Cisco Spark with CUCM
KY_
Level 4
Level 4
Hi everyone
I watched several video about spark but i want to leanr something about it.
How spark work with CUCM and how can I call CUCM registered endpoint directly ? Can you please someone explain me this quaestion ?
https://www.youtube.com/watch?v=05IAyjWSiEE
Is it available only using with sip uri or can i call cucm registered endpoint using my spark applicaion.How can CUCM integrate spark.
The another question  what is the differenc ebetween cisco jabber ?
Jabber can be also make voice/video calls text messaging and content sharing.
I understood  that Cisco spark as if seem CUCM alternative.Spark client never register cucm and it using cisco cloud services only.Its an cloud base application all 78XX and 88XX series phone can be use cisco services.Can you please somone comfirm me for this stuation.
5 Replies 5
Adarsh Chauhan
Level 3
Level 3
I believe you just touched the sweet spot of Cisco Collaboration.
I will try to do justice to your questions.
Spark is a full blown cloud based Messaging system (Meetings, Chat and Call).
Spark has been built to be as the working place for a team
(You have concept of Teams and Rooms in Spark).
Spark is extensible unlike jabber and offers a powerful API.
With persistent chat your work/chat/content gets saved in the Room or 1:1 .
Unlike Jabber you can leave message even if the person is offline.
Because not all customers can go on Cloud Cisco offers Spark Hybrid Services.
Demonstration. (This is where your call manager comes into the picture)
For now Spark is not a replacement for Jabber. Jabber is more of a 1:1.
Supported Endpoints with Cisco Spark
Example of registering a SX20
Please rate and mark correct if helpful.
Adarsh Chauhan
Adarsh Chauhan
Thanks for your explanation,
Can I say spark is alternative product for CUCM basicly  spark working on cloud ip phone can directly register it via internet but i could not understand Can I provide sip trunk  on spark for my voice gateway .It seem not possible.
Another things spark does not need MTP.
Can you please give me more much information.
Are there any spark design guide available ?
I would not say its an alternative for CUCM rather put it as an integral part of Hosted solution.
Not exactly a design guide but the document gives you a high level view of Hybrid Spark Service.
Whether it needs MTP or not totally depends on the call flow.
Adarsh Chauhan
Adarsh Chauhan
Hi Kemal,
SPARK is not an alternative to CUCM like Adarsh mentioned but lets just say the Spark architecture does not have Call manager. Spark has its own call connector software to manage calls and registration. To answer the second part, you can make use of the " Call service aware" & "Call ServiceConnect" where the Spark client shares the extension with your desk phone. It is somewhat similar to Jabber's CTI deskphone control. Spark cloud uses CTI protocol to communicate with the CTI manager service on CUCM to control the deskphone.
Information below:
https://www.cisco.com/c/dam/en/us/solutions/collateral/unified-communications/hosted-collaboration-solution-hcs/at-a-glance-c45-736665.pdf
Architecure below:
http://www.cisco.com/c/dam/en/us/td/docs/solutions/PA/maroon/hybridswp.pdf
Aseem
(Please rate if useful)
voipeee
Level 3
Level 3
Hey All,
I would like to know how can I integrate Spark and my IP Phone?
Muk
