Prblem in blocking FXS stations to go outside
dbenattou
hello,
i have a router 2851 with FXO and FXS .
i want that statios behind FXS can't call outside through FXO.
thanks at advance.
8 Replies 8
paolo bevilacqua
See:
http://cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a008019d649.shtml
Note: the actual configuration can be made smaller that in the example. Just configure with cor the incoming DP for FXS (if not using FXS in SCCP mode), and the DP matching FXO.
hi,
thanks for reply
but i don't have CME to configure COR.
thanks again.
Do you have CM? And if so which protocol are you using to the router ?
hi,
i have CCM 5.1 and i use H323 protcol.
thanks very much
Then he COR configuration still applies. Set a "station number" under voice-port and match it with "answer-address" on a pots DP. That will be your incoming DP.
Another technique is that you configure a translation profile again on the FXS voice port, and change the called number so that it can't dial outside.
hi,
it doesn't work
can you troubleshhot the config :
dial-peer cor custom
name FXS
name All
dial-peer cor list Test
member FXS
dial-peer cor list ALL
member All
dial-peer voice 2 pots
corlist outgoing ALL
destination-pattern .T
progress_ind setup enable 3
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
port 0/0/2
dial-peer voice 3 pots
preference 1
port 0/0/3
dial-peer voice 4 pots
preference 2
port 0/1/0
dial-peer voice 5 pots
preference 3
port 0/1/1
dial-peer voice 52 pots
corlist outgoing Test
answer-address 6211
port 2/0/0
thanks at advance
1. DP 52 needs corlist incoming, not outgoing
2. DP 52 does not need port
3. Have you set station number under voice port 2/0/0 ?
4. unrelated to the problem, you don't need any of the progress_ind commands under DP, these are for ISDN only, and not even always.
5. suggest you use trunkgroup for port 0/0/2, 0/0/3, and 0/1/0 ? That will allow you using a single DP, simplifying much the configuration.
hello,
thank you vey much for your help and also your advices.
You are Wonderful.
