Problem to place calls
Martin Bauer
Hello everyone, I come humbly ask some help to solve my problem.
I'm having troubles to places calls from CUCM using the router 2811 as gateway. When the call is made and the router 2821 is used no problem is related. This issue seems to happen only with IP Communicator calls, because when the call is originate by a ATA 186 (192.168.1.253 or .251) the call is complete normally.
No problems are related when placing calls from 192.168.0.X using router 2821 as gateway (but no IPComm on the side 192.168.0.X exists).
The network topology is the following:
Here is a debug of the call, if someone could help. Thanks very much.
019615: *Feb 21 14:42:51.960: TCB47FB4454 setting property TCP_TOS (11) 48555EE0
019616: *Feb 21 14:42:52.204: TCP0: ACK timeout timer expired
R2811_MF_RS#
019617: *Feb 21 14:42:53.108: //-1/xxxxxxxxxxxx/CCAPI/ccAppShutdownMode:
   ccAppShutdownMode: remove it from the queue
R2811_MF_RS#
019618: *Feb 21 14:42:55.440: TCB4851BB9C created
019619: *Feb 21 14:42:55.440: Reserved port 1720 in Transport Port Agent for TCP IP type 1
019620: *Feb 21 14:42:55.440: TCP0: state was LISTEN -> SYNRCVD [1720 -> 192.168.1.207(34297)]
019621: *Feb 21 14:42:55.440: TCP: tcb 4851BB9C connection to 192.168.1.207:34297, peer MSS 1460, MSS is 516
019622: *Feb 21 14:42:55.440: TCP: sending SYN, seq 1635138926, ack 972178556
019623: *Feb 21 14:42:55.440: TCP0: Connection to 192.168.1.207:34297, advertising MSS 1060
019624: *Feb 21 14:42:55.480: TCP0: state was SYNRCVD -> ESTAB [1720 -> 192.168.1.207(34297)]
019625: *Feb 21 14:42:55.480: //-1/xxxxxxxxxxxx/H323/cch323_ct_main: SOCK 0 Event 0x1
019626: *Feb 21 14:42:55.480: TCB4830C88C accepting 4851BB9C from 192.168.1.207.34297
019627: *Feb 21 14:42:55.480: TCB4851BB9C setting property TCP_PID (8) 4733BAB4
019628: *Feb 21 14:42:55.480: TCB4851BB9C setting property TCP_NO_DELAY (1) 4733BAB8
019629: *Feb 21 14:42:55.480: TCB4851BB9C setting property TCP keepalive timeout (17) 4733BB3C
019630: *Feb 21 14:42:55.484: TCB4851BB9C setting property TCP_NO_DELAY (1) 4733BB14
019631: *Feb 21 14:42:55.484: TCB4851BB9C setting property TCP_ALWAYSPUSH (15) 4733BB14
019632: *Feb 21 14:42:55.484: //-1/xxxxxxxxxxxx/H323/cch323_get_new_ccb: ccb (0x4603A824) is in use
019633: *Feb 21 14:42:55.492: //-1/xxxxxxxxxxxx/H323/cch323_ct_main: SOCK 2 Event 0x1
019634: *Feb 21 14:42:55.492: //-1/xxxxxxxxxxxx/H323/cch323_gw_process_read_socket: owner_data=0x484D9450, len=219, msgPtr=0x47E07E70
019635: *Feb 21 14:42:55.492: //-1/xxxxxxxxxxxx/H323/cch323_gw_process_read_socket: Received msg for H.225
019636: *Feb 21 14:42:55.492: H225.0 INCOMING ENCODE BUFFER::= 20B0060008914A000501401F0041006E00610020005000610075006C00610000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000022C0B50000120F436973636F43616C6C4D616E616765720031000104003CA494565000F08B33C92D6112E80FD301C0A8017300D50D80000700C0A801CF06B8110000F08B33C92D6112E80FD301C0A80173010001000100010010A001000F0140B50000120880A4000400010200
019637: *Feb 21 14:42:55.492:
019638: *Feb 21 14:42:55.492: H225.0 INCOMING PDU ::=
value H323_UserInformation ::=
      h323-uu-pdu
        h323-message-body setup :
          protocolIdentifier { 0 0 8 2250 0 5 }
          sourceAddress
            h323-ID : {"Ana Paula..."}
          sourceInfo
            vendor
              vendor
                t35CountryCode 181
                t35Extension 0
                manufacturerCode 18
              productId '436973636F43616C6C4D616E61676572'H
              versionId '31'H
            terminal
            mc FALSE
            undefinedNode FALSE
          destinationAddress
            dialedDigits : "097161232"
          activeMC FALSE
          conferenceID '00F08B33C92D6112E80FD301C0A80173'H
          conferenceGoal create : NULL
          callType pointToPoint : NULL
          sourceCallSignalAddress ipAddress :
            ip 'C0A801CF'H
            port 1720
          callIdentifier
            guid '00F08B33C92D6112E80FD301C0A80173'H
          mediaWaitForConnect FALSE
          canOverlapSend FALSE
          multipleCalls FALSE
          maintainConnection FALSE
        h245Tunneling FALSE
        nonStandardControl
            nonStandardIdentifier h221NonStandard :
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
            data '80A4000400010200'H
019639: *Feb 21 14:42:55.500: H225 NONSTD INCOMING ENCODE BUFFER::= 80A4000400010200
019640: *Feb 21 14:42:55.500:
019641: *Feb 21 14:42:55.500: H225 NONSTD INCOMING PDU ::=
value H323_UU_NonStdInfo ::=
      callMgrParam
        interclusterVersion 2
        enterpriseID {}
019642: *Feb 21 14:42:55.500: //-1/xxxxxxxxxxxx/H323/cch323_h225_receiver: Received msg of type SETUPIND_CHOSEN
019643: *Feb 21 14:42:55.500: //-1/xxxxxxxxxxxx/H323/setup_ind: Entry
019644: *Feb 21 14:42:55.500: //26747/00F08B33E80F/H323/setup_ind: callingNumber[6028] calledNumber[097161232]
019645: *Feb 21 14:42:55.500: //26747/00F08B33E80F/H323/setup_ind: ---- calling IE present
019646: *Feb 21 14:42:55.500: //26747/00F08B33E80F/H323/setup_ind: ====== PI = 0
019647: *Feb 21 14:42:55.500: //26747/00F08B33E80F/H323/setup_ind: Receive: infoXCap 0
019648: *Feb 21 14:42:55.500: //26747/00F08B33E80F/H323/setup_ind: Receive: infoXCap ccb 0
019649: *Feb 21 14:42:55.500: //26747/00F08B33E80F/H323/setup_ind: Receive bearer cap infoXRate 16, rateMult 0
019650: *Feb 21 14:42:55.500: //-1/xxxxxxxxxxxx/H323/cch323_extract_signaled_carriers: Entry
019651: *Feb 21 14:42:55.500: //26747/00F08B33E80F/H323/cch323_determine_source_ip_group_info: No Source IP group match with Src CarrierId/Zone ID
019652: *Feb 21 14:42:55.500: //26747/00F08B33E80F/H323/cch323_determine_source_ip_group_info: No Source IP group matched with rte id/zone_id/acl
019653: *Feb 21 14:42:55.504: //-1/xxxxxxxxxxxx/H323/cch323_determine_source_group: Entry
