07-05-2008 05:06 AM - edited 03-15-2019 11:45 AM
Hi, if I am setting up an ISDN30 PRI on CME in the UK (BT) and we have purchased 6 channels, does the D channel need to be included in the config i.e.
pri-group timeslots 1-7
Thanks.
07-05-2008 05:17 AM
If you have purchased 6 channels, then you can only have 6 bearer channels...The D channel cant be included in your pri timeslots
your config will be pri-group timeslots 1-6
Log in to Community
