Possible to Trace/Follow a Call to its Destination?
Matthew Martin
Level 5
Level 5
Hello All,
CallManager:  8.0.3.21900-8
Is it possible for me to make a test call into the CallManager to a DN and be able to see how to call is
being routed through the CallManager? For instance, I want to see what Partition, Calling Search Space,
and Translation Patterns it goes through, etc...
Wasn't sure if this was possible, say though the RTMT or something like that?
Is that possible? I'm trying to create a new Translation Pattern and it doesn't seem to be working.
Thanks in Advance,
Matt
Jaime Valencia
Yes, use DNA
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Jaime Valencia
Yes, use DNA
java
java
Hey Jaime, thanks for the reply!
Ahhh Yes, the Dialed Number Analyzer, totally forgot about that... Sorry still new with this stuff.
But just tried it and it looks like that's what I'm looking for...! Thanks!
Thanks for the Help!
Matt
