02-15-2017 06:17 AM - edited 03-17-2019 09:32 AM
I recently got a request to change my call forward all settings so that the forwarded call appears on the last device with the first number that dialed. I can't quite figure out how to do it, and have been unsuccessful in finding good documentation on it.
Here's the situation:
Forwarding phone number: 555-1234
Calling number: 444-9876
If 555-1234 is forwarded to a cell phone, and 444-9876 calls it, the call will appear on a cell phone as 555-9876. I would like this to appear as 444-9876. Where is the setting that does this, or is it a transformation pattern in our trunks?
Solved! Go to Solution.
02-15-2017 06:52 AM
Try using a Dialed number analysis as the calling number is 555-1234 and the called number is your cell and paste the input here
Devan
02-15-2017 06:38 AM
What is the number that you see originally on the phone when there is no call forward enabled?
Devan
02-15-2017 06:39 AM
The number you'd originally see is 444-9876
02-15-2017 06:52 AM
Devan
02-15-2017 07:18 AM
Ahh, I was unaware of that tool. Incredibly useful. I did find a translation pattern on the route pattern that I removed.
Thanks.
