Problem with SIP Trunk and SIP IP Phones inbound.
troy.lynch
I've got a strange problem I've been banging my head against. I've got 2 SIP Trunk accounts that I use for incoming and outgoing calls. I have a handfull of SCCP phones and a handfull of plain SIP phones. With my configuration if I leave out the SIP phone configuration I have a hunt-group that sets up to ring all the SCCP phones when a incoming call comes in from any of the SIP trunks.
voice hunt-group 1 parallel
final 800
list 100,102,103
timeout 20
pilot 500
Which works great exactly how I would expect it to. However when I add the SIP phones with the following config. The first SIP Trnk works fine no matter what and the second SIP trunk works fine until a SIP phone registers and this point the second SIP Trunk will only ring the registered SIP phone. If I unregister the SIP Phone it then will not ring anything until I reload the router.
voice register global
mode cme
source-address 192.168.2.1 port 5060
max-dn 10
max-pool 5
authenticate register
authenticate realm liquiddigital.us
tftp-path flash:
create profile sync 0002731505224327
voice register dn  1
number 104
name 104
label 104
voice register dn  2
number 105
name 105
label 105
voice register dn  3
number 106
name 106
label 106
voice register pool  1
id mac DEAD.BEEF.0001
number 1 dn 1
dtmf-relay sip-notify
username 104 password ***
codec g711ulaw
voice register pool  2
number 1 dn 2
username 105 password ***
codec g711ulaw
voice register pool  3
number 1 dn 3
username 106 password ***
codec g711ulaw
Any help is greatly appreciated!
Troy
These debugs show extension 106 trying to register to both SIP providers (sip.broadvoice.com and gvgw2.simonics.com). The Broadvoice provider rejects the registration and simonics accepts the registration. After that a call is sent to the CME router with a SIP request URI of sip:106@98.226.116.196. This call is routed to the phone with extension 106 as you would expect.
It looks like the simonics provider is doing some number translations such that 8154960448 is being translated to the SIP extensions you are registering with them. Can you try preventing the SIP DNs from registering with the provider by adding the following.
voice register dn x
no-reg
After doing that run "show sip register status" and confirm you only see 2 lines with a peer of -1.
Then refresh the main registrations either by waiting for them to expire or doing the following.
no registrar 1 dns:sip.broadvoice.com expires 3600
no registrar 2 dns:gvgw2.simonics.com expires 3600
Confirm the registrations again use "show sip register status". Then try placing a call.
14 Replies 14
daniel.bloom
It sounds like it could be a conflicting registration issue. Can you share your sip-ua config? Also can you share the output of the following command before and after the SIP phones are registered.
Show sip-ua register status
Thanks for the reply Daniel. Heres my sip-ua info.
sip-ua
credentials username 8153154009 password 7 *** realm BroadWorks
credentials username GV18154960448 password 7 *** realm GVGW
authentication username 8153154009 password 7 *** realm BroadWorks
authentication username GV18154960448 password 7 *** realm GVGW
no remote-party-id
retry invite 3
retry register 10
timers connect 100
sip-server dns:gvgw2.simonics.com
connection-reuse
host-registrar
The before SIP IP Phone
ld-rtr#show sip-ua register status
--------------------- Registrar-Index  1 ---------------------
Line                             peer       expires(sec) registered P-Associ-URI
100                              20002      26           no
102                              20001      26           no
103                              20003      26           no
8153154009                       -1         2394         yes
GV18154960448                    -1         26           no
--------------------- Registrar-Index  2 ---------------------
100                              20002      2726         yes
102                              20001      2726         yes
103                              20003      2728         yes
8153154009                       -1         2726         yes
GV18154960448                    -1         2726         yes
The After SIP IP Phone
100                              20002      93           no
102                              20001      93           no
103                              20003      93           no
105                              40001      168          no
8153154009                       -1         2281         yes
GV18154960448                    -1         93           no
100                              20002      2613         yes
102                              20001      2613         yes
103                              20003      2615         yes
105                              40001      2868         yes
8153154009                       -1         2613         yes
GV18154960448                    -1         2613         yes
The above looks ok to me. Can you debug an incoming call with the SIP phones registered and post the result?
Use the following debugs
debug ccsip messages
debug voip ccapi inout
For this call can you provide the calling and the called numbers also.
The incoming number not sure its a skype account I'm using to call in from outside the network. The number I'm dailing is 8154960448. Looks like the skype number is 16617480240.
