PRI Frame establishment
markedavis
Odd problem here.  Trying to connect to our telco with a PRI on a 2911 h323 gateway. Pretty basic config and I'm no expert troubleshooting the voice side yet.
Cannot get frame established.
    Layer 2 Status:
        TEI = 0, Ces = 1, SAPI = 0, State = TEI_ASSIGNED
Debug isdn q921
Mar  4 21:14:40.884: ISDN Se0/1/0:23 Q921: L2_EstablishDataLink: sending SABME
Mar  4 21:14:40.884: ISDN Se0/1/0:23 Q921: User TX -> SABMEp sapi=0 tei=0
Mar  4 21:14:41.884: ISDN Se0/1/0:23 Q921: User TX -> SABMEp sapi=0 tei=0
Mar  4 21:14:42.884: ISDN Se0/1/0:23 Q921: User TX -> SABMEp sapi=0 tei=0
Mar  4 21:14:43.884: ISDN Se0/1/0:23 Q921: User TX -> SABMEp sapi=0 tei=0
Mar  4 21:14:49.884: ISDN Se0/1/0:23 Q921: L2_EstablishDataLink: sending SABME
Mar  4 21:14:49.884: ISDN Se0/1/0:23 Q921: User TX -> SABMEp sapi=0 tei=0
Could this be a cabling issue?  Not sure where else to look.  Telco basically told me to fix it.
8 Replies 8
Anas Abueideh
Level 9
Level 9
make sure the config is correct, the framing type and CRC, isdn switch type. also check the cable
Anas
please rate if it is helpful
Chris Deren
You are not receiving anything from telco, can be cable, can be provisioning (i.e. switch type, framing, line code), can be that telco has not confifured the circuit. Switch cable, if that does not help, call telco and troubelshoot with them.
HTH,
Chris
markedavis
Thanks, that part is working now.  Thnk you can help me with the rest. I've always used mgcp and the h323 is a bit different.  Trying to get inbound calling working.  I have 5 digit extensions that are 7 then the last 4 of the incoming number.  Here is what I have so far.
Building configuration...
boot-start-marker
boot-end-marker
card type t1 0 0
card type t1 0 1
enable secret 4 qVmJrFcea5.ijlV9XAGG3CHoUtTtp7VJvv3N6SlmCzc
no aaa new-model
no network-clock-participate wic 0
network-clock-participate wic 1
network-clock-select 1 T1 0/1/0
no ipv6 cef
ip source-route
ip cef
isdn switch-type primary-ni
voice-card 0
voice service voip
ip address trusted list
  ipv4 10.5.1.15
  ipv4 10.5.1.16
  ipv4 10.2.100.14
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
  no call service stop
voice class h323 1
  h225 timeout tcp establish 3
voice translation-rule 1
rule 1 /^xxxxxxx\(6...$\)/ /7\1/
voice translation-profile INCOMING
translate called 1
license udi pid CISCO2911/K9 sn FTX1706AKHA
hw-module pvdm 0/0
redundancy
controller T1 0/0/0
cablelength long 0db
channel-group 0 timeslots 1-24
controller T1 0/1/0
pri-group timeslots 1-24
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0.1
description ***Data***
encapsulation dot1Q 1 native
ip address 10.16.28.1 255.255.252.0
interface GigabitEthernet0/0.2
description ***Voice***
encapsulation dot1Q 2
ip address 10.24.8.1 255.255.252.0
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.24.8.1
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
ip address dhcp
duplex auto
speed auto
interface Serial0/1/0:23
no ip address
encapsulation hdlc
isdn incoming-voice voice
no cdp enable
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 10.16.28.2
control-plane
voice-port 0/1/0:23
mgcp profile default
dial-peer voice 101 voip
description To callManager Subscriber
preference 1
destination-pattern 76...
progress_ind setup enable 3
session target ipv4:10.5.1.15
dtmf-relay h245-alphanumeric
codec g711ulaw
ip qos dscp cs5 media
ip qos dscp cs3 signaling
no vad
dial-peer voice 102 voip
description To callManager Publisher
preference 2
session target ipv4:10.5.1.16
codec g711ulaw
no vad
dial-peer voice 999 pots
translation-profile incoming INCOMING
incoming called-number 7....
gateway
timer receive-rtp 1200
How many digits is telco sending?
Can you post "debug isdn q931"?
Chris
markedavis
Thanks for the help Chris.  They are sending 10 digits.
Nothing on the debug at the moment, guess telco is playing with it.
markedavis
Here is the debug.
Mar  4 22:18:41.520: ISDN Se0/1/0:23 Q931: RX <- SETUP pd = 8  callref = 0x0015
        Bearer Capability i = 0x8090A2
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98397
                Exclusive, Channel 23
        Facility i = 0x9F8B0100A1080201010201008400
                Protocol Profile =  Networking Extensions
                0xA1080201010201008400
                Component = Invoke component
                        Invoke Id = 1
                        Operation = CallingName
                                Name not available
        Calling Party Number i = 0x2180, '6979'
                Plan:ISDN, Type:National
        Called Party Number i = 0xA1, '2108196640'
Mar  4 22:18:41.520: ISDN Se0/1/0:23 Q931: Received SETUP  callref = 0x8015 callID = 0x002C switch = primary-ni interface = User
Mar  4 22:18:41.524: ISDN Se0/1/0:23 Q931: TX -> CALL_PROC pd = 8  callref = 0x8015
Mar  4 22:18:41.524: ISDN Se0/1/0:23 Q931: TX -> DISCONNECT pd = 8  callref = 0x8015
        Cause i = 0x8081 - Unallocated/unassigned number
Mar  4 22:18:41.576: ISDN Se0/1/0:23 Q931: RX <- RELEASE pd = 8  callref = 0x0015
Mar  4 22:18:41.576: ISDN Se0/1/0:23 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x8015
Mar  4 22:18:41.596: ISDN Se0/1/0:23 Q931: RX <- RESTART pd = 8  callref = 0x0000
        Restart Indicator i = 0x80
Mar  4 22:18:41.596: ISDN Se0/1/0:23 Q931: TX -> RESTART_ACK pd = 8  callref = 0x8000
I think I got that part now.  incoming dialed-number .
You have couple of choices here:
1. send all 10 digits to CUCM and let CUCM either translate those to internal extensions, or use sigDigits parameter on the GW to strip digits.
2. Use translation rule on GW to massge the digits final extension and then send to CUCM via dial peer.
Which method would you like to use?
HTH, please rate all useful posts!
Chris
