05-10-2012 09:31 AM - edited 03-16-2019 11:05 AM
Hello Guys,
I got a issue in my compony that my Pilot Point does not registering any more. I already restarted the service, but nothig happened.
Could you provide any further information please?
Marcos Cardoso
Solved! Go to Solution.
05-11-2012 02:15 AM
Marcos,
Can you check under User Management ---> Application User
You should have an account for "ac"
Check that you have associated your Pilot Point "PP-BR" to this user.
If yes then you could try resetting the password for "ac" back to the default "12345"
Alex.
Please rate useful posts.
05-10-2012 11:02 AM
Oi Marcos,
If this was working before and the PP is not regitering after restarting the services
(Restarted CTI manager/AC server service) I will recommend to reboot the CUCM.
Otherwise delete the PP and recreate it.
Tere.
If you find this post helpful, please rate!
05-10-2012 11:19 AM
Oi Tere,
I restarted both services and still does not working. In addition, I create a new one and I got the same issue. Could be a problem with jtapi?
Thanks for your help!
05-11-2012 02:15 AM
Marcos,
Alex.
05-11-2012 08:51 AM
Alex,
In fact, I don´t know why this user was erase on CUCM. I created again and it works.
Thank you for your help!