ld-rtr#
*Mar 19 14:20:26.040: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ld-rtr#
*Mar 19 14:20:37.152: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
REGISTER sip:192.168.1.1 SIP/2.0
Via: SIP/2.0/UDP 192.168.1.104:42921;rport;branch=z9hG4bKg0eg5XS9BZ0Hc
Max-Forwards: 70
To: <105>
Call-ID: ecc25bdf-0ae5-1231-0c88-f98e4504380a
CSeq: 41496056 REGISTER
Contact: <105>
Expires: 600
User-Agent: SessionTalk 3.6.3.1
Allow: INVITE, ACK, BYE, CANCEL, OPTIONS, REFER, NOTIFY
Supported: replaces, path
Content-Length: 0
*Mar 19 14:20:37.156: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To: <105>
Date: Tue, 19 Mar 2013 14:20:37 GMT
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
*Mar 19 14:20:37.156: //1926/00F8002781C2/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 401 Unauthorized
To: <105>;tag=3159F1C-14E2
WWW-Authenticate: Digest realm="liquiddigital.us",nonce="BE0C7D57004EF64F",algorithm=MD5,qop="auth"
Content-Length: 0
*Mar 19 14:20:37.172: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.1.104:42921;rport;branch=z9hG4bKH9786raD97p4Q
Max-Forwards: 70
To: <105>
CSeq: 41496057 REGISTER
Contact: <105>
Expires: 600
Authorization: Digest username="105", realm="liquiddigital.us", nonce="BE0C7D57004EF64F", cnonce="7RGpjQrlEjGIDPmORQQ4Cg", algorithm=MD5, uri="sip:192.168.1.1", response="82bd9b5ec95a144e3ec289ef275307fb", qop=auth, nc=0000015b
Content-Length: 0
*Mar 19 14:20:37.176: //1926/00F8002781C2/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Content-Length: 0
ld-rtr#
Sent:
SIP/2.0 200 OK
Contact: <105>;expires=160
Expires:  160
Content-Length: 0
*Mar 19 14:20:38.669: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:105@50.151.94.216:5060 SIP/2.0
Max-Forwards: 20
Via: SIP/2.0/UDP 199.30.56.199:5060;rport;branch=z9hG4bK1640416400
To: <105>
Call-ID: 1146969646@199.30.56.199
CSeq: 9290 INVITE
User-Agent: GVGW
Contact: <16617480240>
Allow: ACK, INVITE, BYE, CANCEL, REGISTER, REFER, OPTIONS, INFO
Content-Type: application/sdp
Content-Length: 185
v=0
o=yate 1363702777 1363702777 IN IP4 199.30.56.199
s=SIP Call
c=IN IP4 199.30.56.199
t=0 0
m=audio 20124 RTP/AVP 0 101
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
*Mar 19 14:20:38.673: //-1/01DF53E681C3/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=16617480240
   ----- ccCallInfo IE subfields -----
   cisco-ani=16617480240
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=105
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
*Mar 19 14:20:38.673: //-1/01DF53E681C3/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x4ACF5228, Call Info(
   Calling Number=16617480240,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=105(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=0, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=1927
*Mar 19 14:20:38.673: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Mar 19 14:20:38.673: :cc_get_feature_vsa malloc success
*Mar 19 14:20:38.673:  cc_get_feature_vsa count is 1
*Mar 19 14:20:38.673: :FEATURE_VSA attributes are: feature_name:0,feature_time:1314833976,feature_id:15
*Mar 19 14:20:38.677: //1927/01DF53E681C3/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=16617480240(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=105(TON=Unknown, NPI=Unknown))
*Mar 19 14:20:38.677: //1927/01DF53E681C3/CCAPI/cc_process_call_setup_ind:
   Event=0x4B478418
*Mar 19 14:20:38.677: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 105
*Mar 19 14:20:38.677: //1927/01DF53E681C3/CCAPI/ccCallSetContext:
   Context=0x48B17D30
   >>>>CCAPI handed cid 1927 with tag 0 to app "_ManagedAppProcess_Default"
*Mar 19 14:20:38.677: //1927/01DF53E681C3/CCAPI/ccCallProceeding:
*Mar 19 14:20:38.681: //1927/01DF53E681C3/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=40001, Params=0x48B19198, Progress Indication=NULL(0)
*Mar 19 14:20:38.681: //1927/01DF53E681C3/CCAPI/ccCheckClipClir:
   In: Calling Number=16617480240(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=16617480240(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Destination Pattern=105, Called Number=105, Digit Strip=FALSE
   Redirect Number=, Display Info=SKYPE USER
   Account Number=16617480240, Final Destination Flag=TRUE,
   Guid=01DF53E6-8FD7-11E2-81C3-C51C5A41FF76, Outgoing Dial-peer=40001
*Mar 19 14:20:38.681: //1927/01DF53E681C3/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=105
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
*Mar 19 14:20:38.681: //1927/01DF53E681C3/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x4ACF5228, Interface Type=3, Destination=, Mode=0x0,
   Call Params(Calling Number=16617480240,(Calling Name=SKYPE USER)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=105(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=40001, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
*Mar 19 14:20:38.681: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Mar 19 14:20:38.681: :cc_get_feature_vsa malloc success
*Mar 19 14:20:38.681:  cc_get_feature_vsa count is 2
*Mar 19 14:20:38.681: :FEATURE_VSA attributes are: feature_name:0,feature_time:1314834424,feature_id:16
*Mar 19 14:20:38.685: //1928/01DF53E681C3/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
*Mar 19 14:20:38.685: //1928/01DF53E681C3/CCAPI/ccCallSetContext:
   Context=0x48B19148
*Mar 19 14:20:38.685: //1927/01DF53E681C3/CCAPI/ccSaveDialpeerTag:
*Mar 19 14:20:38.689: //1928/01DF53E681C3/CCAPI/cc_api_call_proceeding:
   Interface=0x4ACF5228, Progress Indication=NULL(0)
*Mar 19 14:20:38.693: //1927/01DF53E681C3/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To: <105>
Date: Tue, 19 Mar 2013 14:20:38 GMT
CSeq: 9290 INVITE
Allow-Events: telephone-event
Content-Length: 0
*Mar 19 14:20:38.693: //1928/01DF53E681C3/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:105@192.168.1.104:42921 SIP/2.0
