problem with AAuto-attend
coucoumama
- i have a gsm gateway connected to my CME router , so i configure  all incomming call from outside to 4 SIM on my gsm gateway forwarded to  my Auto attend number also my FXO port .
so , the problem when a  call join my AA customized from the gsm gateway  , the customer for  example asked to press 1 to join the technical team but when she's type  it nothing produced and  the prompt keep playing , but from FXO port it  work . so i ask for a solution where i think is related to DTMF-relay i  think ?
the GSm gateway is a h323 with ip adress connected to Gb interface to  the CME and the type of dtmf on the gsm gateway is alphanumeric , signal  and RFC 2833
that's my dial-peer
dial-peer voice 102 voip
description Unity Express - VoiceMail
service app
destination-pattern 999
session protocol sipv2
session target ipv4:10.1.1.2
dtmf-relay rtp-nte
no dtmf-interworking
codec g711ulaw
no vad
this a capture for h323 gsm
9 Replies 9
coucoumama
sorry that's the capture of my gsm
Hi.
Can you please post the CME config.
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
Router#show run
Building configuration...
Current configuration : 15679 bytes
! No configuration change since last restart
version 15.1
service password-encryption
hostname Router
boot-start-marker
boot-end-marker
enable secret 4 X4ZqtPJ///KxuEWxHSsJrv3beQVnz2ise/xj8fF6eFU
no aaa new-model
no ipv6 cef
ip source-route
ip cef
ip dhcp excluded-address 192.168.1.1 192.168.1.10
ip dhcp excluded-address 192.168.2.1 192.168.2.10
ip dhcp excluded-address 10.1.1.1 10.1.1.10
ip dhcp pool VOICE
network 10.1.1.0 255.255.255.0
default-router 10.1.1.1
option 150 ip 10.1.1.1
ip dhcp pool DATA
network 192.168.2.0 255.255.255.0
default-router 192.168.2.1
dns-server 192.168.2.100
crypto pki trustpoint TP-self-signed-490950127
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-490950127
revocation-check none
rsakeypair TP-self-signed-490950127
crypto pki certificate chain TP-self-signed-490950127
certificate self-signed 01
  30820229 30820192 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  30312E30 2C060355 04031325 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 34393039 35303132 37301E17 0D313230 37303930 39333133
  305A170D 32303031 30313030 30303030 5A303031 2E302C06 03550403 1325494F
  532D5365 6C662D53 69676E65 642D4365 72746966 69636174 652D3439 30393530
  31323730 819F300D 06092A86 4886F70D 01010105 0003818D 00308189 02818100
  CCD1D5D9 3023DF26 608D9B91 0D43E112 9F07B3FD 0D53CDFD 8AD80D77 9607E5EA
  F3EF3003 25A34ADC B5FFEFAC 155AD9D5 59B5B1D8 29179ACA 31445436 83804CEA
  1D5007D4 0357F1D6 B9434BDB 09FD6E6A 8E5B6B22 346A84A3 B71C49D0 97E527A8
  4D3BB57D 16392D28 C88FD587 220C10B8 829D17B9 BB81637B 23EA7242 B1468015
  02030100 01A35330 51300F06 03551D13 0101FF04 05300301 01FF301F 0603551D
  23041830 168014C7 DBCCE9F9 9BDA48DC C7FA833D D297177C A54E7C30 1D060355
  1D0E0416 0414C7DB CCE9F99B DA48DCC7 FA833DD2 97177CA5 4E7C300D 06092A86
  4886F70D 01010505 00038181 00804AC9 A908C781 DFA08EC4 D42E280D 35CF9F11
  E08B7952 8773F66F A7847EB0 206DC50C 63841E6C 73A2D385 786977CC 4C4809CB
  19BBF6E0 8A116A81 4F23809D FD0A7FC5 E63FA758 F3A32B75 B0E5A5C2 D3B30EBD
  5461E0BC 4CA10941 7A36A14D 3E8FEBC1 C4CE585A 296B5008 44FDA84E 4BA596DA
  6654DA60 DEF83E32 727A4FE0 9C
        quit
voice-card 0
voice class dualtone-detect-params 1
freq-max-deviation 25
freq-max-power 0
freq-min-power 13
freq-power-twist 4
cadence-variation 4
voice class dualtone-detect-params 90
freq-max-power 6
freq-min-power 25
freq-power-twist 15
freq-max-delay 16
cadence-variation 8
license udi pid CISCO2901/K9 sn FCZ161590ST
hw-module ism 0
hw-module pvdm 0/1
file verify auto
username admin secret 4 X4ZqtPJ///KxuEWxHSsJrv3beQVnz2ise/xj8fF6eFU
redundancy
voice service voip
allow h323 to H323
allow sip to H323
allow h323 to sip
