Phone Registration Errors
studmuffin
I am getting registration errors on my cisco ip phone 7962 I cant get it to register in the cucme becuase it keeps saying that it cant find sep(themacaddressofsaidphone).cnf.xml but i created the cnf files and did a tftp flash i dont get what is wrong
George Sotiropoulos
Do you have other 7962 phones that are operational on your environment?
Can you post your running-config?
Hope the above helps,
gsotirop
wkyuen.ricky1
Did you check the network?
Is the CME able to ping the phone?
