Problem with "telephone-event/16000" exist in SDP from ISP to CUBE
Hello community i am facing a strange problem that i didn't find an answer on it.
the only thing i had found, that another user faced a similar situation but without got answer
https://github.com/pjsip/pjproject/issues/2675
The problem when ISP send invite to CUBE and the SDP contain in the first negotiation for telephone-event 16000 as a first pirority, the CUCM not respondiong to this invite
but when the ISP send only  telephone-event 8000 it works fine
ISP (telehone event 16000) >> CUBE (telehone event 16000)> CUCM     "CUCM never respond and call failed"
ISP (telehone event 8000) >> CUBE (telehone event 8000)> CUCM     "CUCM respond and call works"
Below is the failed call:
Failed callFailed call
telephone event 16000telephone event 16000
below is the working call:
Working CallWorking Call
telephone event 8000telephone event 8000
@b.winter  Appreciate your advice sir,
Because RTP-NTE is part of the audio stream, it has to have the same clockrate as the audio channel. (Edited because, duh, 16000 for nte.)
I would suggest configuring an inbound SIP Profile to reorder references to telephony-event/16000 allowing the system to negotiate something else.
Maren
Hello Maren,
Thanks for your respone.
I have develpoed a sip profile to remove it and tested with Cisco tool and looks fine,
I will try to update the VGW with it and see the result
voice class sip-profiles 10
rule 1 request ANY sdp-header mline-index 1 a=rtpmap:105 remove
rule 2 response ANY sdp-header mline-index 1 a=rtpmap:105 remove
