PLAR configuration Issue
Nikunj Shah
Hi All,
Please help me to solve PLAR issue.
There are two phones and both are in different Cluster.
Extension number 1000 is configured on Cluster 2 and Extension 2000 is configured on Cluster 1.
I have configured PLAR in such a way that once extension 1000 goes off hook phone will automatically dial extension 2000.
Below are the configuration.
  • Partition Configuration For null TP.
Partition
PLAR1_PT
  • CSS configured for Phone and TP.
CSS
Selected PT
Assigned to Line
PLAR1_LINE_CSS
PLAR1_PT
Assigned to TP
PLAR1_TP_CSS
Cluster-1-PT
  • Cisco 7841 configuration.
Phone Config
Ext. 1000
Line Partition
ABC-PT
Line CSS
PLAR1_LINE_CSS
SIP Dial Rule
PLAR_2000
  • This is a SIP phone so i have created SIP Dial rule.
SIP Dial Rule
Dial Pattern
Dial Parameter
Value
PLAR_2000
7940_7960_OTHER
Pattern
2000
  • Null Translation Pattern configured as
Translation Pattren
" NULL"
Called Party Transform Mask
2000
Partition
PLAR1_PT
CSS
PLAR1_TP_CSS
  • Route pattern configuration which is pointing to Cluster 1.
Pattern
Description
Partition
Associated Device
2000
Pointing to Cluster 1
Cluster-1-PT
Cluster-1-RLT
(Note: I can call to extension 2000 from NON PLAR phone.)
No CSS on DN, just CSS on device.
Your SIP dial rule should only have one statement with value 2000, make sure you pressed the PLAR button when you added it.
12 Replies 12
Andrew West
Level 4
Level 4
I might have missed it in there but what is the actual problem you are having?
When extension 1000 goes off hook phone is not auto dialing (I can here Dial-ton) .
I have also checked by changing Line CSS ( added RP's PT on Line css)  for testing.
by changing Line css, I can dial 2000 number manually.
Chris Deren
Is the "PLAR1_LINE_CSS" assigned to the DN or device?
It needs to be assigned to Device and not DN for SIP PLAR to work.
Hi Crish,
Yes, same css has been assign to device and line.
But it will select line css 1st as line css has high priority.
Leave it only on the device.
Post screen shot of your dial rule.
Okay
So for Line which CSS need to select.. the css which has PT of RP??
Please find below screen shot of dial rule
Hi Chris,
PLAR is working now.
Thanks.
Excellent, can you please mark the thread as answered and rate all useful posts?
SIP Dial Rule not working for me too.
configured Button 1 instead of pattern but not working.
any help
Device Model: 8861
Worked please ignore this message
