Problem with notify messages on E1 line and AS5350
vadoodetm
I have a AS5350 with E1 2 PRI DFC on it. E1 line is terminated on the cisco AS5350 and then there is a trunk between this and an Asterisk server. The setup works fine and all incoming calls are forwarded to asterisk server and properly handled.
Problem is, when during a call the other party presses number 2 during a call, which cisco gateway takes it as a notify message  and does not send it to the asetrisk server. All other numbers work just fine.
I wonder if there is some way to instruct gateway to send dtmf to voip server.
here is the partial configuration for the device:
controller E1 3/0
pri-group timeslots 1-31
controller E1 3/1
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
signaling forward unconditional
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback none
isdn switch-type primary-net5
interface Serial3/0:15
no ip address
encapsulation ppp
isdn incoming-voice modem 56
isdn global-disconnect
isdn send-alerting
isdn sending-complete
no keepalive
no fair-queue
interface Serial3/1:15
no ip address
encapsulation ppp
isdn overlap-receiving T302 1000
isdn send-alerting
no keepalive
no fair-queue
voice-port 3/0:D
input gain 10
output attenuation -5
echo-cancel coverage 24
no vad
cptone DE
timeouts ringing 30
timeouts wait-release 1
bearer-cap Speech
voice-port 3/1:D
input gain 10
no vad
cptone DE
timeouts ringing 30
bearer-cap Speech
mgcp fax t38 ecm
dial-peer voice 200 voip
description TO-Asterisk
destination-pattern .T
voice-class codec 5060
session protocol sipv2
session target ipv4:172.21.0.40:5060
session transport udp
dtmf-relay rtp-nte
dtmf-interworking rtp-nte
no vad
11 Replies 11
paolo bevilacqua
You can change dtmf-relay method to something that your open source "PBX", or it's phones, understand.
In fact, gateway does not relay anything when this number is pressed. I do not receive anything on PBX side. Below is what happens on the gateway when caller enters anything other than 2 and when he enters 2  (logs from gateway)
==================  when any other digit is input
May 19 14:07:24.728: ISDN Se3/1:15 Q931: RX <- SETUP pd = 8  callref = 0x6175
        Sending Complete
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98398
                Exclusive, Channel 24
        Calling Party Number i = 0x0083, '00919115zzzz'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x81, 'yyyyy'
                Plan:ISDN, Type:Unknown
May 19 14:07:24.728: ISDN Se3/1:15 Q931: Received SETUP  callref = 0xE175 callID = 0x0533 switch = primary-net5 interface = User
May 19 14:07:24.736: ISDN Se3/1:15 Q931: TX -> CALL_PROC pd = 8  callref = 0xE175
May 19 14:07:24.748: ISDN Se3/1:15 Q931: TX -> CONNECT pd = 8  callref = 0xE175
May 19 14:07:24.780: ISDN Se3/1:15 Q931: RX <- CONNECT_ACK pd = 8  callref = 0x6175
May 19 14:07:33.175: ISDN Se3/1:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x6175
        Cause i = 0x8290 - Normal call clearing
        Progress Ind i = 0x8288 - In-band info or appropriate now available
May 19 14:07:33.175: ISDN Se3/1:15 Q931: call_disc: Global disconnect configured; Postpone sending RELEASE for callid 0x533
May 19 14:07:33.179: ISDN Se3/1:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0xE175
        Cause i = 0x8090 - Normal call clearing
==================  when number 2 is input
May 16 12:10:46.416: ISDN Se3/1:15 Q931: RX <- SETUP pd = 8  callref = 0x5FF5
        Sending Complete
                Standard = CCITT
        Channel ID i = 0xA9839B
                Exclusive, Channel 27
May 16 12:10:46.416: ISDN Se3/1:15 Q931: Received SETUP  callref = 0xDFF5 callID = 0x039C switch = primary-net5 interface = User
May 16 12:10:46.424: ISDN Se3/1:15 Q931: TX -> CALL_PROC pd = 8  callref = 0xDFF5
May 16 12:10:46.432: ISDN Se3/1:15 Q931: TX -> CONNECT pd = 8  callref = 0xDFF5
May 16 12:10:46.468: ISDN Se3/1:15 Q931: RX <- CONNECT_ACK pd = 8  callref = 0x5FF5
May 16 12:10:51.903: ISDN Se3/1:15 Q931: RX <- NOTIFY pd = 8  callref = 0x5FF5
        Notification Ind i = 0xF9
May 16 12:10:51.903: ISDN Se3/1:15 Q931: TX -> STATUS pd = 8  callref = 0xDFF5
        Cause i = 0x80E427 - Invalid information element contents
        Call State i = 0x0A
May 16 12:10:54.791: ISDN Se3/1:15 Q931: RX <- NOTIFY pd = 8  callref = 0x5FF5
        Notification Ind i = 0xFA
May 16 12:10:54.791: ISDN Se3/1:15 Q931: TX -> STATUS pd = 8  callref = 0xDFF5
        Call State i = 0x0A
May 16 12:10:58.935: ISDN Se3/1:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x5FF5
May 16 12:10:58.935: ISDN Se3/1:15 Q931: call_disc: Global disconnect configured; Postpone sending RELEASE for callid 0x39C
May 16 12:10:58.939: ISDN Se3/1:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0xDFF5
        Cause i = 0x8095 - Call rejected
You have to ask your telco why they do not relay digits in-band after call is connected.
However, you have to prove that nothing is received first, while it is received, but not handled by your thirdy party device, as I was suggesting before.
Also I don't know what is the reason for which they send "NOTIFY" message, that the router doesn't even accept.
Thank you Paolo for the comment.
I think destination-pattern thing is just fine. My problem occurs during a call. I mean when during the call, a caller tries to press 2 to send a DTMF tone to IVR, it fails. All other digits work.
We need this behaviour. We want to answer the call as soos as caller stops dialing more numbers. this is done using this interdigit timeout.
I mean if the caller dials 5 numbers he sill be directed to attendant, and if 7 he will be directed to the appropriate extension.
But the original problem I have, happens during a call. I mean while the call is established. Is it related to destination-pattern?
I have edited my post above, becase that as that apparently has nothing to do with overlap digits, as I erroneously indicated before.
The odd thing is, we only see the  that when incoming call comes from celluar phones. If the calling number is a landline, everything works fine.
That normally indicates an issue with overlap receiving. Because a cellephons sends the full number at once, while landline can use overlap.
Any hints on how can I troubleshoot this? Or at least how I can make sure what the real cause of the problem is? The other hint is that DID also works fine both from landline and cellular.
Try configuring destination-pattern for a full lenght DID.
Do you find the root cause of your issue because I am facing the same problem with my gateway.
regards
Luc
