08-01-2012 01:27 PM - edited 03-16-2019 12:29 PM
Hello everyone,
I'm a bit confused. If I download the OVA template for Presence and and deploy it on the VM does that include the install program for Presence or or do I still need install media?
Thanks in advance! All replies rated.
Solved! Go to Solution.
08-01-2012 02:08 PM
All our OVAs are just the VM specs, you need to have install media and do the actual install for any product.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
08-01-2012 02:08 PM
java
08-01-2012 02:37 PM
Thanks again (for the 100th time!)
Is the media for Presence downloadable from Cisco?
08-01-2012 03:02 PM
Nope, fresh install media is not downloadable from CCO. You need to order it via PUT.
java
05-01-2013 09:48 AM
The PUT tool asks for a Contract Number. If this is a new install on an MCS system how do you go about getting the media/contract number?
Joe