019654: *Feb 21 14:42:55.504: //26747/00F08B33E80F/H323/cch323_determine_source_ip_group_info: No Source IP group match with Incoming Called Number
019655: *Feb 21 14:42:55.504: //-1/xxxxxxxxxxxx/H323/cch323_determine_source_group: Entry
019656: *Feb 21 14:42:55.504: //26747/00F08B33E80F/H323/cch323_determine_source_ip_group_info: No Source IP group match with Destination pattern
019657: *Feb 21 14:42:55.504: //26747/00F08B33E80F/H323/setup_ind:
setup_ind: is_overlap = 0, info_complete = 0
019658: *Feb 21 14:42:55.504: //-1/xxxxxxxxxxxx/H323/cch323_is_preauth_reqd: FALSE
019659: *Feb 21 14:42:55.504: //26747/00F08B33E80F/H323/setup_ind: Call Manager detected
019660: *Feb 21 14:42:55.504: //26747/00F08B33E80F/H323/cch323_h225_receiver: SETUPIND_CHOSEN: src address = 192.168.0.250; dest address = 192.168.1.207
019661: *Feb 21 14:42:55.504: //26747/00F08B33E80F/H323/run_h225_sm: Received event H225_EV_SETUP_IND while at state H225_IDLE
019662: *Feb 21 14:42:55.504: //-1/xxxxxxxxxxxx/H323/cch323_associate_incoming_peer: timeout = 1, reason = 0
019663: *Feb 21 14:42:55.504: //26747/00F08B33E80F/H323/common_idle_setupInd_hdlr: full match is found
019664: *Feb 21 14:42:55.504: //26747/00F08B33E80F/H323/cch323_set_preferred_codec: Using Voice Class Codec, tag = 1
019665: *Feb 21 14:42:55.504: //26747/00F08B33E80F/H323/cch323_set_peer: peer: 484FCAFC, peer->voice_peer_tag: E7EF1, ccb: 4603A824
019666: *Feb 21 14:42:55.504: //26747/00F08B33E80F/H323/cch323_set_peer: ccb h245addr bits = system[0x0007]
019667: *Feb 21 14:42:55.504: //26747/00F08B33E80F/H323/cch323_set_peer: ccb ccm bits = system[0x0028]
019668: *Feb 21 14:42:55.504: //26747/00F08B33E80F/H323/cch323_h225_set_new_state: Changing from H225_IDLE state to H225_SETUP state
019669: *Feb 21 14:42:55.504: TCB4851BB9C setting property TCP_TOS (11) 4733B8EC
019670: *Feb 21 14:42:55.504: //26747/00F08B33E80F/H323/cch323_set_h245_state_mc_mode_incoming: h245 state m/c mode=0x10F, h323_ctl=0x2F
019671: *Feb 21 14:42:55.504: //-1/xxxxxxxxxxxx/H323/cch323_associate_incoming_peer: timeout = 1, reason = 0
019672: *Feb 21 14:42:55.504: //26747/00F08B33E80F/H323/cch323_create_incoming_callinfo_block: peer 45856664, voice_peer_tag 950001, ccb: 4603A824
019673: *Feb 21 14:42:55.504: //26747/00F08B33E80F/H323/cch323_create_incoming_callinfo_block: Calling Party is CCM
019674: *Feb 21 14:42:55.504: //26747/00F08B33E80F/H323/h323_gw_setup_ind: is_overlap = 0, info_complete = 0
019675: *Feb 21 14:42:55.504: //-1/00F08B33E80F/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=Ana Paula
   ----- ccCallInfo IE subfields -----
   cisco-ani=6028
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=097161232
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
019676: *Feb 21 14:42:55.508: //-1/00F08B33E80F/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x47158B60, Call Info(
   Calling Number=6028,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=097161232(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=950001, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=26747
019677: *Feb 21 14:42:55.508: //-1/00F08B33E80F/CCAPI/ccCheckClipClir:
   In: Calling Number=6028(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
019678: *Feb 21 14:42:55.508: //-1/00F08B33E80F/CCAPI/ccCheckClipClir:
   Out: Calling Number=6028(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
019679: *Feb 21 14:42:55.508: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
019680: *Feb 21 14:42:55.508: :cc_get_feature_vsa malloc success
019681: *Feb 21 14:42:55.508: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
019682: *Feb 21 14:42:55.508:  cc_get_feature_vsa count is 1
019683: *Feb 21 14:42:55.508: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
019684: *Feb 21 14:42:55.508: :FEATURE_VSA attributes are: feature_name:0,feature_time:1185185696,feature_id:26747
019685: *Feb 21 14:42:55.508: //26747/00F08B33E80F/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=6028(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=097161232(TON=Unknown, NPI=Unknown))
019686: *Feb 21 14:42:55.508: //26747/00F08B33E80F/H323/cch323_h225_handle_deferred_ind: UnBuffering deferred indications
019687: *Feb 21 14:42:55.508: //-1/xxxxxxxxxxxx/H323/cch323_create_call_info_type_container:
cch323_create_call_info_type_container: creating callInfoType container for callID = 26747
019688: *Feb 21 14:42:55.508: //26747/00F08B33E80F/H323/cch323_update_call_info_from_dial_peer: Playout Mode: 1,Init 60, Min 40, Max 250, Fax 300
019689: *Feb 21 14:42:55.508: //26747/00F08B33E80F/H323/cch323_update_carriers_in_call_info: tg_label_flag 0x0
019690: *Feb 21 14:42:55.508: //26747/00F08B33E80F/CCAPI/cc_process_call_setup_ind:
   Event=0x472CC070
019691: *Feb 21 14:42:55.512: //26747/00F08B33E80F/CCAPI/ccCallSetContext:
   Context=0x45FEBAE8
019692: *Feb 21 14:42:55.512: //26747/00F08B33E80F/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 26747 with tag 950001 to app "_ManagedAppProcess_Default"
019693: *Feb 21 14:42:55.516: //26747/00F08B33E80F/CCAPI/ccCallProceeding:
   Progress In
R2811_MF_RS#dication=NULL(0)
019694: *Feb 21 14:42:55.520: //26747/00F08B33E80F/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=900, Params=0x45FF85C8, Progress Indication=NULL(0)
019695: *Feb 21 14:42:55.520: //26747/00F08B33E80F/CCAPI/ccCheckClipClir:
019696: *Feb 21 14:42:55.520: //26747/00F08B33E80F/CCAPI/ccCheckClipClir:
019697: *Feb 21 14:42:55.520: //26747/00F08B33E80F/CCAPI/ccCallSetupRequest:
   Destination Pattern=0[7-9]T, Called Number=097161232, Digit Strip=TRUE
019698: *Feb 21 14:42:55.520: //26747/00F08B33E80F/CCAPI/ccCallSetupRequest:
   Redirect Number=, Display Info=
   Account Number=Ana Paula, Final Destination Flag=TRUE,
   Guid=00F08B33-C92D-6112-E80F-D301C0A80173, Outgoing Dial-peer=900
019699: *Feb 21 14:42:55.520: //26747/00F08B33E80F/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-ani=6028
