08-16-2010 12:58 AM - edited 03-16-2019 12:15 AM
Hi there,
We have an Access Server here, when I try to create a voip dialpeer pointing to a new CCM SUB we just added, the dialpeer is created but when I type the command
show dial-peer voice summary
it seems it is created with a prefix 01, I am not able to delete this prefix, and when I try to check the dialpeer configuration I do not find this prefix at all!!
However when I create a dialpeer pointing to the existing CallManagers, it is created without this prefix !
Apprecaite any assistance please, thanks a lot.
08-16-2010 01:51 AM
Maybe is a leftover from a previousl pots DP with the same tag, that had prefix.
It is a cosmetic issue that you can ignore.
08-16-2010 03:12 AM
Actually it is causing problems because when a called number matches this dialpeer, the call fails with the disconnect cause "network out of order (38)"
Any ideas??
08-16-2010 04:19 AM
Voip DP support no prefix, so that is not the cause.
You can recreate the DP under another tag anyway, but it will still fail according to the statement abvove.
