06-28-2009 03:43 PM - edited 03-15-2019 06:43 PM
My current setup is as follows
PBX to VOIP routers - WAN - VOIP router to PBX
Calls are getting connected and the phone rings at either site, when someone picks the phone up there is just silence.
any suggestions?
Thanks in advance for any help
06-28-2009 04:17 PM
can u check the routing any acl, firewall,...?
06-28-2009 04:24 PM
Hello
Yes, look the routing rules (acl, firewall...) all that can to block the rtp.
The RTP and signaling protocol, use differente ports.
Thx
Peterson
06-29-2009 12:48 AM
There is full routing between the 2 routers accross the WAN, there are also no firewalls in place or ACL's on any router interfaces.
is there anything else i should be looking at, or any other possible causes to this problem?
06-29-2009 04:49 AM
Send us the configuration both routers.
What is the codec utilized?
06-29-2009 05:17 AM
06-29-2009 05:48 AM
Try to create a voice class codec
Example:
(config)#voice class codec 1
(config-xx)#codec preference 1 g729r8
(config-xx)#codec preference 2 g729br8
On both routers and apply this voice class on dial-peer voip
example:
dial-peer voice x voip
voice-class codec 1
So, on dial-peer voip put the command:
incoming call .T
Example
incoming call .T
Thx
Peterson