interface Embedded-Service-Engine0/0
no ip address
interface GigabitEthernet0/0
ip address 192.168.3.1 255.255.255.0
duplex auto
speed auto
interface ISM0/0
ip unnumbered GigabitEthernet0/1.10
ip virtual-reassembly in
service-module fail-open
service-module ip address 10.1.1.2 255.255.255.0
service-module ip default-gateway 10.1.1.1
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
interface GigabitEthernet0/1.10
encapsulation dot1Q 10
ip address 10.1.1.1 255.255.255.0
interface GigabitEthernet0/1.20
encapsulation dot1Q 20
ip address 192.168.2.254 255.255.255.0
ip helper-address 192.168.2.100
interface ISM0/1
description Internal switch interface connected to Internal Service Module
no ip address
interface Vlan1
no ip address
ip forward-protocol nd
ip http server
ip http access-class 50
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip http path flash0:/8.6.0
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/1.20
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0
ip route 10.1.1.2 255.255.255.255 ISM0/0
ip route 192.168.2.0 255.255.255.0 GigabitEthernet0/1.20
access-list 50 permit 10.1.1.2
access-list 50 remark -=[Control CUCME Web Access]=-
access-list 50 permit 192.168.2.0 0.0.0.255
tftp-server flash:/ephone/7945-7965/apps45.8-3-2-27.sbn alias apps45.8-3-2-27.sbn
tftp-server flash:/ephone/7945-7965/cnu45.8-3-2-27.sbn alias cnu45.8-3-2-27.sbn
tftp-server flash:/ephone/7945-7965/cvm45sccp.8-3-2-27.sbn alias cvm45sccp.8-3-2-27.sbn
tftp-server flash:/ephone/7945-7965/dsp45.8-3-2-27.sbn alias dsp45.8-3-2-27.sbn
tftp-server flash:/ephone/7945-7965/jar45sccp.8-3-2-27.sbn alias jar45sccp.8-3-2-27.sbn
tftp-server flash:/ephone/7945-7965/SCCP45.8-3-3S.loads alias SCCP45.8-3-3S.loads
tftp-server flash:/ephone/7945-7965/term45.default.loads alias term45.default.loads
tftp-server flash:/ephone/7945-7965/term65.default.loads alias term65.default.loads
tftp-server flash:/ephone/7906-7911/apps11.8-3-2-27.sbn alias apps11.8-3-2-27.sbn
tftp-server flash:/ephone/7906-7911/cnu11.8-3-2-27.sbn alias cnu11.8-3-2-27.sbn
tftp-server flash:/ephone/7906-7911/cvm11sccp.8-3-2-27.sbn alias cvm11sccp.8-3-2-27.sbn
tftp-server flash:/ephone/7906-7911/dsp11.8-3-2-27.sbn alias dsp11.8-3-2-27.sbn
tftp-server flash:/ephone/7906-7911/jar11sccp.8-3-2-27.sbn alias jar11sccp.8-3-2-27.sbn
tftp-server flash:/ephone/7906-7911/SCCP11.8-3-3S.loads alias SCCP11.8-3-3S.loads
tftp-server flash:/ephone/7906-7911/term06.default.loads alias term06.default.loads
tftp-server flash:/ephone/7906-7911/term11.default.loads alias term11.default.loads
control-plane
voice-port 0/2/0
supervisory disconnect dualtone mid-call
supervisory answer dualtone sensitivity high
supervisory dualtone-detect-params 1
no battery-reversal
input gain 5
output attenuation -2
no vad
compand-type a-law
cptone CZ
timeouts call-disconnect 10
timeouts wait-release 1
connection plar opx 150
impedance complex2
description Configured by CCA 4 FXO-0/1/0-Custom-OP
caller-id enable
voice-port 0/2/1
no battery-reversal
input gain 5
no vad
compand-type a-law
cptone CZ
impedance complex2
caller-id enable
voice-port 0/2/2
no battery-reversal
input gain 5
no vad
compand-type a-law
cptone CZ
impedance complex2
caller-id enable
voice-port 0/2/3
no battery-reversal
input gain 5
no vad
compand-type a-law
cptone CZ
impedance complex2
caller-id enable
voice-port 0/3/0
voice-port 0/3/1
voice-port 0/3/2
connection plar 104
caller-id enable
voice-port 0/3/3
connection plar 102
caller-id enable
mgcp profile default
dial-peer cor custom
name local
name national
name international
dial-peer cor list call-local
member local
dial-peer cor list call-national
member local
member national
dial-peer cor list call-international
member local
member national
member international
dial-peer voice 1 pots
corlist outgoing call-national
destination-pattern [798].......
