09-10-2015 02:58 PM - edited 03-17-2019 04:16 AM
09-10-2015 06:19 PM
Hi Marco,
What type of problem do you have? This might be a hardware issue, does this happen with more than 2 phones? If you think this is a hardware problem you might need to open a TAC case for an RMA.
Tere.
09-11-2015 12:31 AM
Hi Tere,
if it is outside maintenance of Cisco? A colleague of mine opened in IP phone looks like it defective the contact is not There Any Way of fix this and it lasts for a while?
Thanks for your interest.
Greetings,
Marco.
09-12-2015 07:05 AM
Hi Marco,
I just wanted to add a note to the good info from Tere (+5 "T").
This is a very common problem that has plagued these models of IP phones for years. Here is a an old thread with some more recent comments that discuss the repair/replacement of many of the "hookswitch" parts that cause these issues;
https://supportforums.cisco.com/discussion/10857716/7961-onoff-hook-issue
The parts are available for a fairly reasonable cost @ many suppliers. Here's one example that I found with a quick Google search;
http://www.buytelephoneparts.com/cisco/
If you search YouTube you will even find some step-by-step videos.
Cheers!
Rob
09-28-2015 04:30 AM
09-28-2015 02:03 PM
More over, there are so many eBay based resellers selling 7900s that, it may in fact be easier and cheaper to replace the phones than the individual switch.