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=097161232
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
019700: *Feb 21 14:42:55.524: //26747/00F08B33E80F/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x46A6ADA0, Interface Type=6, Destination=, Mode=0x0,
   Call Params(Calling Number=6028,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=097161232(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=900, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
019701: *Feb 21 14:42:55.524: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
019702: *Feb 21 14:42:55.524: :cc_get_feature_vsa malloc success
019703: *Feb 21 14:42:55.524: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
019704: *Feb 21 14:42:55.524:  cc_get_feature_vsa count is 2
019705: *Feb 21 14:42:55.524: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
019706: *Feb 21 14:42:55.524: :FEATURE_VSA attributes are: feature_name:0,feature_time:1185182888,feature_id:26748
019707: *Feb 21 14:42:55.524: //-1/xxxxxxxxxxxx/H323/cch245_event_handler: callID=26747
019708: *Feb 21 14:42:55.524: //-1/xxxxxxxxxxxx/H323/cch245_event_handler: Event CC_EV_H245_SET_MODE: data ptr=0x498424A0
019709: *Feb 21 14:42:55.524: //-1/xxxxxxxxxxxx/H323/cch323_set_mode: callID=26747, flow Mode=1 spi_mode=0x6
019710: *Feb 21 14:42:55.524: //26748/00F08B33E80F/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
019711: *Feb 21 14:42:55.524: //26748/00F08B33E80F/CCAPI/ccCallSetContext:
   Context=0x45FF8578
019712: *Feb 21 14:42:55.524: //26747/00F08B33E80F/CCAPI/ccSaveDialpeerTag:
019713: *Feb 21 14:42:55.524: //26747/00F08B33E80F/H323/cch323_do_set_dialpeer_tag: gw_id=1
019714: *Feb 21 14:42:55.524: //26747/00F08B33E80F/H323/cch323_do_call_proceeding: gw_id=1
019715: *Feb 21 14:42:55.524: //26747/00F08B33E80F/H323/cch323_do_call_proceeding: set_mode NOT called yet...saved deferred CALL_PROC
019716: *Feb 21 14:42:55.524: //26747/00F08B33E80F/H323/cch323_send_event_to_h245_connection_sm: Changing to new event H245_LISTEN_REQ_EVENT
019717: *Feb 21 14:42:55.528: //26747/00F08B33E80F/H323/cch323_h245_connection_sm: state=0, event=0, ccb=4603A824, listen state=0
019718: *Feb 21 14:42:55.528: //26747/00F08B33E80F/H323/cch323_h245_connection_sm: H245_LISTEN: Received event H245_LISTEN_REQ_EVENT while at H245_NONE state
019719: *Feb 21 14:42:55.528: TCB48050EC4 created
019720: *Feb 21 14:42:55.528: TCB48050EC4 setting property TCP_PID (8) 4733BABC
019721: *Feb 21 14:42:55.528: TCB48050EC4 setting property TCP_NO_DELAY (1) 4733BAC0
019722: *Feb 21 14:42:55.528: TCB48050EC4 setting property TCP_NONBLOCKING_WRITE (10) 4733BB40
019723: *Feb 21 14:42:55.528: TCB48050EC4 setting property TCP_NONBLOCKING_READ (14) 4733BB40
019724: *Feb 21 14:42:55.528: TCB48050EC4 setting property TCP_REUSEADDR (13) 4733BB44
019725: *Feb 21 14:42:55.528: TCB48050EC4 setting property TCP_VRFTABLEID (20) 4733BB6C
019726: *Feb 21 14:42:55.528: TCP: Random local port generated 45122, network 1
019727: *Feb 21 14:42:55.528: TCB48050EC4 bound to UNKNOWN.45122
019728: *Feb 21 14:42:55.528: Reserved port 45122 in Transport Port Agent for TCP IP type 0
019729: *Feb 21 14:42:55.528: TCB48050EC4 listening with queue 32
019730: *Feb 21 14:42:55.528: TCB48050EC4 setting property TCP_ACCESS_CHECK (6) 41385888
019731: *Feb 21 14:42:55.528: //26747/00F08B33E80F/H323/cch323_h245_set_new_state: Changing from H245_NONE state to H245_WAITING state
019732: *Feb 21 14:42:55.528: //26747/00F08B33E80F/H323/cch323_process_set_mode: Setting inbound leg mode flags to 0x10F, flow-mode to FLOW_THROUGH
019733: *Feb 21 14:42:55.528: //26747/00F08B33E80F/H323/cch323_process_set_mode: Sending deferred CALL_PROC
019734: *Feb 21 14:42:55.528: //26747/00F08B33E80F/H323/cch323_do_call_proceeding: gw_id=1
019735: *Feb 21 14:42:55.528: //26747/00F08B33E80F/H323/cch323_do_call_proceeding: set_mode called so we can proceed with CALLPROC
019736: *Feb 21 14:42:55.528: //26747/00F08B33E80F/H323/run_h225_sm: Received event H225_EV_CALLPROC while at state H225_SETUP
019737: *Feb 21 14:42:55.528: //26747/00F08B33E80F/H323/cch323_h225_set_new_state: Changing from H225_SETUP state to H225_CALLPROC state
019738: *Feb 21 14:42:55.528: //26747/00F08B33E80F/H323/delay_h245_transport_address: CCM-ITS compatibility delay transport address for callid[687B]
019739: *Feb 21 14:42:55.528: //26747/00F08B33E80F/H323/generic_send_callproc: ====== PI = 0
019740: *Feb 21 14:42:55.528: H225.0 OUTGOING PDU ::=
      h323-uu-pdu
        h323-message-body callProceeding :
          protocolIdentifier { 0 0 8 2250 0 4 }
          destinationInfo
            vendor
              vendor
                t35CountryCode 181
                t35Extension 0
                manufacturerCode 18
            gateway
              protocol
                voice :
                  supportedPrefixes
            mc FALSE
            undefinedNode FALSE
          h245Address ipAddress :
            ip 'C0A800FA'H
            port 45122
          callIdentifier
          multipleCalls FALSE
        h245Tunneling FALSE
019741: *Feb 21 14:42:55.536: H225.0 OUTGOING ENCODE BUFFER::= 21C0060008914A00042800B500001240013C05010000C0A800FAB042110C110000F08B33C92D6112E80FD301C0A801730100010010800100
019742: *Feb 21 14:42:55.536:
019743: *Feb 21 14:42:55.540: //26748/00F08B33E80F/CCAPI/cc_api_call_proceeding:
   Interface=0x46A6ADA0, Progress Indication=NULL(0)
019744: *Feb 21 14:42:56.792: //26748/00F08B33E80F/CCAPI/cc_api_call_disconnected:
   Cause Value=34, Interface=0x46A6ADA0, Call Id=26748
019745: *Feb 21 14:42:56.792: //26748/00F08B33E80F/CCAPI/cc_api_call_disconnected:
   Call Entry(Responsed=TRUE, Cause Value=34, Retry Count=0)
019746: *Feb 21 14:42:56.792: //26747/xxxxxxxxxxxx/CCAPI/ccCallReleaseResources:
   release reserved xcoding resource.
