12-13-2010 08:16 AM - last edited on 03-09-2022 10:56 PM by smallbusiness
I am having an issue with a 7962 and I think I am completely misinformed about how the phone load process works. The current setup involves a 7962, a cisco 2811, and a NME-16ESW switch module. Currently, we are using SCCP for the phone load. In the 2811, for the telephony-service section, I have the following stated:
load 7961 SCCP41.8-4-S2
The ephone setup is as follows:
ephone 3
no multicast-moh
device-security-mode none
description 7962 Phone
mac-address macaddwithheld
ephone-template 1
paging-dn 71
type 7961
button 1:3
Solved! Go to Solution.
12-13-2010 07:12 PM
It's looking for the load for a 7962 because it IS a 7962. A 7962 and a 7961 are not the same thing. They use different firmware. You cannot force a phone to take a load for another model. When the phone hits the TFTP server, it will grab firmware files for its specific model and get them loaded before it ever even gets to the section where you define what it is.
You'll need to define the load for a 7962 in the telephony-service section, declare the files in the tftp section, and then define the ephone properties appropriately.
12-13-2010 07:12 PM
12-13-2010 09:00 PM
Would you mind providing me show run and show flash of your router.
Luis Sandi
12-20-2010 12:21 PM
I just simply loaded the correct files as suggested. This fixed the issue. Thanks for the help.
