07-24-2012 12:31 AM - edited 03-16-2019 12:20 PM
If I put the command ´sh license detail cme-srst´ I receive this :
RouterVallecas#sh license detail cme-srst
Feature: cme-srst Period left: 5 weeks 6 days
Index: 1 Feature: cme-srst Version: 1.0
License Type: EvalRightToUse
License State: Active, In Use
Evaluation total period: 8 weeks 4 days
Evaluation period left: 5 weeks 6 days
Period used: 2 weeks 4 days
Transition date: Sep 03 2012 20:02:37
License Count: 32/0 (In-use/Violation)
License Priority: Low
Store Index: 7
Store Name: Built-In License Storage
This mean is already installed the license? because althoug says ´License State: Active, In Use´ there is only a Evaluation period of 8 w and 4 d.
When this period expire, should I keep on using the CME router?
Do I need to do anything else or is all ok?
Thanks and regards!
Solved! Go to Solution.
07-24-2012 12:41 AM
I Ivan,
CME / SRST licenses are honor based and hence you have to just accept the EULA. After the 60 days of evaluation the license will change to "right to use" for 12 years.
Ronak Patel
Rate helpful posts by clicking stars below the answer.
07-24-2012 12:41 AM
I Ivan,
Ronak Patel
07-24-2012 01:11 AM
Ok thanks, now i see in the cme
Feature name EULA Accepted
ipbasek9 n/a
securityk9 yes
uck9 n/a
datak9 yes
gatekeeper no
SSL_VPN no
ios-ips-update no
SNASw no
hseck9 n/a
cme-srst yes
WAAS_Express no
UCVideo no
so, as you say, there is already accepted, and after 2 weeks the license will expire in 12 y.
Regards!
07-24-2012 01:55 AM
HI
Yes.
Basically as per me, Cisco consider 12 year as life of the product so you can use the CME/SRST till the product is alive ( i.e 12 years).
regards
Ronak patel
07-24-2012 06:31 AM
Hi Ivan,
+5 to Ronak for these excellent tips!
Just thought that I would add that in newer IOS's the 12 year RTU ( right to use)
license has been replaced with a "Lifetime" RTU license
http://www.cisco.com/en/US/docs/routers/access/sw_activation/SA_on_ISR.pdf
Cheers!
Rob
"Always movin' ahead and never lookin' back" - Springsteen