Via: SIP/2.0/UDP 192.168.1.1:5060;branch=z9hG4bK67F22B4
To: <105>
Call-ID: 1E26147-8FD711E2-81C9C51C-5A41FF76@192.168.1.1
Supported: 100rel,timer,resource-priority,replaces
Min-SE:  1800
Cisco-Guid: 0031413222-2413236706-2177090844-1514274678
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, R
ld-rtr#EFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1363702838
Call-Info: <192.168.1.1:5060>;method="NOTIFY;Event=telephone-event;Duration=2000"
Expires: 180
Max-Forwards: 19
Content-Disposition: session;handling=required
Content-Length: 212
v=0
o=CiscoSystemsSIP-GW-UserAgent 7175 9286 IN IP4 192.168.1.1
s=SIP Call
c=IN IP4 192.168.1.1
t=0 0
m=audio 18324 RTP/AVP 0 19
a=rtpmap:19 CN/8000
a=ptime:20
*Mar 19 14:20:38.857: //1928/01DF53E681C3/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <105>
CSeq: 101 INVITE
Timestamp: 1363702838 0.002299
Content-Length: 0
*Mar 19 14:20:38.917: //1928/01DF53E681C3/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To: <105>;tag=yr8675UKBSK4H
CSeq: 101 INVITE
Contact: <105>
Content-Length: 0
*Mar 19 14:20:38.917: //1928/01DF53E681C3/CCAPI/cc_api_call_alert:
   Interface=0x4ACF5228, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
   Call Entry(Retry Count=0, Responsed=TRUE)
*Mar 19 14:20:38.917: //1927/01DF53E681C3/CCAPI/ccCallAlert:
   Call Entry(Responsed=TRUE, Alert Sent=TRUE)
*Mar 19 14:20:38.921: //1927/01DF53E681C3/SIP/Msg/ccsipDisplayMsg:
Sent:
ld-rtr#SIP/2.0 180 Ringing
To: <105>;tag=315A5FC-5F4
CSeq: 9290 INVITE
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Contact: <105>
Content-Length: 0
ld-rtr#
*Mar 19 14:20:46.589: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CANCEL sip:105@50.151.94.216:5060 SIP/2.0
To: <105>
CSeq: 9290 CANCEL
User-Agent: GVGW
Max-Forwards: 70
Content-Length: 0
*Mar 19 14:20:46.589: //1927/01DF53E681C3/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x4ACF5228, Call Id=1927
   Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
*Mar 19 14:20:46.589: //1928/01DF53E681C3/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
*Mar 19 14:20:46.593: //1928/01DF53E681C3/CCAPI/ccCallDisconnect:
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
*Mar 19 14:20:46.593: //1927/01DF53E681C3/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
*Mar 19 14:20:46.597: //1927/01DF53E681C3/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <105>
Date: Tue, 19 Mar 2013 14:20:46 GMT
CSeq: 9290 CANCEL
Content-Length: 0
*Mar 19 14:20:46.597: //1928/01DF53E681C3/SIP/Msg/ccsipDisplayMsg:
Sent:
CANCEL sip:105@192.168.1.104:42921 SIP/2.0
To: <105>
CSeq: 101 CANCEL
Max-Forwards: 70
Timestamp: 1363702846
Reason: Q.850;cause=16
Content-Length: 0
Sent:
SIP/2.0 487 Request Cancelled
CSeq: 9290 INVITE
Content-Length: 0
*Mar 19 14:20:46.601: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:105@50.151.94.216:5060 SIP/2.0
Reason: SIP;text="Request Terminated"
Via: SIP/2.0/UDP 199.30.56.199:5060;rport;branch=z9hG4bK1891536881
CSeq: 9291 BYE
User-Agent: GVGW
Max-Forwards: 70
Content-Length: 0
*Mar 19 14:20:46.601: //1927/01DF53E681C3/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 9291 BYE
P-RTP-Stat: PS=0,OS=0,PR=0,OR=0,PL=0,JI=0,LA=0,DU=51758
Content-Length: 0
*Mar 19 14:20:46.641: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:105@50.151.94.216:5060 SIP/2.0
CSeq: 9290 ACK
Max-Forwards: 20
User-Agent: GVGW
Content-Length: 0
*Mar 19 14:20:46.641: //1927/01DF53E681C3/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x4ACF5228, Tag=0x0, Call Id=1927,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
*Mar 19 14:20:46.641: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Mar 19 14:20:46.641: :cc_free_feature_vsa freeing 4E5EC630
*Mar 19 14:20:46.641:  vsacount in free is 1
*Mar 19 14:20:46.733: //1928/01DF53E681C3/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 CANCEL
Content-Length: 0
*Mar 19 14:20:46.733: //1928/01DF53E681C3/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x4ACF5228, Tag=0x0, Call Id=1928,
*Mar 19 14:20:46.733: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Mar 19 14:20:46.733: :cc_free_feature_vsa freeing 4E5EC7F0
*Mar 19 14:20:46.733:  vsacount in free is 0
*Mar 19 14:20:46.737: //1928/01DF53E681C3/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 487 Request Terminated
CSeq: 101 INVITE
Content-Length: 0
*Mar 19 14:20:46.741: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ld-rtr#ACK sip:105@192.168.1.104:42921 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
The call trace shows that the called number is extension 105. Do you have any direct inward dial maps setup with the SIP trunk provider to map 8154960448 to 105?
Can you repeat the call debug test with sip phone disconnected so we can see what the call looks like when it is actually ringing your hunt group?
ld-rtr#
*Mar 19 20:55:49.982: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
OPTIONS sip:8153154009@172.16.100.32:5060;ep=172.16.100.32;fw=98.226.116.196 SIP/2.0
Via: SIP/2.0/UDP 206.15.148.180:5060;branch=z9hG4bK0mkh2c10fgdgonsbm4g1
To: <>8153154009@sip.broadvoice.com>
Date: Tue, 19 Mar 2013 20:54:22 GMT
Call-ID: FC007758-900D11E2-8002893D-37EA3615
Max-Forwards: 69
Timestamp: 1363726462
CSeq: 3 OPTIONS
Contact: <206.15.148.180:5060>
Expires: 3600
Authorization: Digest username="8153154009",realm="BroadWorks",uri="sip:sip.broadvoice.com:5060",response="2dda51b5b5362fa8675c2730709953cd",nonce="BroadWorksXhehig96fT6vq3mjBW",cnonce="2DF648F0",qop=auth,algorithm=MD5,nc=00000001
Content-Length: 0
*Mar 19 20:55:49.986: //16/2683E3D28019/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <>8153154009@sip.broadvoice.com>;tag=329C8-215E
Date: Tue, 19 Mar 2013 20:55:49 GMT
CSeq: 3 OPTIONS
Accept: application/sdp
ld-rtr#,resource-priority,replaces,sdp-anat
Content-Length: 175
v=0
