Pings dropping packets to the ip phone
Alex Nemeth
I am trying to troubleshoot call quality problems.
I did an extended ping from a CUBE to ip phone out across the wan with 1000 reps and TOS 184.  I drop packets and was told that is from the anti dos feature of the phone that will drop packets if it is sent at a high rate.
Is there a way to disable that so I can run pings to troubleshoot.
Alex Nemeth
04-CUBE#ping
Protocol [ip]:
Target IP address: 172.17.144.122
Repeat count [5]: 1000
Datagram size [100]:
Timeout in seconds [2]:
Extended commands [n]: y
Source address or interface:
Type of service [0]: 184
Set DF bit in IP header? [no]:
Validate reply data? [no]:
Data pattern [0xABCD]:
Loose, Strict, Record, Timestamp, Verbose[none]:
Sweep range of sizes [n]:
Sending 1000, 100-byte ICMP Echos to 172.17.144.122, timeout is 2 seconds:
Success rate is 99 percent (995/1000), round-trip min/avg/max = 79/82/353 ms
04-CUBE#ping
Protocol [ip]:
Target IP address: 172.17.65.140
Sending 1000, 100-byte ICMP Echos to 172.17.65.140, timeout is 2 seconds:
Success rate is 92 percent (926/1000), round-trip min/avg/max = 52/107/1048 ms
04-CUBE#
Hi Alex,
This one is an old "gotcha"
http://www.cisco.com/c/en/us/support/docs/voice/skinny-call-control-protocol-sccp/25200-ipphone-ping.html
Basically says try using DOS to ping  from a PC instead of pinging from the router.
Alex
Regards, Alex. Please rate useful posts.
