Is it possible to configure paging in call manager 7.0 ? Pls advice..
I can't seem to do it across the VPN. Everyone is default g.711Internal it works fine.The site across the vpn can not do conferencing. So it seems that something is off. I just can't put my finger on it.I have the CFB confgiure and have the MRG in bo...
Hello, The document titled "Cisco Unified Border Element for Contact Center Solutions" states that if xcoding is needed for agent phones that xcoding needs to be done on the CUBE. I have configured xcoding on the cube and this does work, but should ...
Hi all,We're deploying IP Communicator alongside a 3rd party SSL VPN which advises it supports Cisco IP Communicator 1.x+ using IP pool allocations. However, I've not managed to get it to work unless I specify the IP address for network audio manuall...
Hi guys,I am trying to setup a Trixbox conference. This is working OK but when call from PSTN then the DTMF digits are not recognized. If I call from a SCCP phone which is registered to our callmanager it is working without a problem.This is my setup...
Hi,We have a customer that has a couple of sites (one runs CUCM 6.1.1, and the other 6.1.3). Both site have Kirk 600v3 Dect systems, that use SCCP integration with the UCMs. We recently upgraded the Kirk base stations/radios to version IPfirmware_607...
Hi,can soneone please help, I have our remote sites registered to the the Call Manager Cluster with SRST in place if failure on the main WAN path. However a couple of times now on a main WAN failure the telephones have correctly registered to the SRS...
The problem is I dial my voicemail pilot number, the call is picked up but I don't get any audio output from Unity. I would expect the usual 'Please enter your PIN' etcâ¦I am running:Cisco Unified CM Administration (7.0.2.20000-5)Cisco Unity Express...
Telepresence 500 - I am unable to consle into the hardware codec. Anyone know how to restore to factory default settings?Your help is greatly appreciated
Hi - We currently have a single site 2 node (1xpub and 1xsub) CUCM Systemversion: 7.0.2.20000-5 cluster.Our customer has requested we re-address both the subscriber and the publisher toaccommodate their new address scheme. I have followed the doc htt...
Hello all,We are currently asked by a telcom to test functionality of Cisco IP Phone 7940/60 with their SIP Server SBG (Ericsson) in a LAB environment.I was able to change the firmware from SCCP to SIP successfully (version P003-8-12-00)The Phones ar...
Hi,CME 7.1 with CUE 7.0.The requirement is: 5 agents dynamically join/leave the hunt-group(use Hlog). when all the agents left the hunt-group, one agent can have the option to forward the hunt-pilot call to his cell phone. Each day different agent wi...
I have a Call Manager running 3.3(3) SR3 and would like to know the maximum uers I can have on a Meet-Me Bridge. Thanks everyone....
I'm looking for a configuration guide that include all the details for installation and configuration for unity connection including integrarion with lotus any of you can provide the link?regards
I need to install any Cisco IP phone for use as doorphone (indoor conditions). I need touchscreen and handsfree capabilities, so the visitors can select the extension and call with it in handsfree mode. I imagine a model similar to 7975 without hands...
Subject | Author | Posted |
05-30-2025 10:37 AM | ||
05-29-2025 01:49 AM | ||
05-23-2025 02:08 PM | ||
05-22-2025 11:54 PM | ||
05-21-2025 06:23 AM |
User | Count |
6 | |
5 | |
2 | |
2 | |
1 |
