PRI Fluctutation
Vijay Patil
Level 3
Level 3
Hi All,
I am facing PRI Fluctuation , beacuse of which Call are diconnected on regular intervals.
below is the error which is gettin on Router Voice Gateway
6 Replies 6
Aman Soi
Hi Vijay,
the snapshot shows RAI[remote alarm indication]  detected which is mainly due to Far end in your case it is TELCO.The other error is due to clocking.if possible,please post your config.
Did u get your media checked by TELCO?
regds,
aman
Hi Vijay.
This usually is a cabling issue from the vg PRI to the provider device.
Check with your local provider an , if you can, the cable connecting PRI interface.
Please also post a show controller E1
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
E004010102CRR#sh controllers e1
E1 0/0/0 is up.
  Applique type is Channelized E1 - balanced
  No alarms detected.
  alarm-trigger is not set
  Version info FPGA Rev: 08121917, FPGA Type: PRK1
  Framing is NO-CRC4, Line Code is HDB3, Clock Source is Line.
  International Bit: 1, National Bits: 11111
  Data in current interval (887 seconds elapsed):
     0 Line Code Violations, 10 Path Code Violations
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     259 Errored Secs, 21 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
  Total Data (last 24 hours)
     0 Line Code Violations, 2432 Path Code Violations,
     8 Slip Secs, 1418 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
     7156 Errored Secs, 916 Bursty Err Secs, 0 Severely Err Secs, 1450 Unavail Secs
islam.kamal
Level 10
Level 10
Hi Vijay
You have to check with your Teleco , that means the other equipment on the other side disconnected or out of service and please check the isdn switch-type may be is mismatched with your SP. Please check the below link which shows your problem :-
http://www.cisco.com/en/US/tech/tk713/tk628/technologies_tech_note09186a00800a70f6.shtml
Thank you
Please rate all useful information
Hi Vijay,
To troubleshoot further, u can try changing CRC parameter under controller config.
Further, u can also give loopback local from controller port to check your cable and E1 port .
loopback remote from controller E1 port to check the media end to end by involving TELCO.
regds,
aman
Hi Amanso
Great idea for disable also CRC4 , but i think this should be done from Teleco side.
Hi Vijay
you have all possible solutions now, please start with contacting your Teleco.
Thank you
