05-23-2012 07:40 AM - last edited on 03-25-2019 08:15 PM by ciscomoderator
We have CUCM version 7.1.3.33026 on MCS server we want to migrate to 8.5 on UCS
But we don't have the 7.1.3.33026 CD so we can't install it again and restore also we can't upgrade the MCS to 8.5 directly as we have UCCX 7.0.1 which is not compatible with CUCM 8.5
So please advise
05-23-2012 07:55 AM
You may be able to upgrade the existing MCS server to 8.5 for in an upgrade only version. This won't function but will let you backup the server (version 8.5) to restore on the new UCS.
You'll have to upgrade UCCX along with CUCM in either scenario.
05-23-2012 08:18 AM
I just dont want to upgrade UCCX till iam done with the CUCM on the UCS as i will replace the MCS
so if there any solution that will not affect the UCCX please let me khnow
another question , is it possible to upgrade the publisher only to version 8.5 and take the backup then revert to version 7.1.3 through version switch option ?
Message was edited by: ATIF TANVEER
05-23-2012 07:55 AM
I see couple of options:
1. See if you can get the 7.1 DVD from your cisco account team or TAC
2. Upgrade to 8.0 or 8.5 if supported on current hardware along with upgrading CCX to 8.X.
HTH,
Chris
05-23-2012 08:38 AM