o=CiscoSystemsSIP-GW-UserAgent 8339 3815 IN IP4 98.226.116.196
s=SIP Call
c=IN IP4 98.226.116.196
t=0 0
m=audio 0 RTP/AVP 18 0 8 9 4 2 15 3
ld-rtr#
*Mar 19 20:55:53.982: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 69
CSeq: 3 OPTIONS
Expires: 3600
Content-Length: 0
*Mar 19 20:55:53.986: //16/2683E3D28019/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Tue, 19 Mar 2013 20:55:53 GMT
CSeq: 3 OPTIONS
Content-Length: 175
v=0
s=SIP Call
t=0 0
ld-rtr#
*Mar 19 20:56:02.686: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:200@98.226.116.196:5060 SIP/2.0
Max-Forwards: 20
Via: SIP/2.0/UDP 199.30.56.199:5060;rport;branch=z9hG4bK2147213811
To: <200>
Call-ID: 1137609921@199.30.56.199
CSeq: 9438 INVITE
User-Agent: GVGW
Content-Length: 185
v=0
o=yate 1363724529 1363724529 IN IP4 199.30.56.199
s=SIP Call
t=0 0
m=audio 27358 RTP/AVP 0 101
*Mar 19 20:56:02.694: //-1/3E7DBAE1801A/CCAPI/cc_api_display_ie_subfields:
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=500
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
*Mar 19 20:56:02.694: //-1/3E7DBAE1801A/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x4A8E35A8, Call Info(
   Called Number=500(TON=Unknown, NPI=Unknown),
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=17
*Mar 19 20:56:02.694: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Mar 19 20:56:02.694: :cc_get_feature_vsa malloc success
*Mar 19 20:56:02.694:  cc_get_feature_vsa count is 1
*Mar 19 20:56:02.694: :FEATURE_VSA attributes are: feature_name:0,feature_time:1310451536,feature_id:4
*Mar 19 20:56:02.694: //17/3E7DBAE1801A/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Called Number=500(TON=Unknown, NPI=Unknown))
*Mar 19 20:56:02.698: //17/3E7DBAE1801A/CCAPI/cc_process_call_setup_ind:
   Event=0x4B05DE20
*Mar 19 20:56:02.698: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 500
*Mar 19 20:56:02.698: //17/3E7DBAE1801A/CCAPI/ccCallSetContext:
   Context=0x48B02428
   >>>>CCAPI handed cid 17 with tag 0 to app "_ManagedAppProcess_Default"
*Mar 19 20:56:02.698: //17/3E7DBAE1801A/CCAPI/ccCallProceeding:
*Mar 19 20:56:02.702: //17/3E7DBAE1801A/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=20002, Params=0x48B03890, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
*Mar 19 20:56:02.702: //17/3E7DBAE1801A/CCAPI/ccCheckClipClir:
   Destination Pattern=100$, Called Number=100, Digit Strip=TRUE
   Called Number=100(TON=Unknown, NPI=Unknown),
   Guid=3E7DBAE1-900E-11E2-801A-893D37EA3615, Outgoing Dial-peer=20002
*Mar 19 20:56:02.702: //17/3E7DBAE1801A/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=100
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
*Mar 19 20:56:02.702: //17/3E7DBAE1801A/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x4C183844, Interface Type=6, Destination=, Mode=0x0,
   Called Number=100(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=20002, Call Count On=FALSE,
*Mar 19 20:56:02.702: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Mar 19 20:56:02.702: :cc_get_feature_vsa malloc success
*Mar 19 20:56:02.702:  cc_get_feature_vsa count is 2
*Mar 19 20:56:02.702: :FEATURE_VSA attributes are: feature_name:0,feature_time:1310451088,feature_id:5
*Mar 19 20:56:02.702: //18/3E7DBAE1801A/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
*Mar 19 20:56:02.702: //18/3E7DBAE1801A/CCAPI/ccCallSetContext:
   Context=0x48B03840
*Mar 19 20:56:02.702: //17/3E7DBAE1801A/CCAPI/ccSaveDialpeerTag:
*Mar 19 20:56:02.706: //17/3E7DBAE1801A/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=20001, Params=0x48B04CA8, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
*Mar 19 20:56:02.706: //17/3E7DBAE1801A/CCAPI/ccCheckClipClir:
   Destination Pattern=102$, Called Number=102, Digit Strip=TRUE
   Called Number=102(TON=Unknown, NPI=Unknown),
   Guid=3E7F8F58-900E-11E2-8020-893D37EA3615, Outgoing Dial-peer=20001
*Mar 19 20:56:02.706: //17/3E7DBAE1801A/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=102
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
*Mar 19 20:56:02.706: //17/3E7DBAE1801A/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x4C17DFCC, Interface Type=6, Destination=, Mode=0x0,
   Called Number=102(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=20001, Call Count On=FALSE,
*Mar 19 20:56:02.706: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Mar 19 20:56:02.706: :cc_get_feature_vsa malloc success
*Mar 19 20:56:02.706:  cc_get_feature_vsa count is 3
*Mar 19 20:56:02.706: :FEATURE_VSA attributes are: feature_name:0,feature_time:1310451312,feature_id:6
*Mar 19 20:56:02.706: //19/3E7DBAE1801A/CCAPI/ccIFCallSetupRequestPrivate:
*Mar 19 20:56:02.706: //19/3E7DBAE1801A/CCAPI/ccCallSetContext:
   Context=0x48B04C58
*Mar 19 20:56:02.706: //17/3E7DBAE1801A/CCAPI/ccSaveDialpeerTag:
*Mar 19 20:56:02.710: //18/3E7DBAE1801A/CCAPI/cc_api_update_call_info:
   Interface=0x4C183844, Call Id=0x12
*Mar 19 20:56:02.714: //19/3E7DBAE1801A/CCAPI/cc_api_update_call_info:
   Interface=0x4C17DFCC, Call Id=0x13
*Mar 19 20:56:02.714: //18/3E7DBAE1801A/CCAPI/cc_api_call_proceeding:
   Interface=0x4C183844, Progress Indication=NULL(0)
*Mar 19 20:56:02.714: //19/3E7DBAE1801A/CCAPI/cc_api_call_proceeding:
   Interface=0x4C17DFCC, Progress Indication=NULL(0)
*Mar 19 20:56:02.718: //18/3E7DBAE1801A/CCAPI/cc_api_call_alert:
   Interface=0x4C183844, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
*Mar 19 20:56:02.718: //19/3E7DBAE1801A/CCAPI/cc_api_call_alert:
   Interface=0x4C17DFCC, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
*Mar 19 20:56:02.722: //17/3E7DBAE1801A/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To: <200>
Date: Tue, 19 Mar 2013 20:56:02 GMT
CSeq: 9438 INVITE
Content-Length: 0
*Mar 19 20:56:02.722: //17/3E7DBAE1801A/CCAPI/ccCallAlert:
*Mar 19 20:56:02.722: //18/3E7DBAE1801A/CCAPI/ccCallFeature:
   Feature Type=25, Call Id=18
