PRI analog line issue
Ameen Ameer Ali
I have two connection ,one PRI and an Analog connection(fxo).I want all users to use PRI DID number except receptionist.I want Receptionist to take analog line for both incoming and outgoing call.In coming is coming to recetionist extension 0.But when i call from that extension to outside number its taking PRI board number .dial-peer has preference more for PRI i cannot alter that,i want this particular extension to take analog (fxo) and go out.How its possible to implement.I tried to applying cor list also.No luck.Please suggest.
You will need to use cor lists to achieve this in CCME.
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
Chris Deren
Is this CM or CME deployment? If CM I am assuming you are using H323 as you mentioned dial-peers, if so the easiest way to handle this is to create separate CSS/PT/Route Patterns for the operator phone and prefix a digit that then matches different dial-peers on the GW that point to different circuit.
HTH,
Chris
Ameen Ameer Ali
I am Using Call manager express..!!