019747: *Feb 21 14:42:56.792: //26748/00F08B33E80F/CCAPI/ccCallSetAAA_Accounting:
   Accounting=1, Call Id=26748
019748: *Feb 21 14:42:56.792: //26748/00F08B33E80F/CCAPI/ccCallDisconnect:
   Cause Value=34, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=34)
019749: *Feb 21 14:42:56.792: //26748/00F08B33E80F/CCAPI/ccCallDisconnect:
   Cause Value=34, Call Entry(Responsed=TRUE, Cause Value=34)
019750: *Feb 21 14:42:56.800: //26748/00F08B33E80F/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x46A6ADA0, Tag=0x0, Call Id=26748,
   Call Entry(Disconnect Cause=34, Voice Class Cause Code=0, Retry Count=0)
019751: *Feb 21 14:42:56.800: //26748/00F08B33E80F/CCAPI/cc_api_call_disconnect_done:
   Call Disconnect Event Sent
019752: *Feb 21 14:42:56.800: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
019753: *Feb 21 14:42:56.800: :cc_free_feature_vsa freeing 46A474A0
019754: *Feb 21 14:42:56.800: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
019755: *Feb 21 14:42:56.800:  vsacount in free is 1
019756: *Feb 21 14:42:56.800: //26747/00F08B33E80F/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=901, Params=0x45FF0390, Progress Indication=NULL(0)
019757: *Feb 21 14:42:56.800: //26747/00F08B33E80F/CCAPI/ccCheckClipClir:
019758: *Feb 21 14:42:56.800: //26747/00F08B33E80F/CCAPI/ccCheckClipClir:
019759: *Feb 21 14:42:56.800: //26747/00F08B33E80F/CCAPI/ccCallSetupRequest:
019760: *Feb 21 14:42:56.804: //26747/00F08B33E80F/CCAPI/ccCallSetupRequest:
   Guid=00F08B33-C92D-6112-E80F-D301C0A80173, Outgoing Dial-peer=901
019761: *Feb 21 14:42:56.804: //26747/00F08B33E80F/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-ani=6028
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=097161232
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
019762: *Feb 21 14:42:56.804: //26747/00F08B33E80F/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x472DC084, Interface Type=6, Destination=, Mode=0x0,
R2811_MF_RS#(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=901, Call Count On=FALSE,
019763: *Feb 21 14:42:56.804: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
019764: *Feb 21 14:42:56.804: :cc_get_feature_vsa malloc success
019765: *Feb 21 14:42:56.804: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
019766: *Feb 21 14:42:56.804:  cc_get_feature_vsa count is 2
019767: *Feb 21 14:42:56.804: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
019768: *Feb 21 14:42:56.804: :FEATURE_VSA attributes are: feature_name:0,feature_time:1185182888,feature_id:26749
019769: *Feb 21 14:42:56.804: //-1/xxxxxxxxxxxx/H323/cch245_event_handler: callID=26747
019770: *Feb 21 14:42:56.804: //-1/xxxxxxxxxxxx/H323/cch245_event_handler: Event CC_EV_H245_SET_MODE: data ptr=0x498428C0
019771: *Feb 21 14:42:56.804: //-1/xxxxxxxxxxxx/H323/cch323_set_mode: callID=26747, flow Mode=1 spi_mode=0x6
019772: *Feb 21 14:42:56.804: //26749/00F08B33E80F/CCAPI/ccIFCallSetupRequestPrivate:
019773: *Feb 21 14:42:56.804: //26749/00F08B33E80F/CCAPI/ccCallSetContext:
   Context=0x45FF0340
019774: *Feb 21 14:42:56.804: //26747/00F08B33E80F/CCAPI/ccSaveDialpeerTag:
019775: *Feb 21 14:42:56.804: //26747/00F08B33E80F/H323/cch323_do_set_dialpeer_tag: gw_id=1
019776: *Feb 21 14:42:56.812: //26749/00F08B33E80F/CCAPI/cc_api_call_proceeding:
   Interface=0x472DC084, Progress Indication=NULL(0)
R2811_MF_RS#
019777: *Feb 21 14:43:00.024: //26749/00F08B33E80F/CCAPI/cc_api_call_alert:
   Interface=0x472DC084, Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1)
019778: *Feb 21 14:43:00.028: //26749/00F08B33E80F/CCAPI/cc_api_call_alert:
   Call Entry(Retry Count=0, Responsed=TRUE)
019779: *Feb 21 14:43:00.028: //26747/00F08B33E80F/CCAPI/ccCallAlert:
019780: *Feb 21 14:43:00.028: //26747/00F08B33E80F/CCAPI/ccCallAlert:
   Call Entry(Responsed=TRUE, AlertSent=TRUE)
019781: *Feb 21 14:43:00.028: //26749/00F08B33E80F/CCAPI/cc_api_get_called_ccm_detected:
   CallInfo(ccm detected=0)
019782: *Feb 21 14:43:00.028: //26747/00F08B33E80F/CCAPI/ccCallNotify:
   Data Bitmask=0x7, Call Id=26747
019783: *Feb 21 14:43:00.028: //26749/00F08B33E80F/CCAPI/cc_api_get_called_ccm_detected:
019784: *Feb 21 14:43:00.028: //-1/xxxxxxxxxxxx/H323/cch323_post_call_service_msg: callID=26747, notify data mask=0x00000007
019785: *Feb 21 14:43:00.028: //26747/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x46039B2C, callID1=0x687B, callID2=0x687D, tag=0x0)
019786: *Feb 21 14:43:00.028: //26747/00F08B33E80F/CCAPI/ccConferenceCreate:
   Conference Id=0x46039B2C, Call Id1=26747, Call Id2=26749, Tag=0x0
019787: *Feb 21 14:43:00.028: //26747/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
019788: *Feb 21 14:43:00.028: cc_api_get_xcode_stream : 4369
019789: *Feb 21 14:43:00.028: //26747/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x2FD2, Source Interface=0x47158B60, Source Call Id=26747,
   Destination Call Id=26749, Disposition=0x0, Tag=0x0
019790: *Feb 21 14:43:00.032: //26749/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x2FD2, Source Interface=0x472DC084, Source Call Id=26749,
   Destination Call Id=26747, Disposition=0x0, Tag=0xFFFFFFFF
019791: *Feb 21 14:43:00.032: //26747/00F08B33E80F/CCAPI/cc_generic_bridge_done:
019792: *Feb 21 14:43:00.032: //26747/00F08B33E80F/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x2FD2, Destination Call Id=26749)
019793: *Feb 21 14:43:00.032: //26749/00F08B33E80F/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x2FD2, Destination Call Id=26747)
019794: *Feb 21 14:43:00.032: //26749/00F08B33E80F/CCAPI/cc_api_caps_ind:
   Destination Interface=0x47158B60, Destination Call Id=26747, Source Call Id=26749,
   Caps(Codec=0x1, Fax Rate=0x1, Vad=0x1,
   Modem=0x2, Codec Bytes=20, Signal Type=3)
019795: *Feb 21 14:43:00.032: //26749/00F08B33E80F/CCAPI/cc_api_caps_ind:
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=250(ms), Fax Nom=300(ms))
019796: *Feb 21 14:43:00.032: //-1/xxxxxxxxxxxx/H323/cch323_post_caps_ind: callID=26747, ExtendedCaps not present
019797: *Feb 21 14:43:00.032: //26747/00F08B33E80F/H323/cch323_call_alert: gw_id=1