port 0/2/0
dial-peer voice 2 pots
preference 1
port 0/2/1
dial-peer voice 3 pots
preference 2
port 0/2/2
dial-peer voice 4 pots
preference 3
port 0/2/3
dial-peer voice 10 pots
corlist outgoing call-international
destination-pattern 00T
port 0/2/0
forward-digits all
dial-peer voice 11 pots
preference 1
port 0/2/1
forward-digits all
dial-peer voice 12 pots
preference 2
port 0/2/2
forward-digits all
dial-peer voice 13 pots
preferen
Apr  5 14:59:24.899: %IPPHONE-6-REGISTER: ephone-10:SEP3CCE7358A09B IP:10.1.1.27 Socket:3 DeviceType:Phone has registered.ce 3
port 0/2/3
forward-digits all
dial-peer voice 14 pots
destination-pattern [94].......
port 0/2/0
dial-peer voice 15 pots
preference 1
port 0/2/1
dial-peer voice 103 voip
destination-pattern 800
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 100 voip
description gsm-gateway
destination-pattern [253].......
session target ipv4:192.168.3.2:1720
dtmf-relay rtp-nte
codec g711ulaw
no vad
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 16 pots
preference 2
port 0/2/2
dial-peer voice 17 pots
preference 3
port 0/2/3
dial-peer voice 20 pots
destination-pattern 01200
port 0/2/0
forward-digits 4
dial-peer voice 21 pots
destination-pattern 01210
port 0/2/0
forward-digits 4
dial-peer voice 22 pots
destination-pattern 01198
port 0/2/0
forward-digits 4
dial-peer voice 23 pots
destination-pattern 01299
port 0/2/0
forward-digits 4
sip-ua
gatekeeper
shutdown
telephony-service
group 1
  ip source-address 10.1.1.1 port 2000
  url services http://10.1.1.2/voiceview/common/login.do
  url authentication http://10.1.1.1/CCMCIP/authenticate.asp
authentication credential admin admin
authentication credential cisco cisco
max-ephones 25
max-dn 70
system message SAME
load 7911 SCCP11.8-3-3S
load 7965 SCCP45.8-3-3S
time-format 24
dialplan-pattern 2 71807782 extension-length 3
voicemail 800
max-conferences 8 gain -6
moh moh.au
multicast moh 239.1.1.55 port 2100
web admin system name cisco secret 5 $1$KTt1$JhAozQ8ilzWNt9jMVzlIO0
dn-webedit
time-webedit
transfer-system full-consult
secondary-dialtone 9
directory last-name-first
create cnf-files version-stamp 7960 Apr 05 2013 14:58:08
line con 0
exec-timeout 0 0
password 7 060506324F41
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line 67
no exec
transport input all
stopbits 1
line vty 0 4
password 7 05080F1C2243
login
transport input all
scheduler allocate 20000 1000
end
ahmed-ben-ammar
need help please
Hi can you please send the output of a show call active voice | in Peer during a call to AA from GSM.
Please also specify the number of AA application you are calling to
THX
Carlo
i can' t for this moment because im not at the customer local to have the output but if u can explain me from where exactly this issue if there is something missed on my CME config alo the AA number is 999 , thank you
to explain more the issue , the incomming call from the gsm to my AA number ( 999 ) is established and i can listen to my welcome prompt but when try to join or put 1 , 2 or 3 nothing produced the greeting still playing and from FXO port it's okey .
thanks
need help !!!
Hi Ahmed.
I need some debugs output.
debug voip ccapi inout
debug h245 asn1
Please post these outputs.
Reards
Carlo
