CUCM version 8.6.2, 6921 ip phone is rejected when firmware is upgraded
Not applicable
 hello
like title, if i upgrade ip phone 9-4 firmware version,
the phone gone to reject status
so i restore firmware version 9-3-1 then, the phone registered
These symptoms only occur on the 6921 model. 7911, 7962, 7975 is fine
help me plz
When i upgrade firmware
IPTS01F2960A#sho cdp nei fa0/2 de
Device ID: SEPF866F2F6B516
Entry address(es):
Platform: Cisco IP Phone 6921,  Capabilities: Host Phone Two-port Mac Relay
Interface: FastEthernet0/2,  Port ID (outgoing port): Port 1
Holdtime : 120 sec
Second Port Status: Down
Version :
SCCP 9.4.1.3
can't assign IP
Entry address(es):
  IP address: 10.237.207.17
Platform: Cisco IP Phone 6921 ,  Capabilities: Host Phone Two-port Mac Relay
Holdtime : 129 sec
Version :
SCCP 9.3.1.3
advertisement version: 2
Duplex: full
Power drawn: 6.000 Watts
Power request id: 18115, Power management id: 5
Power request levels are:6000 0 0 0 0
Management address(es):
IP assigned
5 Replies 5
Dennis Mink
rather then from going from 9.3 to 9.4, in 1 go,  do it in steps,  I have found some time this works, I know this is somewhat tedious, but in the past found this the only solution sometime.
you can try a single phone by hard setting the LOAd in the phones configuration pages and leaving the device default the same (9.3.1) until tested successfully.
Please rate if helpful
Please remember to rate useful posts, by clicking on the stars below.
 cmterm-69xx-sccp.9-3-1-3
next version cmterm-69xx-sccp.9-3-3-2
but same
so i tried sccp.9-3-3-2-sr1
sccp.9-4-1-3
SCCP-9-4-1-3SR2
but all next version does not work.
thanks Dennis
Won-kyo,
are you saying you have them on SCCP-9-4-1-3SR2 and then the next version fails?
and you are sure you are running them on SCCP not SIP?
i am running on SCCP not SIP
current my version 9-3-1-3
but The next version, 9-3-3-2-sr1, will also be in the Reject state.
Other versions sccp.9-4-1-3 and sccp.9-4-1-3SR2 are also in the same REJECT state.
I'm wondering if you can not solve it.
Did I miss something else?
To update the firmware, refer to the address below
https://supportforums.cisco.com/document/9873946/upgrade-downgrade-firmware-specific-ip-phone
Dear all,
I've extactly the same issue with cucm 8.5.1.10000-26 and 8.6.2.22900-9.
I tried to upgrade firmware SCCP69xx.9-3-1-3 to a higher version but it's not working.
I tried to upgrade to SCCP69xx.9-3-3-2, SCCP69xx.9-4-1-3 and SCCP69xx.9-4-1-3SR1 but the result is the same. Phone rejected on CUCM, i don't undrestand why...