019798: *Feb 21 14:43:00.032: //26747/00F08B33E80F/CCAPI/cc_api_get_delay_xport:
   CallInfo(delay xport=FALSE)
019799: *Feb 21 14:43:00.032: //26747/00F08B33E80F/H323/cch323_put_embedded_obj_to_ccb: ccb=0x4603A824, tag=18, size=83
019800: *Feb 21 14:43:00.032: //26747/00F08B33E80F/H323/cch323_put_embedded_obj_to_ccb: Insertion PASSED, embedded at 0x4822B0D0
019801: *Feb 21 14:43:00.032: //-1/xxxxxxxxxxxx/H323/cch323_call_alert: stored alert data display_info  in ccb
019802: *Feb 21 14:43:00.032: //-1/xxxxxxxxxxxx/H323/cch323_iev_queue_service: Dispatch 0x1 internal event to H225 SM
019803: *Feb 21 14:43:00.032: //26747/00F08B33E80F/H323/run_h225_sm: Received event H225_EV_ALERT while at state H225_CALLPROC
019804: *Feb 21 14:43:00.032: //26747/00F08B33E80F/H323/cch323_h225_set_new_state: Changing from H225_CALLPROC state to H225_ALERT state
019805: *Feb 21 14:43:00.032: //26747/00F08B33E80F/H323/delay_h245_transport_address: CCM-ITS compatibility delay transport address for callid[687B]
019806: *Feb 21 14:43:00.032: //26747/00F08B33E80F/H323/generic_send_alert: ====== PI = 8
019807: *Feb 21 14:43:00.032: //26747/00F08B33E80F/H323/cch323_get_embedded_obj_from_ccb: ccb=0x4603A824, tag=18, size=83
019808: *Feb 21 14:43:00.032: //26747/00F08B33E80F/H323/cch323_get_embedded_obj_from_ccb: Extraction PASSED from 0x4822B0D0
019809: *Feb 21 14:43:00.032: //26747/00F08B33E80F/H323/generic_send_alert: get ALERT displayInfo
019810: *Feb 21 14:43:00.036: H225.0 OUTGOING PDU ::=
      h323-uu-pdu
        h323-message-body alerting :
          destinationInfo
            vendor
              vendor
                t35CountryCode 181
                t35Extension 0
                manufacturerCode 18
            gateway
              protocol
                voice :
                  supportedPrefixes
            mc FALSE
            undefinedNode FALSE
            ip 'C0A800FA'H
            port 45122
          callIdentifier
          multipleCalls FALSE
        h245Tunneling FALSE
019811: *Feb 21 14:43:00.040: H225.0 OUTGOING ENCODE BUFFER::= 23C0060008914A00042800B500001240013C05010000C0A800FAB0421B0C00110000F08B33C92D6112E80FD301C0A801730100010010800100
019812: *Feb 21 14:43:00.040:
019813: *Feb 21 14:43:00.040: //-1/xxxxxxxxxxxx/H323/cch323_do_call_notify: gw_id=1, callID=26747, cs_data present
019814: *Feb 21 14:43:00.040: //26747/00F08B33E80F/H323/cch323_put_embedded_obj_to_ccb: ccb=0x4603A824, tag=15, size=128
019815: *Feb 21 14:43:00.040: //26747/00F08B33E80F/H323/cch323_put_embedded_obj_to_ccb: Insertion PASSED, embedded at 0x4822AE90
019816: *Feb 21 14:43:00.040: //-1/xxxxxxxxxxxx/H323/cch323_do_call_notify: stored notify_data.display_info  in ccb
019817: *Feb 21 14:43:00.040: //-1/xxxxxxxxxxxx/H323/cch323_iev_queue_service: Dispatch 0x20 internal event to H225 SM
019818: *Feb 21 14:43:00.040: //26747/00F08B33E80F/H323/run_h225_sm: Received event H225_EV_NOTIFY while at state H225_ALERT
019819: *Feb 21 14:43:00.040: //26747/00F08B33E80F/H323/send_notify_msg: Notify data found, mask=0x00000007
019820: *Feb 21 14:43:00.040: //26747/00F08B33E80F/H323/send_notify_msg: Sending NOTIFY Display Info IE =
019821: *Feb 21 14:43:00.040: //26747/00F08B33E80F/H323/send_notify_msg: Sending NOTIFY Notification Indicator IE = 113
019822: *Feb 21 14:43:00.040: //26747/00F08B33E80F/H323/send_notify_msg: Sending NOTIFY Connected Number as IE
019823: *Feb 21 14:43:00.044: //26747/00F08B33E80F/H323/send_notify_msg: [cnum]/[oct]/[oct3a] = [097161232]/[0x00]/[0x00]
019824: *Feb 21 14:43:00.044: H225.0 OUTGOING PDU ::=
      h323-uu-pdu
        h323-message-body notify :
          callIdentifier
        h245Tunneling FALSE
019825: *Feb 21 14:43:00.044: H225.0 OUTGOING ENCODE BUFFER::= 28501900060008914A00040000F08B33C92D6112E80FD301C0A8017310800100
019826: *Feb 21 14:43:00.044:
019827: *Feb 21 14:43:00.044: //26747/00F08B33E80F/H323/h323_open_rtp_stream: Media In-active notification object not attached to ccb
019828: *Feb 21 14:43:00.044: //26747/00F08B33E80F/H323/cch323_set_dtmf_iw_enabled: negotiated dtmf relay: 0, dtmf_iw_enabled: 0, dtmf_sccp_enabled: 0
019829: *Feb 21 14:43:00.044: //26747/00F08B33E80F/H323/cch323_caps_ind: gw_id=1
019830: *Feb 21 14:43:00.044: //26747/00F08B33E80F/H323/cch323_peer_caps_ind_common: Load DSP with Preferred codec(6) g711alaw, Bytes=160
019831: *Feb 21 14:43:00.044: //26747/00F08B33E80F/H323/cch323_peer_caps_ind_common: Set DSP for dtmf-relay = CC_CAP_DTMF_RELAY_INBAND_VOICE
019832: *Feb 21 14:43:00.044: //26747/00F08B33E80F/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x2FD2, Call Id1=26747, Call Id2=26749
019833: *Feb 21 14:43:00.092: //-1/xxxxxxxxxxxx/H323/cch323_ct_main: SOCK 2 Event 0x1
019834: *Feb 21 14:43:00.092: //-1/xxxxxxxxxxxx/H323/cch323_gw_process_read_socket: owner_data=0x484D9450, len=46, msgPtr=0x4838D924
019835: *Feb 21 14:43:00.092: //-1/xxxxxxxxxxxx/H323/cch323_gw_process_read_socket: Received msg for H.225
019836: *Feb 21 14:43:00.092: H225.0 INCOMING ENCODE BUFFER::= 2580060008914A00051100110000F08B33C92D6112E80FD301C0A8017310800100
019837: *Feb 21 14:43:00.096:
019838: *Feb 21 14:43:00.096: H225.0 INCOMING PDU ::=
      h323-uu-pdu
        h323-message-body releaseComplete :
          callIdentifier
        h245Tunneling FALSE
019839: *Feb 21 14:43:00.096: //-1/xxxxxxxxxxxx/H323/cch323_h225_receiver: Received msg of type RELEASEIND_CHOSEN
019840: *Feb 21 14:43:00.096: //26747/00F08B33E80F/H323/release_ind: Disconnect cause 47 location code 1
019841: *Feb 21 14:43:00.096: //-1/xxxxxxxxxxxx/H323/h323_set_release_source_for_peer: ownCallId[26747], src[2]
019842: *Feb 21 14:43:00.096: //26747/00F08B33E80F/H323/cch323_h225_receiver: RELEASEIND_CHOSEN: src address = 192.168.0.250; dest address = 192.168.1.207
019843: *Feb 21 14:43:00.096: //26747/00F08B33E80F/H323/run_h225_sm: Received event H225_EV_RELEASE_IND while at state H225_ALERT
019844: *Feb 21 14:43:00.096: //26747/00F08B33E80F/H323/cch323_traverse_enum_contact_list: State = 3