*Mar 19 20:56:02.722: //17/3E7DBAE1801A/CCAPI/ccCallNotify:
   Data Bitmask=0x7, Call Id=17
*Mar 19 20:56:02.730: //17/3E7DBAE1801A/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
To: <200>;tag=3C70C-1F3D
CSeq: 9438 INVITE
Contact: <200>
Content-Length: 0
*Mar 19 20:56:02.846: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ld-rtr#REGISTER sip:sip.broadvoice.com:5060 SIP/2.0
Via: SIP/2.0/UDP 98.226.116.196:5060;branch=z9hG4bK13558
From: <>8153154009@sip.broadvoice.com>;tag=3C780-1C34
Max-Forwards: 70
Timestamp: 1363726562
CSeq: 4 REGISTER
Contact: <8153154009>
Expires:  3600
Supported: path
Content-Length: 0
*Mar 19 20:56:03.342: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Tue, 19 Mar 2013 20:56:03 GMT
Max-Forwards: 70
Timestamp: 1363726563
CSeq: 4 REGISTER
Expires:  3600
Supported: path
Content-Length: 0
*Mar 19 20:56:04.342: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Tue, 19 Mar 2013 20:56:04 GMT
Max-Forwards: 70
Timestamp: 1363726564
CSeq: 4 REGISTER
Expires:  3600
Supported: path
Content-Length: 0
ld-rtr#
*Mar 19 20:56:05.522: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CANCEL sip:200@98.226.116.196:5060 SIP/2.0
To: <200>
CSeq: 9438 CANCEL
User-Agent: GVGW
Max-Forwards: 70
Content-Length: 0
*Mar 19 20:56:05.526: //17/3E7DBAE1801A/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x4A8E35A8, Call Id=17
*Mar 19 20:56:05.526: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:200@98.226.116.196:5060 SIP/2.0
Via: SIP/2.0/UDP 199.30.56.199:5060;rport;branch=z9hG4bK2109160574
CSeq: 9439 BYE
User-Agent: GVGW
Max-Forwards: 70
Content-Length: 0
*Mar 19 20:56:05.526: //18/3E7DBAE1801A/CCAPI/ccCallDisconnect:
*Mar 19 20:56:05.526: //18/3E7DBAE1801A/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
*Mar 19 20:56:05.530: //19/3E7DBAE1801A/CCAPI/ccCallDisconnect:
   Cause Value=0, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
   Cause Value=0, Call Entry(Responsed=TRUE, Cause Value=0)
*Mar 19 20:56:05.530: //19/3E7DBAE1801A/CCAPI/cc_api_get_transfer_info:
*Mar 19 20:56:05.530: //17/3E7DBAE1801A/CCAPI/ccCallDisconnect:
*Mar 19 20:56:05.538: //18/3E7DBAE1801A/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x4C183844, Tag=0x0, Call Id=18,
*Mar 19 20:56:05.538: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Mar 19 20:56:05.538: :cc_free_feature_vsa freeing 4E1BE588
*Mar 19 20:56:05.538:  vsacount in free is 2
*Mar 19 20:56:05.538: //19/3E7DBAE1801A/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x4C17DFCC, Tag=0x0, Call Id=19,
   Call Entry(Disconnect Cause=0, Voice Class Cause Code=0, Retry Count=0)
*Mar 19 20:56:05.538: :cc_free_feature_vsa freeing 4E1BE668
*Mar 19 20:56:05.538:  vsacount in free is 1
*Mar 19 20:56:05.542: //17/3E7DBAE1801A/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <200>
Date: Tue, 19 Mar 2013 20:56:05 GMT
CSeq: 9438 CANCEL
Content-Length: 0
Sent:
SIP/2.0 200 OK
CSeq: 9439 BYE
P-RTP-Stat: PS=0,OS=0,PR=0,OR=0,PL=0,JI=0,LA=0,DU=250
Content-Length: 0
*Mar 19 20:56:05.546: //17/3E7DBAE1801A/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 9438 INVITE
Content-Length: 0
*Mar 19 20:56:05.582: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:200@98.226.116.196:5060 SIP/2.0
CSeq: 9438 ACK
Max-Forwards: 20
User-Agent: GVGW
Content-Length: 0
*Mar 19 20:56:05.586: //17/3E7DBAE1801A/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x4A8E35A8, Tag=0x0, Call Id=17,
ld-rtr#Call Disconnect Event Sent
*Mar 19 20:56:05.586: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Mar 19 20:56:05.586: :cc_free_feature_vsa freeing 4E1BE748
*Mar 19 20:56:05.586:  vsacount in free is 0
*Mar 19 20:56:06.342: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Tue, 19 Mar 2013 20:56:06 GMT
Max-Forwards: 70
Timestamp: 1363726566
CSeq: 4 REGISTER
Expires:  3600
Supported: path
Content-Length: 0
This time the invite message shows that the sip trunk provider is sending the call to extension 200 (which by the looks of it you translate to 500). One thing I do notice is that the first call (with the sip phone registered) the invite is sent to IP address 50.151.94.216 where as the second call is sent to IP address 98.226.116.196. Do you know if these IP addresses are assigned to your router?
Also we're you able to check if there are any DID maps/translations configured at the trunk provider?
You can disregard the ip change. That was me working on another issue. Yes I do have 200 translated over to 500 which works fine cause when calling 8154960448 is comes in to that extension if there is no sip registered. As soon as I register a SIP phone is changes the incoming over to the SIP phones extension and only rings that phone. I dont think there are any DID maps on the trunk provider the trunk provider is a generic gateway which is translating a google talk account over to a asterisk sip server and then I am connecting to that. One thing I noticed in the past awhile ago I recall while debugging that there was no number listed as the number called.
daniel.bloom
It looks like the issue is external to your CME router. The first call was sent to extension 105 and the second call was sent to extension 200. Do you have control of the asterisk server or is that controlled by another party? It would appear that the call is treated differently either by the asterisk server or by the translation from the google talk account.
Nope no control over the astrisk server. Heres one thing that is strange also. After I register the SIP Phone all calls goto the SIP phone and can see everything on the debug log. After I unregister the SIP IP Phone its like CME unregisters from the SIP Truck cause then it doesn show anything in the log when dialing in. Then if I go back to the SIP phone and register it starts working with the SIP Phone again. lol. Here's a log of me doing this.
