07-14-2010 11:31 PM - edited 03-15-2019 11:43 PM
i've a 2811 voice-gateway in a location in poland.All inbound calls are fine - no problems. But i experiencing strange problems on outgoing calls: Some calls are OK - but almost all outgoing calls fail. In the debug, i get the "CALL_PROC" and the "ALERTING" (the called phone rings). But after that, my gateway sends a "DISCONNECT".
Jul 15 06:17:47.266: ISDN Se0/2/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x1 0x1, Calling num 48717XXXXX
Jul 15 06:17:47.270: ISDN Se0/2/0:15 Q931: Sending SETUP callref = 0x00A0 callID = 0x8021 switch = primary-net5 interface = User
Jul 15 06:17:47.270: ISDN Se0/2/0:15 Q931: TX -> SETUP pd = 8 callref = 0x00A0
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA18381
Preferred, Channel 1
Progress Ind i = 0x8183 - Origination address is non-ISDN
WRO-STADIUM-VG1#
Calling Party Number i = 0x1181, '48717XXXXX'
Plan:ISDN, Type:International
Called Party Number i = 0x91, '49XXXXXXXXX'
Jul 15 06:17:47.358: ISDN Se0/2/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x80A0
Channel ID i = 0xA98381
Exclusive, Channel 1
WRO-STADIUM-VG1#
Jul 15 06:17:53.382: ISDN Se0/2/0:15 Q931: RX <- ALERTING pd = 8 callref = 0x80A0
WRO-STADIUM-VG1#
Jul 15 06:17:57.786: ISDN Se0/2/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x00A0
Cause i = 0x80BF - Service/option not available, unspecified
Jul 15 06:17:57.826: ISDN Se0/2/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x80A0
Jul 15 06:17:57.830: ISDN Se0/2/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x00A0
07-15-2010 01:35 AM
Which exact IOS ?
07-15-2010 03:46 AM
12.4.24T
07-15-2010 06:04 AM
Update: Both, inbound and outbound calls have these problems...
07-15-2010 10:18 PM
Are you using CM? I remember some wrong setting there can cause that. Unfortunately, I don't remember which ones.