019845: *Feb 21 14:43:00.096: //26747/00F08B33E80F/CCAPI/cc_api_call_disconnected:
   Cause Value=47, Interface=0x47158B60, Call Id=26747
019846: *Feb 21 14:43:00.096: //26747/00F08B33E80F/CCAPI/cc_api_call_disconnected:
   Call Entry(Responsed=TRUE, Cause Value=47, Retry Count=0)
019847: *Feb 21 14:43:00.100: TCP0: FIN processed
019848: *Feb 21 14:43:00.100: TCP0: state was ESTAB -> CLOSEWAIT [1720 -> 192.168.1.207(34297)]
019849: *Feb 21 14:43:00.100: //26747/00F08B33E80F/CCAPI/ccConferenceDestroy:
   Conference Id=0x2FD2, Tag=0x0
019850: *Feb 21 14:43:00.100: //26747/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
019851: *Feb 21 14:43:00.100: //26749/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=26747, Disposition=0x0, Tag=0x0
019852: *Feb 21 14:43:00.100: //26747/00F08B33E80F/CCAPI/cc_generic_bridge_done:
   Conference I
R2811_MF_RS#d=0x2FD2, Source Interface=0x472DC084, Source Call Id=26749,
019853: *Feb 21 14:43:00.100: //-1/xxxxxxxxxxxx/H323/cch323_ct_main: SOCK 2 Event 0x1
019854: *Feb 21 14:43:00.100: //-1/xxxxxxxxxxxx/H323/cch323_gw_process_read_socket: owner_data=0x484D9450, len=46, msgPtr=0x4838D924
019855: *Feb 21 14:43:00.100: //-1/xxxxxxxxxxxx/H323/cch323_gw_process_read_socket: Received msg for H.225
019856: *Feb 21 14:43:00.104: H225.0 INCOMING ENCODE BUFFER::= 2580060008914A00051100110000F08B33C92D6112E80FD301C0A8017310800100
019857: *Feb 21 14:43:00.104:
019858: *Feb 21 14:43:00.104: H225.0 INCOMING PDU ::=
      h323-uu-pdu
          callIdentifier
        h245Tunneling FALSE
019859: *Feb 21 14:43:00.104: //-1/xxxxxxxxxxxx/H323/cch323_h225_receiver: Received msg of type RELEASEIND_CHOSEN
019860: *Feb 21 14:43:00.104: //26747/00F08B33E80F/H323/cch323_h225_receiver: RELEASEIND_CHOSEN: src address = 192.168.0.250; dest address = 192.168.1.207
019861: *Feb 21 14:43:00.104: //26747/00F08B33E80F/H323/run_h225_sm: Received event H225_EV_RELEASE_IND while at state H225_ALERT
019862: *Feb 21 14:43:00.104: //-1/xxxxxxxxxxxx/H323/cch323_ct_main: SOCK 2 Event 0x1
019863: *Feb 21 14:43:00.104: TCP0: state was CLOSEWAIT -> LASTACK [1720 -> 192.168.1.207(34297)]
019864: *Feb 21 14:43:00.104: TCP0: sending FIN
019865: *Feb 21 14:43:00.104: //-1/xxxxxxxxxxxx/H323/h323_gw_clean_send_blocked_watch: fd 2
019866: *Feb 21 14:43:00.108: //-1/xxxxxxxxxxxx/H323/cch323_cleanup_xport: hashDestroy for TcpFDTbl
019867: *Feb 21 14:43:00.108: //-1/xxxxxxxxxxxx/H323/cch323_iev_queue_service: Dispatch 0x2D internal event to H225 SM
019868: *Feb 21 14:43:00.108: //26747/00F08B33E80F/H323/run_h225_sm: Received event H225_EV_CONN_LOST while at state H225_ALERT
019869: *Feb 21 14:43:00.108: //26749/00F08B33E80F/CCAPI/ccCallDisconnect:
   Cause Value=47, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
019870: *Feb 21 14:43:00.108: //26749/00F08B33E80F/CCAPI/ccCallDisconnect:
   Cause Value=47, Call Entry(Responsed=TRUE, Cause Value=47)
019871: *Feb 21 14:43:00.108: //26749/00F08B33E80F/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
019872: *Feb 21 14:43:00.112: //26747/00F08B33E80F/CCAPI/ccCallDisconnect:
   Cause Value=47, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=47)
019873: *Feb 21 14:43:00.112: //26747/00F08B33E80F/CCAPI/ccCallDisconnect:
019874: *Feb 21 14:43:00.112: //26747/00F08B33E80F/CCAPI/cc_api_get_transfer_info:
019875: *Feb 21 14:43:00.116: //26749/00F08B33E80F/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x472DC084, Tag=0x0, Call Id=26749,
   Call Entry(Disconnect Cause=47, Voice Class Cause Code=0, Retry Count=0)
019876: *Feb 21 14:43:00.116: //26749/00F08B33E80F/CCAPI/cc_api_call_disconnect_done:
019877: *Feb 21 14:43:00.116: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
019878: *Feb 21 14:43:00.116: :cc_free_feature_vsa freeing 46A474A0
019879: *Feb 21 14:43:00.116: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
019880: *Feb 21 14:43:00.116:  vsacount in free is 1
019881: *Feb 21 14:43:00.116: //26747/00F08B33E80F/H323/cch323_do_call_disconnect: gw_id=1, discCause=47
019882: *Feb 21 14:43:00.116: //-1/xxxxxxxxxxxx/H323/cch323_iev_queue_service: Dispatch 0x9 internal event to H225 SM
019883: *Feb 21 14:43:00.116: //26747/00F08B33E80F/H323/run_h225_sm: Received event H225_EV_RELEASE while at state H225_ALERT
019884: *Feb 21 14:43:00.116: //26747/00F08B33E80F/H323/cch323_h225_set_new_state: Changing from H225_ALERT state to H225_IDLE state
019885: *Feb 21 14:43:00.116: //26747/00F08B33E80F/H323/cch323_call_generic_cleanup: Disconnected flag 1
019886: *Feb 21 14:43:00.116: //26747/00F08B33E80F/H323/cch323_store_call_history_entry: Trying to store call history/remove call_info while RTP session exists
019887: *Feb 21 14:43:00.116: //26747/00F08B33E80F/H323/cch323_store_call_history_entry: Call Active Playout Mode: 1,Init 60, Min 40, Max 250, Fax 300
019888: *Feb 21 14:43:00.116: //26747/00F08B33E80F/H323/cch323_store_call_history_entry: Call History Playout Mode: 1,Init 60, Min 40, Max 250, Fax 300
019889: *Feb 21 14:43:00.120: //26747/00F08B33E80F/H323/run_h245_iwf_sm: received IWF_EV_H245_DISCONN while at state IWF_IDLE
019890: *Feb 21 14:43:00.120: //26747/00F08B33E80F/H323/defaultHdlr: DEFAULT: Received IWF_EV_H245_DISCONN in state IWF_IDLE
019891: *Feb 21 14:43:00.120: Released port 45122 in Transport Port Agent for TCP IP type 0 delay 240000
019892: *Feb 21 14:43:00.120: TCP0: state was LISTEN -> CLOSED [45122 -> UNKNOWN(0)]
019893: *Feb 21 14:43:00.120: TCB 0x48050EC4 destroyed
019894: *Feb 21 14:43:00.120: //-1/xxxxxxxxxxxx/H323/h323_gw_clean_send_blocked_watch: fd 3
019895: *Feb 21 14:43:00.120: //26747/00F08B33E80F/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x47158B60, Tag=0x0, Call Id=26747,
019896: *Feb 21 14:43:00.120: //26747/00F08B33E80F/CCAPI/cc_api_call_disconnect_done:
019897: *Feb 21 14:43:00.120: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
019898: *Feb 21 14:43:00.120: :cc_free_feature_vsa freeing 46A47F98
019899: *Feb 21 14:43:00.120: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
019900: *Feb 21 14:43:00.120:  vsacount in free is 0