Timestamp: 1363734289
CSeq: 2 REGISTER
Contact: <106>
Expires:  3600
Supported: path
Content-Length: 0
*Mar 19 23:04:49.824: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 98.226.116.196:5060;branch=z9hG4bK18C115A
To: <>106@sip.broadvoice.com>
Date: Tue, 19 Mar 2013 23:04:49 GMT
Call-ID: 3C378C24-902011E2-80D9893D-37EA3615
Max-Forwards: 70
CSeq: 2 REGISTER
Contact: <106>
Expires:  3600
Supported: path
Content-Length: 0
*Mar 19 23:04:49.868: //434/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 404 Not found
To: <>106@sip.broadvoice.com>;tag=317573053-1363734519684
CSeq: 2 REGISTER
Content-Length: 0
*Mar 19 23:04:49.872: //435/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 98.226.116.196:5060;branch=z9hG4bK18B1051;received=98.226.116.196
To: <>106@gvgw2.simonics.com>
Call-ID: 3C378C24-902011E2-80DA893D-37EA3615
CSeq: 2 REGISTER
Server: GVGW
Content-Length: 0
*Mar 19 23:04:49.880: //435/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 2 REGISTER
WWW-Authenticate: Digest realm="GVGW", nonce="d1c3999d3f76acb4fb7718eb014e8f52.1363734290", stale=FALSE, algorithm=MD5
Server: GVGW
Content-Length: 0
*Mar 19 23:04:49.884: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
REGISTER sip:gvgw2.simonics.com:5060 SIP/2.0
Via: SIP/2.0/UDP 98.226.116.196:5060;branch=z9hG4bK18D1B42
Max-Forwards: 70
CSeq: 3 REGISTER
Contact: <106>
Expires: 3600
Authorization: Digest username="GV18154960448",realm="GVGW",uri="sip:gvgw2.simonics.com:5060",response="5d351d06445e102e2486dede0bcefc3e",nonce="d1c3999d3f76acb4fb7718eb014e8f52.1363734290",algorithm=MD5
Content-Length: 0
*Mar 19 23:04:49.936: //435/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 98.226.116.196:5060;branch=z9hG4bK18D1B42;received=98.226.116.196
CSeq: 3 REGISTER
Server: GVGW
Content-Length: 0
*Mar 19 23:04:49.940: //435/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
ld-rtr#SIP/2.0 200 OK
To: <>106@gvgw2.simonics.com>;tag=279194923
CSeq: 3 REGISTER
Expires: 3600
Contact: <106>;expires=3600
Server: GVGW
Content-Length: 0
ld-rtr#
*Mar 19 23:04:59.380: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:106@98.226.116.196:5060 SIP/2.0
Max-Forwards: 20
Via: SIP/2.0/UDP 199.30.56.199:5060;rport;branch=z9hG4bK1409774254
To: <106>
Call-ID: 1028908803@199.30.56.199
CSeq: 9540 INVITE
User-Agent: GVGW
Content-Length: 185
v=0
o=yate 1363734299 1363734299 IN IP4 199.30.56.199
s=SIP Call
t=0 0
m=audio 29546 RTP/AVP 0 101
*Mar 19 23:04:59.384: //-1/xxxxxxxxxxxx/CCAPI/cc_set_post_tagdata:
   CALL_ERROR; Avlist Set Is Failed
*Mar 19 23:04:59.388: //-1/41EB8CE180DB/CCAPI/cc_api_display_ie_subfields:
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=106
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
*Mar 19 23:04:59.388: //-1/41EB8CE180DB/CCAPI/cc_api_call_setup_ind_common:
   Called Number=106(TON=Unknown, NPI=Unknown),
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=436
*Mar 19 23:04:59.388: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Mar 19 23:04:59.388: :cc_get_feature_vsa malloc success
*Mar 19 23:04:59.388:  cc_get_feature_vsa count is 1
*Mar 19 23:04:59.388: :FEATURE_VSA attributes are: feature_name:0,feature_time:1310451088,feature_id:67
*Mar 19 23:04:59.388: //436/41EB8CE180DB/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Called Number=106(TON=Unknown, NPI=Unknown))
*Mar 19 23:04:59.392: //436/41EB8CE180DB/CCAPI/cc_process_call_setup_ind:
   Event=0x4B05DE20
*Mar 19 23:04:59.392: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 106
*Mar 19 23:04:59.392: //436/41EB8CE180DB/CCAPI/ccCallSetContext:
   Context=0x48B03840
   >>>>CCAPI handed cid 436 with tag 0 to app "_ManagedAppProcess_Default"
*Mar 19 23:04:59.392: //436/41EB8CE180DB/CCAPI/ccCallProceeding:
*Mar 19 23:04:59.392: //436/41EB8CE180DB/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=40001, Params=0x48B04CA8, Progress Indication=NULL(0)
*Mar 19 23:04:59.392: //436/41EB8CE180DB/CCAPI/ccCheckClipClir:
*Mar 19 23:04:59.396: //436/41EB8CE180DB/CCAPI/ccCheckClipClir:
*Mar 19 23:04:59.396: //436/41EB8CE180DB/CCAPI/ccCallSetupRequest:
   Destination Pattern=106, Called Number=106, Digit Strip=FALSE
   Guid=41EB8CE1-9020-11E2-80DB-893D37EA3615, Outgoing Dial-peer=40001
*Mar 19 23:04:59.396: //436/41EB8CE180DB/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=106
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
*Mar 19 23:04:59.396: //436/41EB8CE180DB/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x4A8E35A8, Interface Type=3, Destination=, Mode=0x0,
   Called Number=106(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
*Mar 19 23:04:59.396: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Mar 19 23:04:59.396: :cc_get_feature_vsa malloc success
*Mar 19 23:04:59.396:  cc_get_feature_vsa count is 2
*Mar 19 23:04:59.396: :FEATURE_VSA attributes are: feature_name:0,feature_time:1310450640,feature_id:68
*Mar 19 23:04:59.396: //437/41EB8CE180DB/CCAPI/ccIFCallSetupRequestPrivate:
