pri to sip
FG10
Should i be considering any extra or hidden cube licencing costs for
migrating to a 161 channel sip circuit from an existing PRI in terms of my
gateways?
thanks
Jaime Valencia
Not really, if it's only one CUBE then buy the necessary session licenses for the amount of calls you need, if you plan to have HA, then buy the CUBE HA licenses you need for both ISRs.
If you will use SRTP/TLS then also get the security license in case you don't have it.
I'm assuming you already properly sized your platform supports the amount of calls and CPS you need.
java
if this helps, please rate
