10-28-2013 08:49 AM - edited 03-16-2019 08:06 PM
Hi ,
I have an IP Telephony setup with Call Manager Express running on cisco 2921 router with version 9.1.My isssue is phones are not getting registered .All the phones showing like " Registering".
I have enabled the DHCP Pool in the CME itself and phones are getting the Ip address,Subnet mask,default gateway and TFTP server IP.
I am able to ping the default gateway and Phone Ip address from the CME itself.
When I checked the staus message from the phone I can see that File not found : SEP001F9E26639C.cnf.xml
Attached is the Sh run and Licence details.
Nithin Louis.
10-28-2013 09:17 AM
Hi nithin
Please under telephony-service type auto-reg-ephone , your issue as i found no auto-reg.
thank you
please rate all useful information
10-28-2013 09:25 AM
Hi Islam,
I have configured auto-reg-ephone under the telephony-service...but result is same...phone trying for registering......
nithin louis.
10-28-2013 09:28 AM
You dont need auto registration for your phones to register. You have laready configured your phones. Your firmware for the phone type you have is wrong..here is what you need. You need to upload them to flash and then change your tftp-server command to have these files
SCCP41.9-2-1S.loads
apps41.9-2-1TH1-13.sbn
cnu41.9-2-1TH1-13.sbn
cvm41sccp.9-2-1TH1-13.sbn
dsp41.9-2-1TH1-13.sbn
jar41sccp.9-2-1TH1-13.sbn
term41.default.loads
term61.default.loads
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
10-28-2013 09:39 AM
Hi Nithin
1-I need from you to try only one thing , on the phone which is trying to register . Please press setting **# then tyou will find Erase button appears , please press erase , then wait.
Thank you
10-28-2013 09:19 AM
I think you have the wrong files..These files are for 7911 IP Phones. You need files with 41..names not 11
tftp-server flash:apps11.9-3-1ES13.sbn
tftp-server flash:cnu11.9-3-1ES13.sbn
tftp-server flash:cvm11sccp.9-3-1ES13.sbn
tftp-server flash:dsp11.9-3-1ES13.sbn
tftp-server flash:jar11sccp.9-3-1ES13.sbn
tftp-server flash:SCCP11.9-3-1SR2-1S.loads
tftp-server flash:term06.default.loads
tftp-server flash:term11.default.loads
10-28-2013 09:28 AM
I just trying to upgrade the FM for the 7911 phones......not for the 7941.......
But the result is same....
Nithin Louis.
10-28-2013 09:30 AM
Do I need to upgrade the FM for 7941 phones ?
Nithin Louis.
10-28-2013 09:43 AM
Your configuration does not show anything about the 7911 ip phones...
10-29-2013 12:15 AM
I have upgrade the 7941 firmware from sccp-41-8-3-1s to 8.5(2) and the upgrade to SCCP41.9.2-1SR2S....
But phone still showing registering.Not only 7941 none of the phones are registering in the new CME.
Attached is the updated show run and debug tftp events.
Best Regards
Nithin Louis.
10-29-2013 01:10 AM
Hi nithin
Is this problem for all phones which you have (CIPC , 7941 , 7911) , please specify?.
Hi Nithin
Thank you
Please rate all useful information
10-29-2013 04:07 AM
Your problems seem to be locale related..The CCME server cant find the following locale files.
Oct 28 22:10:20.914: TFTP: Looking for English_United_States/mk-sccp.jar
Oct 28 22:10:21.422: TFTP: Looking for United_States/g3-tones.xml
Copy the attached locale file into flash...
Then
Copy into Flash:/its
CUCME(config)#telephony-service
CUCME(config-telephony)#user-locale 0 US load CME-locale-en_US-English-8.8.2.5.tar
Next create cnf files..
CUCME(config-telephony)#create cnf-files
Then test your phones again and send debug tftp events if you still have issues
