Please share the flow to get time for SIP and SCCP phones.
adiyodi.rakesh
NTP has associated with Date and time group.So someone please share the flow to get the time for SIP and SCCP phones.
CUCM 10.x VER
Happy to help.
Dont forget to mark the post as answered if you dont have further questions :-)
JB
5 Replies 5
Jitender Bhandari
below explains the difference
NTP reference is for SIP devices only, SCCP devices always pull time from Call Manager, so they use Date and Time Group assigned to the device pool to place them in the correct time zone.  You add a NTP reference point into the Date and Time Group so any SIP phones assigned to the device pool will get the correct time zone and will get NTP from a NTP reference point.  Call Manager does not use these NTP reference points for SCCP phones, to set the call manager to use a NTP server is done under the OS Admin page Settings>NTP Servers.
https://learningnetwork.cisco.com/thread/50702
(Rate if it helps)
JB
Thanks Jithender.
One Doubt.:-
SCCP phones taking the time from Call manager and convert the time based on the "Date and Time Group".?
Whether the SIP phone taking from NTP reference,how the phone gets the time based on the Country.
Means NTP server have one UTC time.SIP phone have ET timezone.So how it converts.
Is there any messages happen in between the devices ?
Read below for complete understanding
https://books.google.co.in/books?id=_umTnCW4M-wC&pg=PA146&lpg=PA146&dq=cucm+ntp+for+sccp+and+sip+phone&source=bl&ots=YlYMgzjtSO&sig=7D3xomxDRYAMc5iLUBKtivAdGr8&hl=en&sa=X&ved=0ahUKEwjGm7Lgl8_VAhUBSiYKHQ0vCqcQ6AEISjAE#v=onepage&q=cucm%20ntp%20for%20sccp%20and%20sip%20phone&f=false
(Rate if it helps)
JB
Thanks Jithender.
I have understood about my queries.
Happy to help.
JB
