Problem in using Cisco 2811 router as fxo-gateway
ronin
Hi all
I have a cisco 2811 router with pvdm2-32 and vwic2- 4FX0 and IOS version of Router is 15.01
when I use this router as a fxo gateway :
  in outgoing calls , the Co line is occupying but no connection to called number  is happening ,
  just some noise but the line is busy so that no one can call this isdn number from outside
  and when a incoming call comes from outside, nothing happens (debug on router shows nothing )
But when I use Grandstream FXO-gateway instead of cisco router , there is no problem and outgoing calls works very well
  I got these information from the recorded voice call (which is dialed with Grandstream as FXo gateway)
  Busy tone = 425
  on time frequency = 500
  off time frequency = 500
would you please help me to fix this probably with changing my router configration?
This is my config on 2811 :
trunk group 1
max-calls voice 4
hunt-scheme round-robin
voice class dualtone-detect-params 1
freq-max-deviation 15
cadence-variation 8
voice class custom-cptone IR
dualtone busy
frequency 425
cadence 500 500
dualtone ringback
frequency 425 425
cadence 1000 4000
dualtone disconnect
frequency 425
cadence 500 498 499 501 503 497 496
voice-port 0/0/0
trunk-group 1
supervisory custom-cptone IR
supervisory dualtone-detect-params 1
timeouts initial 5
timeouts interdigit 3
timeouts call-disconnect 3
timeouts ringing 5
timeouts wait-release 5
timing hookflash-out 50
timing guard-out 1000
connection plar 599
description FXO1
dial-peer voice 100 pots
trunkgroup 1
destination-pattern [1-9]T
forward-digits all
Jaderson Pessoa
I hope that it can help you: https://community.cisco.com/t5/ip-telephony-and-phones/mgcp-fxo-gateway-on-2811-router/td-p/3002183
Jaderson Pessoa
*** Rate All Helpful Responses ***