019901: *Feb 21 14:43:00.120: //-1/xxxxxxxxxxxx/H323/cch323_call_generic_cleanup: Freeing ccb (0x4603A824)
019902: *Feb 21 14:43:00.144: TCP0: Got ACK for our FIN
019903: *Feb 21 14:43:00.144: TCP0: state was LASTACK -> CLOSED [1720 -> 192.168.1.207(34297)]
019904: *Feb 21 14:43:00.144: Released port 1720 in Transport Port Agent for TCP IP type 1 delay 240000
019905: *Feb 21 14:43:00.144: TCB 0x4851BB9C destroyed
R2811_MF_RS#
019906: *Feb 21 14:43:21.960: TCB47FB4454 setting property TCP_TOS (11) 48555EE0
019907: *Feb 21 14:43:22.208: TCP0: ACK timeout timer expired
R2811_MF_RS#
R2811_MF_RS#
R2811_MF_RS#
R2811_MF_RS#
019908: *Feb 21 14:43:51.960: TCB47FB4454 setting property TCP_TOS (11) 48555EE0
019909: *Feb 21 14:43:52.204: TCP0: ACK timeout timer expired
R2811_MF_RS#
R2811_MF_RS#
R2811_MF_RS#
6 Replies 6
Bruno Rangel
Hi Martin
Just checked your output, I saw Cause code 47 is "No Resources" It can usually be traced to either a lack of DSP resources, channels, or more often than not a codec issue.
Also found a Cause code 34, this is a very common cause code and happens when the network is not able to determine what to do with the call being made.No Circuit/Channel Available.
Check the region of your MTP and Annunciator against the region of your H323 trunk, and see if you will need to transcode.  If so, make sure you have a transcoder available.
Cheers
Bruno Rangel
"Se você quiser alguém em quem confiar, confie em si mesmo. Quem acredita sempre alcança"
Renato Russo
Cheers
Bruno Rangel
Please remember to rate helpful responses using the star bellow and identify helpful or correct answers
I would like to thank you both for time spent with this situation. Sometimes what we need is just a push to start walkig.
Thanks for your ideas I could realize the problem is (still is) something to do with codec issue. By changing the device pool, i could make calls.
Now I'm going to study better this configs to first understand the working flow and manage the options to the right concept.
Thanks again.
Mártin
Ayodeji Okanlawon
Can you describe your scenario. Can you alas send your config. Looks like the gateway attempted to use g711a for the call.
What is the region setting between the phone and the gateway?
What codec is your inbound dial-peer and outbound dial-peer set to
Sent from Cisco Technical Support Android App
Please rate all useful posts
Hello aokanlawon, the scenario is: IPCom --> CUCM --> Router 2811
In the figure I post above there is a better view of scenario.
This is the gateway config:
R2811_MF_RS#sh run
Building configuration...
Current configuration : 10126 bytes
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
service password-encryption
service sequence-numbers
hostname R2811_MF_RS
boot-start-marker
boot system flash:c2800nm-entservicesk9-mz.124-15.T6.bin
boot-end-marker
card type e1 0 1
logging buffered 8192
logging console emergencies
enable secret 5 $1$H2R5$H/EXELkoAN8OXvHITtUzH/
enable password 7 096F471A1A0A
no aaa new-model
network-clock-participate wic 1
network-clock-select 1 E1 0/1/0
dot11 syslog
no ip source-route
no ip gratuitous-arps
ip cef
no ip bootp server
no ip domain lookup
stcapp feature access-code
voice-card 0
dspfarm
dsp services dspfarm
voice call send-alert
voice call convert-discpi-to-prog
voice call carrier capacity active
voice rtp send-recv
voice service pots
supported-language pt
voice service voip
no fax-relay sg3-to-g3
h323
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729r8
codec preference 4 g729br8
voice class h323 1
h225 timeout tcp establish 5
voice translation-rule 1
rule 1 /^5\(..$\)/ /95\1/
voice translation-rule 2
rule 1 /^00/ /021/
voice translation-rule 3
rule 1 /^0/ //
voice translation-rule 14
rule 1 /^00/ /014/
voice translation-rule 1551
rule 1 /^01551/ //
voice translation-profile 95xx
translate called 1
voice translation-profile RETIRA51
translate called 1551
voice translation-profile SRST
translate called 2
voice translation-profile SRST_014
translate called 14
voice translation-profile SRST_LOCAL
translate called 3
username telsinc privilege 15 password 7 111A090014061903092B25
username admin privilege 15 password 7 00091526560B5B51
username nonononono 5 password 7 151F041E012C272130
archive
log config
  hidekeys
controller E1 0/1/0
framing NO-CRC4
ds0-group 0 timeslots 1-15,17-31 type r2-digital r2-compelled ani
cas-custom 0
  country brazil
  metering
  double-answer
  category 2
  answer-signal group-b 1
  request-category 4
  dnis-digits min 1 max 65
  ani-digits min 1 max 65
  dnis-complete
ip tcp selective-ack
ip tcp path-mtu-discovery
ip tftp source-interface FastEthernet0/0
class-map match-all SCCP
match protocol skinny
class-map match-any VOIP_Class
match access-group name VOZ_ACL
class-map match-any SIGNAL_VOZ_VIDEO_Class
match access-group name SIGNAL_VOZ_VIDEO
class-map match-all H323
match protocol h323
interface Loopback0
description Usada pelo Music On Hold
ip address 1.1.1.1 255.255.255.255
ip address 192.168.0.250 255.255.255.0
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr 192.168.0.250
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0
mtu 1100
no ip address
encapsulation frame-relay IETF
interface Serial0/0/0.111 point-to-point
ip address 189.56.172.102 255.255.255.252
snmp trap link-status
frame-relay interface-dlci 111 CISCO
frame-relay ip rtp header-compression
interface Serial0/0/1
no ip address
shutdown
clock rate 2000000
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.0.1
ip route 189.56.217.176 255.255.255.252 189.56.172.101
ip route 192.168.1.0 255.255.255.0 189.56.172.101 name rede
no ip http server
ip http authentication local
no ip http secure-server
ip access-list extended SIGNAL_VOZ_VIDEO
permit ip any any dscp af31
permit ip any any dscp cs3
permit tcp any any eq 5060
permit udp any any eq 5060
permit tcp any any eq 1720
permit udp any any eq 1719
permit udp any any eq 1718
permit tcp any any range 2000 2004
ip access-list extended VOZ_ACL
permit ip 192.168.0.0 0.0.0.255 192.168.1.0 0.0.0.255 dscp ef