*Mar 19 23:04:59.396: //437/41EB8CE180DB/CCAPI/ccCallSetContext:
   Context=0x48B04C58
*Mar 19 23:04:59.396: //436/41EB8CE180DB/CCAPI/ccSaveDialpeerTag:
*Mar 19 23:04:59.400: //437/41EB8CE180DB/CCAPI/cc_api_call_proceeding:
   Interface=0x4A8E35A8, Progress Indication=NULL(0)
*Mar 19 23:04:59.404: //436/41EB8CE180DB/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To: <106>
Date: Tue, 19 Mar 2013 23:04:59 GMT
CSeq: 9540 INVITE
Content-Length: 0
*Mar 19 23:04:59.408: //437/41EB8CE180DB/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:106@192.168.1.104:61573 SIP/2.0
Via: SIP/2.0/UDP 192.168.1.1:5060;branch=z9hG4bK18E23B
To: <106>
Call-ID: 41EDFD81-902011E2-80E1893D-37EA3615@192.168.1.1
Min-SE:  1800
Cisco-Guid: 1105956065-2418020834-2161871165-0938096149
CSeq: 101 INVITE
Timestamp: 1363734299
Expires: 180
Max-Forwards: 19
Content-Length: 212
v=0
o=CiscoSystemsSIP-GW-UserAgent 4312 4932 IN IP4 192.168.1.1
s=SIP Call
t=0 0
m=audio 17318 RTP/AVP 0 19
a=rtpmap:19 CN/8000
a=ptime:20
*Mar 19 23:04:59.608: //437/41EB8CE180DB/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 192.168.1.1:5060;received=192.168.1.1;branch=z9hG4bK18E23B
To: <106>
CSeq: 101 INVITE
Content-Length:  0
*Mar 19 23:04:59.612: //437/41EB8CE180DB/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To: <106>;tag=d7Zzx7Kp-.GQ0aRBxR.N58MfGvU7F.sL
CSeq: 101 INVITE
Contact: "106" <106>
Allow: PRACK, INVITE, ACK, BYE, CANCEL, UPDATE, INFO, SUBSCRIBE, NOTIFY, REFER, MESSAGE, OPTIONS
Content-Length:  0
*Mar 19 23:04:59.612: //437/41EB8CE180DB/CCAPI/cc_api_call_alert:
   Interface=0x4A8E35A8, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
*Mar 19 23:04:59.612: //436/41EB8CE180DB/CCAPI/ccCallAlert:
*Mar 19 23:04:59.616: //436/41EB8CE180DB/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
To: <106>;tag=98DB70-1F75
CSeq: 9540 INVITE
Contact: <106>
Content-Length: 0
*Mar 19 23:04:59.624: //437/41EB8CE180DB/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 101 INVITE
Content-Length:  0
ld-rtr#
*Mar 19 23:05:03.852: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CANCEL sip:106@98.226.116.196:5060 SIP/2.0
To: <106>
CSeq: 9540 CANCEL
User-Agent: GVGW
Max-Forwards: 70
Content-Length: 0
*Mar 19 23:05:03.856: //436/41EB8CE180DB/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x4A8E35A8, Call Id=436
*Mar 19 23:05:03.856: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:106@98.226.116.196:5060 SIP/2.0
Via: SIP/2.0/UDP 199.30.56.199:5060;rport;branch=z9hG4bK2022564638
CSeq: 9541 BYE
User-Agent: GVGW
Max-Forwards: 70
Content-Length: 0
*Mar 19 23:05:03.856: //437/41EB8CE180DB/CCAPI/ccCallDisconnect:
*Mar 19 23:05:03.860: //436/41EB8CE180DB/CCAPI/ccCallDisconnect:
*Mar 19 23:05:03.864: //436/41EB8CE180DB/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <106>
Date: Tue, 19 Mar 2013 23:05:03 GMT
CSeq: 9540 CANCEL
Content-Length: 0
Sent:
SIP/2.0 200 OK
CSeq: 9541 BYE
P-RTP-Stat: PS=0,OS=0,PR=0,OR=0,PL=0,JI=0,LA=0,DU=10021
Content-Length: 0
*Mar 19 23:05:03.864: //437/41EB8CE180DB/SIP/Msg/ccsipDisplayMsg:
Sent:
CANCEL sip:106@192.168.1.104:61573 SIP/2.0
To: <106>
CSeq: 101 CANCEL
Max-Forwards: 70
Timestamp: 1363734303
Content-Length: 0
*Mar 19 23:05:03.868: //436/41EB8CE180DB/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 9540 INVITE
Content-Length: 0
*Mar 19 23:05:03.912: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:106@98.226.116.196:5060 SIP/2.0
CSeq: 9540 ACK
Max-Forwards: 20
User-Agent: GVGW
Content-Length: 0
*Mar 19 23:05:03.912: //436/41EB8CE180DB/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x4A8E35A8, Tag=0x0, Call Id=436,
*Mar 19 23:05:03.912: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Mar 19 23:05:03.912: :cc_free_feature_vsa freeing 4E1BE588
*Mar 19 23:05:03.912:  vsacount in free is 1
*Mar 19 23:05:04.012: //437/41EB8CE180DB/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 CANCEL
Content-Length:  0
*Mar 19 23:05:04.012: //437/41EB8CE180DB/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x4A8E35A8, Tag=0x0, Call Id=437,
*Mar 19 23:05:04.012: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Mar 19 23:05:04.012: :cc_free_feature_vsa freeing 4E1BE3C8
*Mar 19 23:05:04.012:  vsacount in free is 0
*Mar 19 23:05:04.016: //437/41EB8CE180DB/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 101 INVITE
Content-Length:  0
*Mar 19 23:05:04.016: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ld-rtr#ACK sip:106@192.168.1.104:61573 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
ld-rtr#
*Mar 19 23:05:19.845: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ld-rtr#
*Mar 19 23:05:36.201: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 98.226.116.196:5060;branch=z9hG4bK18F2C7
From: <>GV18154960448@sip.broadvoice.com>;tag=996A58-E1A
To: <>GV18154960448@sip.broadvoice.com>
Date: Tue, 19 Mar 2013 23:05:36 GMT
Call-ID: FC38014C-900D11E2-8003893D-37EA3615
