PRA layer 3 problem on outgoing calls
David Wagner
i've a 2811 voice-gateway in a location in poland.All inbound calls are fine - no problems. But i experiencing strange problems on outgoing calls: Some calls are OK - but almost all outgoing calls fail. In the debug, i get the "CALL_PROC" and the "ALERTING" (the called phone rings). But after that, my gateway sends a "DISCONNECT".
Jul 15 06:17:47.266: ISDN Se0/2/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x1 0x1, Calling num 48717XXXXX
Jul 15 06:17:47.270: ISDN Se0/2/0:15 Q931: Sending SETUP  callref = 0x00A0 callID = 0x8021 switch = primary-net5 interface = User
Jul 15 06:17:47.270: ISDN Se0/2/0:15 Q931: TX -> SETUP pd = 8  callref = 0x00A0
        Sending Complete
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA18381
                Preferred, Channel 1
        Progress Ind i = 0x8183 - Origination address is non-ISDN
WRO-STADIUM-VG1#
        Calling Party Number i = 0x1181, '48717XXXXX'
                Plan:ISDN, Type:International
        Called Party Number i = 0x91, '49XXXXXXXXX'
Jul 15 06:17:47.358: ISDN Se0/2/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x80A0
        Channel ID i = 0xA98381
                Exclusive, Channel 1
WRO-STADIUM-VG1#
Jul 15 06:17:53.382: ISDN Se0/2/0:15 Q931: RX <- ALERTING pd = 8  callref = 0x80A0
WRO-STADIUM-VG1#
Jul 15 06:17:57.786: ISDN Se0/2/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x00A0
        Cause i = 0x80BF - Service/option not available, unspecified
Jul 15 06:17:57.826: ISDN Se0/2/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x80A0
Jul 15 06:17:57.830: ISDN Se0/2/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x00A0
paolo bevilacqua
Which exact IOS ?
12.4.24T
Update: Both, inbound and outbound calls have these problems...
Are you using CM? I remember some wrong setting there can cause that. Unfortunately, I don't remember which ones.
