PRI Monitoring tool ?
Koushal Pandit
Hi All,
  I have urgent requirement of any tool or techneque so that i can monitor the PRI status in terms of and calls and details contineousley.
Thanks in advance.
acampbell
You can use a syslog server ( there are plenty free -on internet) and with a couple of lines of config on the router
you will receive the info you want
http://www.cisco.com/en/US/tech/tk1077/technologies_tech_note09186a0080094e72.shtml
Alex
Regards, Alex. Please rate useful posts.
Gordon Ross
Level 9
Level 9
"debug isdn q931" & "debug isdn q921" ?
Or do you want a real ISDN tester which will show what is really on the wire, rather than what IOS claims to be on the wire ?
Please rate all helpful posts.