Max-Forwards: 70
Timestamp: 1363734336
CSeq: 57 REGISTER
Contact:
Expires:  3600
Supported: path
Content-Length: 0
*Mar 19 23:05:36.205: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 98.226.116.196:5060;branch=z9hG4bK1901F1F
To: <>102@sip.broadvoice.com>
Call-ID: FCE69066-900D11E2-8006893D-37EA3615
Max-Forwards: 70
CSeq: 57 REGISTER
Contact: <102>
Expires:  3600
Supported: path
Content-Length: 0
Sent:
Via: SIP/2.0/UDP 98.226.116.196:5060;branch=z9hG4bK1911E0
To: <>100@sip.broadvoice.com>
Call-ID: FCE72C8E-900D11E2-8008893D-37EA3615
Max-Forwards: 70
CSeq: 57 REGISTER
Contact: <100>
Expires:  3600
Supported: path
Content-Length: 0
*Mar 19 23:05:36.265: //438/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
To: <>GV18154960448@sip.broadvoice.com>;tag=2134149879-1363734566078
CSeq: 57 REGISTER
Content-Length: 0
*Mar 19 23:05:36.277: //439/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
To: <>102@sip.broadvoice.com>;tag=1666449784-1363734566085
CSeq: 57 REGISTER
Content-Length: 0
*Mar 19 23:05:36.277: //440/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
To: <>100@sip.broadvoice.com>;tag=868653407-1363734566088
CSeq: 57 REGISTER
Content-Length: 0
*Mar 19 23:05:36.573: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 98.226.116.196:5060;branch=z9hG4bK1927EE
To: <>103@sip.broadvoice.com>
Call-ID: FCE72C8E-900D11E2-800A893D-37EA3615
Max-Forwards: 70
CSeq: 57 REGISTER
Contact: <103>
Expires:  3600
Supported: path
Content-Length: 0
*Mar 19 23:05:36.617: //441/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
ld-rtr#SIP/2.0 404 Not found
To: <>103@sip.broadvoice.com>;tag=282590174-1363734566430
CSeq: 57 REGISTER
Content-Length: 0
ld-rtr#
*Mar 19 23:05:49.849: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ld-rtr#
*Mar 19 23:06:00.642: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 98.226.116.196:5060;branch=z9hG4bK1932226
To: <>200@sip.broadvoice.com>
Date: Tue, 19 Mar 2013 23:06:00 GMT
Call-ID: FD0821C0-900D11E2-800C893D-37EA3615
Max-Forwards: 70
Timestamp: 1363734360
CSeq: 57 REGISTER
Contact: <200>
Expires:  3600
Supported: path
Content-Length: 0
*Mar 19 23:06:00.694: //442/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
To: <>200@sip.broadvoice.com>;tag=1171700645-1363734590498
CSeq: 57 REGISTER
Content-Length: 0
ld-rtr#
*Mar 19 23:06:19.850: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ld-rtr#
*Mar 19 23:06:49.851: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ld-rtr#
*Mar 19 23:07:19.855: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ld-rtr#
*Mar 19 23:07:24.848: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.1.104:61573;rport;branch=z9hG4bKPjJU55lVCFMUo7VlhiPMStAeGaIPrfaG-u
Max-Forwards: 70
From: "106" <106>;tag=cwxh2e3RXXExuEb6XcLgzgZZ3Zp3Ec2O
To: "106" <106>
Call-ID: VJA5PsnRoiG3fGKIGi8vNGPP1OCjr1Ul
CSeq: 32925 REGISTER
User-Agent: Bria iOS 2.4.0
Supported: outbound, path
Contact: "106" <106>;reg-id=1;+sip.instance=""
Expires: 900
Content-Length:  0
*Mar 19 23:07:24.852: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To: "106" <106>
Date: Tue, 19 Mar 2013 23:07:24 GMT
Content-Length: 0
*Mar 19 23:07:24.852: //443/989F822A80E2/SIP/Msg/ccsipDisplayMsg:
Sent:
To: "106" <106>;tag=9B12BC-12BE
WWW-Authenticate: Digest realm="liquiddigital.us",nonce="FB9CCCEC000F81DF",algorithm=MD5,qop="auth"
Content-Length: 0
*Mar 19 23:07:24.864: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.1.104:61573;rport;branch=z9hG4bKPjlbhCTIfUb8hAh5g8LbR-rOeM6qnl900f
Max-Forwards: 70
To: "106" <106>
CSeq: 32926 REGISTER
Expires: 900
Authorization: Digest username="106", realm="liquiddigital.us", nonce="FB9CCCEC000F81DF", uri="sip:192.168.1.1", response="2a2e906399ae12629b141de68f401e43", algorithm=MD5, cnonce="et8Qe4Ki67G84Eryp-KTqBPMNJRajGnQ", qop=auth, nc=00000001
Content-Length:  0
*Mar 19 23:07:24.868: //443/989F822A80E2/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Content-Length: 0
Sent:
Contact: <106>;expires=160
Expires:  160
Content-Length: 0
ld-rtr#
*Mar 19 23:07:49.876: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 98.226.116.196:5060;branch=z9hG4bK194B8E
Date: Tue, 19 Mar 2013 23:07:49 GMT
Max-Forwards: 70
Timestamp: 1363734469
CSeq: 3 REGISTER
Contact: <106>
Expires:  3600
Supported: path
Content-Length: 0
*Mar 19 23:07:49.920: //444/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
To: <>106@sip.broadvoice.com>;tag=1634465366-1363734699731
CSeq: 3 REGISTER
Content-Length: 0
ld-rtr#
*Mar 19 23:07:54.892: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ld-rtr#
*Mar 19 23:08:04.016: //-1/xxxxxxxxxxxx/CCAPI/ccAppShutdownMode:
   ccAppShutdownMode: remove it from the queue
voice register dn x
no-reg
The no-reg fixed it. It seems to be working now!
Excellent. It looks like this provider didn't like having multiple registrations and they would route calls to the newest registration.
Your the man thanks so much. My hair can now grow back again.
