Problem with IVR vxml
Dmitri Popkov
Good day!
Can you help me please, im trying to create a custom ivr vxml scrip, but i cant make it to work properly
When ccme receives a inbound call:
1) Welcome greetings begins to play (It works properly)
2)Then, if smb enters ext ... connection should go to desire phone (It works properly)
3) If nothing there are no number entered, call should go to hunt-group - number - 64001 (Call-center)
Here is my vxml
<?xml version="1.0"?>
<vxml version="2.0" base="flash:/vxml/ivr-1.vxml">
<var name="number"/>
<form id="main">
<property name="timeout" value="3s"/>
<block> <prompt>
<audio src="flash:/vxml/disa-1.wav"/>
</prompt> </block>
<field name="num" type="number">
<grammar type="application/grammar+regex">[0-9][0-9][0-9]</grammar>
  <filled>
   <assign expr="'phone://' + num" name="number"/>
   <goto next="#ext"/>
  </filled>
</field>
</form>
<form id="ext">
<transfer connecttimeout="20s" name="mycall"  destexpr="number" bridge="false"> </transfer>
</form>
</vxml>
Dmitri Popkov
Problem was solved.
Thanks;)