permit udp 192.168.0.0 0.0.0.255 192.168.1.0 0.0.0.255 range 14384 32768
map-class frame-relay FR_QOS
frame-relay cir 1024000
frame-relay bc 10240
frame-relay mincir 1024000
access-list 23 remark CONTROLE DE ACESSO TELNET
access-list 23 permit 192.168.0.0 0.0.255.255
access-list 23 deny   any log
control-plane
voice-port 0/1/0:0
cptone BR
voice-port 0/2/0
cptone BR
timeouts call-disconnect 0
timeouts wait-release 5
connection plar 9521
voice-port 0/2/1
cptone BR
voice-port 0/2/2
cptone BR
voice-port 0/2/3
supervisory disconnect anytone
cptone BR
voice-port 0/3/0
cptone BR
voice-port 0/3/1
cptone BR
voice-port 0/3/2
cptone BR
voice-port 0/3/3
cptone BR
ccm-manager music-on-hold
sccp local FastEthernet0/0
sccp ccm 192.168.1.207 identifier 1 version 5.0.1
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate profile 2 register CFB_POA
associate profile 1 register XCODE_RS
dspfarm profile 1 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 3
associate application SCCP
dspfarm profile 2 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 2
dial-peer cor custom
name int
name local
name ld
name intl
dial-peer cor list int
member int
dial-peer cor list local
member local
dial-peer cor list ld
member ld
dial-peer cor list intl
member intl
dial-peer voice 100 pots
translation-profile incoming 95xx
destination-pattern 0T
progress_ind setup enable 3
incoming called-number .
direct-inward-dial
port 0/1/0:0
dial-peer voice 101 pots
preference 2
direct-inward-dial
port 0/3/0
dial-peer voice 102 pots
preference 3
direct-inward-dial
port 0/3/1
dial-peer voice 103 pots
preference 4
direct-inward-dial
port 0/3/2
dial-peer voice 104 pots
preference 5
direct-inward-dial
port 0/3/3
dial-peer voice 950001 voip
description ##CallManager##
destination-pattern 95..
voice-class codec 1
voice-class h323 1
session target ipv4:192.168.1.207
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 120001 voip
destination-pattern 12..
voice-class codec 1
voice-class h323 1
no vad
dial-peer voice 900 pots
description ##CELFIX##
preference 1
destination-pattern 0[7-9]T
port 0/2/0
dial-peer voice 901 pots
preference 2
port 0/2/1
dial-peer voice 902 pots
preference 3
port 0/2/2
dial-peer voice 903 pots
preference 4
port 0/2/3
dial-peer voice 904 pots
description ##TRONCO##
preference 5
dial-peer voice 910 pots
preference 1
destination-pattern 00..[7-9]T
port 0/2/0
prefix 021
dial-peer voice 911 pots
preference 2
port 0/2/1
prefix 021
dial-peer voice 912 pots
preference 3
port 0/2/2
prefix 021
dial-peer voice 913 pots
preference 4
port 0/2/3
prefix 021
dial-peer voice 914 pots
preference 5
prefix 021
dial-peer voice 920 pots
description ##Tronco##
preference 1
destination-pattern 00..[2-6]T
port 0/1/0:0
prefix 014
dial-peer voice 921 pots
description ##Analogica##
preference 2
port 0/3/0
prefix 014
dial-peer voice 922 pots
preference 3
port 0/3/1
prefix 014
dial-peer voice 923 pots
preference 4
port 0/3/2
prefix 014
dial-peer voice 924 pots
preference 5
port 0/3/3
prefix 014
dial-peer voice 930 pots
preference 1
destination-pattern 000T
prefix 0014
dial-peer voice 931 pots
port 0/3/0
prefix 0014
dial-peer voice 932 pots
preference 3
port 0/3/1
prefix 0014
dial-peer voice 933 pots
preference 4
port 0/3/2
prefix 0014
dial-peer voice 934 pots
preference 5
port 0/3/3
prefix 0014
dial-peer voice 2 pots
destination-pattern 8#T
direct-inward-dial
port 0/1/0:0
num-exp 9500 9521
call-manager-fallback
secondary-dialtone 0
max-conferences 8 gain -6
transfer-system full-consult
ip source-address 192.168.0.250 port 2000
max-ephones 42
max-dn 80 dual-line
system message primary Trabalhando em modo SRST
system message secondary Modo SRST
transfer-pattern .T
call-forward pattern .T
time-zone 17
time-format 24
date-format dd-mm-yy
ephone-dn-template  1
privilege exec level 5 ping
privilege exec level 5 show stcapp device summary
line con 0
session-timeout 10
exec-timeout 30 0
logging synchronous
login local
line aux 0
line vty 0 4
session-timeout 10
exec-timeout 20 0
privilege level 15
password 7 106D000A0618
logging synchronous
login local
notify
transport input telnet
line vty 5 15
session-timeout 10
exec-timeout 20 0
logging synchronous
login local
notify
scheduler allocate 20000 1000
end
The H323 trunk is configure with device pool using a different region from the phone.
The gateway uses a Custom Region RS and the phone uses Default region.
Region Relationships
Region                 Audio Codec  Video Call Bandwidth
Default                 G.711                      None
RS                      G.729                      None
SP_ATA-Port 2     G.711                      None
Bruno, thanks for helping. How I enable transcoder? At the router or CUCM? or both?
Martin,
So here is what I think is going on..
Your incoming dial-peer is set to use voice-class codec..(which advertises G729 and G711)
Your region setting between IPCOM and gateway =G729 (hence this call leg will use g729)
Your outbound call is pots call so that will be g711
So your call flow looks like this..
Inbound--------------------g729-------gateway-----------G711------------PSTN
As you can see in this call you will need a xcoder for this call to work.
The other ATA call that is working has a call flow like this
inbound----=g711---gateway-------g711----PSTN (so that works without a xcoder)
You can either configure your gateway for xcoding or use G711 between your gateway and IPCOM
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Hi Martin
Just to complete the good finds from aokanlawon (+5 Stars), in order to have a Xcode/Transcode configured look on those links, transcoding is required to enable communication between different Codecs. For example, inbond Calls are G.711 only and will not be reachable from a side if Inter-region codec has been set as G.729. To make this communication possible, a transcoder sitting at terminating gateway do media conversion from one codec to another.
IOS Transconding
CUCM XCODE
Cheers
Bruno Rangel
Renato Russo
Cheers
Bruno Rangel
