12-24-2012 06:15 AM - edited 03-16-2019 02:51 PM
We would like to Know Cisco New Premium attendant Console 9.0 supports redundancy over WAN or not , we would like to deploy CUAC Publisher in one data center and CUAC Subscriber in another data center.
12-24-2012 07:23 AM
Maheshwar,
I reviewed the design doc (link below) as well as the release notes and there is no mention of latency/bandwidth requirements for resiliency. I know that does not help you, so if I was you I would open a PDI ticket to check for sure.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucmac/arc/CUAC_V9_Design_G.pdf
HTH,
Chris
01-04-2013 08:24 AM
Yes it is supported over the WAN.
Some considerations:
CUAC Client should have no more than a RTT of 150ms to the CUAC servers
CUAC servers should have no more than a RTT of 80ms to the CUCM
It is also important that the time on the Publisher and Subscriber CUAC servers are the same, they need to match in order for failover to work correctly.
08-08-2013 07:24 PM
Jamie,
Is that information documented somewhere?
