polycom soundstation duo instead of 7937
hi all,
am having cisco CME version 9.1 and am trying to use and register the polycom soundstation duo using the sip protocol in the call manager express router and works as audio conference instead of the 7937g/7936, Is that possible???
Is the polycom soundstation duo compatible with cisco cme???
thanks.
Jitender Bhandari
Hi Mohammed,
you can check the below link and see if it helps.
http://www.cisco.com/c/dam/en/us/products/collateral/unified-communications/unified-communications-manager-express/spa_polycom_application.pdf
JB
