IP Telephony and Phones
Labels
Hello,I have the file TSPSingleLinex64-2-2-0-8.exe  dated from 16/11/2010.Can't find a newer version (I this version is difficult to find on download area)Do you know if there is a newer version ? (I use a CME)Do you know if it exist a tapi client fo...
dufour001 by Level 1
  • 347 Views
  • 1 replies
Hi,I just want to know that below rule would remove 9 from incoming number. Now i am using CUCM 7 with h323 gateway. Telco is sending last 4 digits and poiting to CTI route point. Now at above scenario, whats the use? and where shall i call that prof...
techguy by Level 4
  • 2153 Views
  • 8 replies
Hi All,We are running with CUCM 9.1.2 & LDAP integration is enabled. When we tried to do the Manual sync for one of the LDAP directory & it immediately disappear from the Directory list  in CUCM GUI & all the user went to Inactive state.While we veri...
