Bookmark
Subscribe
1558
Ports on a VG-450 will not register
Good afternoon-
We have just installed a Vg-450. When we create a POTS line and add the config, it will not register until we reset the entire gateway. After that the port registers and functions correctly.
Are we missing something?
Steve McFarland
I assume that you register the VG with a CUCM, Can we know  the protocol used. And could you share your VG configuration.
Response Signature
We are using MGCP.
I am not allowed to send the configuration. I can't continue with this resource.
Thank you for your time.
With MGCP I think that you would need to reset the gateway once you complete the configuration of the directory number(s). As you say that it is working after this I’m going to say that this is working as intended.
Response Signature
