05-09-2016 08:59 AM - edited 03-18-2019 11:59 AM
Hello
I have installed and configured cisco unified communication manager v11.
I have configured BLF in cisco ip phones 7861 but it is not working .
Can you help me please
Best regards
05-09-2016 10:14 AM
And what troubleshooting have you done so far??
05-12-2016 11:55 AM
05-13-2016 01:46 AM
Check below things
1- If the IP Phone is getting an IP address or not, if it is getting one is it ping-able
2- Check the if the MAC Address and device type in the e-phone config are correct.
3- If above two points are fine, try to reconfigure the ephone config and see that works.
As per the config on router it seems to be fine. Try these steps and see if it helps. Also as Adarsh advised to check the status messages on the phone that might also give you some lead.
Abhay Reyal
05-13-2016 03:44 AM
Thanks for you answer
The IP phones do not give any IP address.
TIP phones has been working very well before
Thank you
05-13-2016 07:16 AM
That is where the issue lies then. Check if the Phones are in correct VLAN. Phones should have an IP Address so as to process the registration request.
Abhay Reyal
05-15-2016 03:33 AM
Thanks for your answer
The ip phones not gave me any information for vlan and ip address .
Best regards
05-15-2016 06:18 AM
Give it a manual IP Address and rest of the configuration too. For Ex:- Subnet, TFTP etc. It should get register. Right now at the moment you phone is not getting the IP address and mentioned earlier your phone should have an IP address for registration purpose.
Abhay Reyal
05-10-2016 04:27 PM
Please check the status messages of the phone to start off your troubleshooting.
It might give you some hint.
Adarsh Chauhan
05-12-2016 11:58 AM
05-12-2016 08:35 PM
The basic configuration looks fine to me for a sccp phone to register.
As I said, I would suggest you to check the status messages on phone to figure out what exactly is happening in the background.
Adarsh Chauhan
05-13-2016 03:45 AM
The IP phones has been working very well before
Thank you
05-13-2016 03:48 AM
sh ephone summary
hairpin_block:
ephone-1[0] Mac:580A.2098.1DFC TCP socket:[-1] activeLine:0 whisperLine:0 UNREGISTERED
mediaActive:0 whisper_mediaActive:0 startMedia:0 offhook:0 ringing:0 reset:0 reset_sent:0 debug:0 primary_dn: 1*
IP:0.0.0.0* Unknown 0 keepalive 0 music 0
ephone-2[1] Mac:5017.FF76.7E1A TCP socket:[-1] activeLine:0 whisperLine:0 UNREGISTERED
mediaActive:0 whisper_mediaActive:0 startMedia:0 offhook:0 ringing:0 reset:0 reset_sent:0 debug:0 primary_dn: 2*
ephone-3[2] Mac:5017.FF76.7E9E TCP socket:[-1] activeLine:0 whisperLine:0 UNREGISTERED
mediaActive:0 whisper_mediaActive:0 startMedia:0 offhook:0 ringing:0 reset:0 reset_sent:0 debug:0 primary_dn: 3*
ephone-4[3] Mac:5017.FF76.7E4A TCP socket:[-1] activeLine:0 whisperLine:0 UNREGISTERED
mediaActive:0 whisper_mediaActive:0 startMedia:0 offhook:0 ringing:0 reset:0 reset_sent:0 debug:0 primary_dn: 4*
ephone-5[4] Mac:5017.FF76.7E05 TCP socket:[-1] activeLine:0 whisperLine:0 UNREGISTERED
mediaActive:0 whisper_mediaActive:0 startMedia:0 offhook:0 ringing:0 reset:0 reset_sent:0 debug:0 primary_dn: 5*
ephone-6[5] Mac:5017.FF76.7EC8 TCP socket:[-1] activeLine:0 whisperLine:0 UNREGISTERED
mediaActive:0 whisper_mediaActive:0 startMedia:0 offhook:0 ringing:0 reset:0 reset_sent:0 debug:0 primary_dn: 6*
ephone-7[6] Mac:5017.FF76.7E2A TCP socket:[-1] activeLine:0 whisperLine:0 UNREGISTERED
mediaActive:0 whisper_mediaActive:0 startMedia:0 offhook:0 ringing:0 reset:0 reset_sent:0 debug:0 primary_dn: 7*
