presence-ciro
nettuno8_20111
hi I have a router 2900 CME VERSION 12.0 I have a problem with the presence on the 7975 ip phones registered in SIP the problem is that when I pick up the handset I have when I put the DND of the ip phone the other phones do not see the presence on the buttons, only when it does the call the presence can be seen on the buttons of the ip telephone. then I have other phones registered in SCCP the presence works perfectly for me. how can i do for sip ip phones.
6 Replies 6
Start with sharing your configuration from the router that you run CME on. Without any information to go with we cannot provide you any advice quality advice as it would purely be based upon speculation and guesswork.
Response Signature
voice-card 0
voice service voip
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
registrar server expires max 120 min 60
voice register global
mode cme
source-address 188.168.0.1 port 5060
timeouts interdigit 2
max-dn 20
max-pool 20
load 7942 SIP42.9-2-1S
load 7975 SIP75.9-2-3S
authenticate register
timezone 28
time-format 24
date-format D/M/Y
tftp-path flash:
logo CME-SIP
create profile sync 0001814734597506
network-locale IT
user-locale IT
voice register dn 1
number 301
allow watch
name anna
label anna
voice register dn 2
number 302
allow watch
name noemi
label noemi
voice register dn 3
number 303
allow watch
name pasquale
label pasquale
voice register dn 4
number 304
allow watch
name peppe
label peppe
voice register pool 1
id mac 6416.8DBB.913F
type 7975
number 1 dn 1
presence call-list
dtmf-relay sip-notify
username anna password cisco.com
codec g711ulaw
blf-speed-dial 1 302 label "noemi" device
blf-speed-dial 2 402 label "maria" device
blf-speed-dial 3 401 label "ciro" device
blf-speed-dial 4 303 label "pasquale" device
voice register pool 2
id mac 001D.45E9.5D43
type 7975
number 1 dn 2
presence call-list
username noemi password cisco.com
codec g711ulaw
blf-speed-dial 1 301 label "anna" device
voice register pool 3
id mac 108C.CFE1.3244
type 7942
number 1 dn 3
presence call-list
username pasquale password cisco.com
codec g711ulaw
voice register pool 4
vxml logging-tag
license udi pid CISCO2901/K9 sn FCZ171691S0
hw-module pvdm 0/0
redundancy
controller VDSL 0/0/0
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/1
description router-voice to router-isp
ip address 192.168.0.1 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1.2
description VOIP-SCCP
encapsulation dot1Q 2
ip address 188.168.1.1 255.255.255.0
interface GigabitEthernet0/1.15
description VOIP-SIP
encapsulation dot1Q 15
ip address 188.168.0.1 255.255.255.0
interface ATM0/0/0
no ip address
shutdown
no atm ilmi-keepalive
interface Ethernet0/0/0
no ip address
shutdown
ip forward-protocol nd
ip http server
no ip http secure-server
ipv6 ioam timestamp
tftp-server flash:apps42.8-3-1-22.sbn
tftp-server flash:cnu42.8-3-1-22.sbn
tftp-server flash:cvm42sccp.8-3-1-22.sbn
tftp-server flash:dsp42.8-3-1-22.sbn
tftp-server flash:jar42sccp.8-3-1-22.sbn
tftp-server flash:SCCP42.8-3-2S.loads
tftp-server flash:term42.default.loads
tftp-server flash:term62.default.loads
tftp-server flash:apps42.9-2-1TH1-13.sbn
tftp-server flash:cnu42.9-2-1TH1-13.sbn
tftp-server flash:cvm42sip.9-2-1TH1-13.sbn
tftp-server flash:dsp42.9-2-1TH1-13.sbn
tftp-server flash:jar42sip.9-2-1TH1-13.sbn
tftp-server flash:SIP42.9-2-1S.loads
tftp-server flash:apps75.9-2-3TH1-9.sbn
tftp-server flash:cnu75.9-2-3TH1-9.sbn
tftp-server flash:cvm75sip.9-2-3TH1-9.sbn
tftp-server flash:dsp75.9-2-3TH1-9.sbn
tftp-server flash:jar75sip.9-2-3TH1-9.sbn
tftp-server flash:SIP75.9-2-3S.loads
tftp-server flash:term75.default.loads
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
presence
presence call-list
max-subscription 150
watcher all
allow subscribe
sip-ua
presence enable
gatekeeper
shutdown
telephony-service
max-ephones 20
max-dn 20
ip source-address 188.168.1.1 port 2000
system message CME-SCCP
user-locale IT
network-locale IT
load 7942 SCCP42.8-3-2S
time-zone 28
time-format 24
date-format dd-mm-yy
max-conferences 8 gain -6
transfer-system full-consult
create cnf-files version-stamp 7960 Aug 17 2023 17:50:21
ephone-dn 1
number 401
label ciro
name ciro
allow watch
ephone-dn 2
number 402
label maria
name maria
allow watch
ephone 1
device-security-mode none
mac-address C07B.BCA0.99EB
presence call-list
type 7942
button 1:1
ephone 2
mac-address 0016.C7EA.297E
presence call-list
blf-speed-dial 2 302 label "NOEMI" device
type 7960
button 1:2
A few things, although not directly related to your question. Why do you have different VLANs for the SCCP and SIP phones? That’s not necessary or recommended. Also you don’t need to use usernames/passwords on the SIP phones and this command is not needed “authenticate register”. What version of IOS are you using?
Response Signature
I am using CME VERSION 12.0
Thank you, but that’s not what I asked. What version of IOS do you use?
Response Signature
IOS version 15.7
