05-24-2008 12:41 AM - edited 03-15-2019 10:51 AM
Hii all,
I am working with CCM 5.1. I registered a IP Communicator (Soft Phone). When I am trying to communicate with that Soft phone its ringing . and connected with caller but no voice is coming...
any body know , wth is the problem?
plz help me
Thanks & Regards
Madhab
05-24-2008 02:59 PM
Hi Madhab,
I am working with CCM 5.1 but I don't have this problem. Do you can be more specific, maybe the problem not is de IP Communicator. The problem occur with another IP Phone?
05-24-2008 03:41 PM
sounds like a routing issue, check that you have all the proper routing for the RTP to be routed from IP Phone to IPC
also check codecs just in case
javalenc
if this helps, please rate
