problem with sip trunk between gw and ToIP ISP in incoming calls
juanluis
Hi, I have this VoIP network: SIP Server -- GW -- PSTN, with E1 link to PSTN, the gw and SIP server and GW are in the same LAN.
I can see the sip-ua is registered:
GW#show sip-ua register status
Line                              peer        expires(sec)  registered
.*                                2           154           no
90001                             -1          94            yes
GW#show sip-ua connections udp detail
Remote-Agent:192.168.4.21, Connections-Count:1
  Remote-Port Conn-Id Conn-State  WriteQ-Size
         6060       2 Established           0
The outgoing calls are working fine with phones registered in sip server. But I dont get work the incoming calls from pstn. This is the involved config:
voice service pots
supported-language es
supplementary-service qsig call-forward
voice service voip
dtmf-interworking rtp-nte
allow-connections h323 to sip
allow-connections sip to sip
redirect ip2ip
signaling forward unconditional
fax protocol t38 nse force ls-redundancy 0 hs-redundancy 0 fallback none
sip
  bind control source-interface GigabitEthernet0/0
  bind media source-interface GigabitEthernet0/0
  registrar server expires max 3600 min 3600
  no update-callerid
  early-offer forced
  midcall-signaling passthru
voice class codec 1
codec preference 1 transparent
codec preference 2 g711alaw
codec preference 3 g711ulaw
controller E1 0/3/1
framing NO-CRC4
pri-group timeslots 1-31
interface Serial0/3/1:15
no ip address
encapsulation hdlc
isdn switch-type primary-qsig
isdn incoming-voice voice
no cdp enable
bearer-cap 3100Hz
voice-port 0/3/1:15
echo-cancel coverage 64
cptone ES
connection plar 951016650
dial-peer voice 2 pots
description outgoing calls
destination-pattern .T
port 0/3/1:15
dial-peer voice 1 voip
description incoming calls
destination-pattern 951016650
voice-class codec 1
session protocol sipv2
session target ipv4:192.168.4.21:6060
dtmf-relay sip-notify h245-alphanumeric
sip-ua
credentials username 90001 password ****** realm 3CXPhoneSystem
keepalive target ipv4:192.168.4.21:6060
authentication username 90001 password ******
retry invite 3
retry response 3
retry bye 3
retry cancel 3
timers expires 300000
registrar ipv4:192.168.4.21:6060 expires 3600
sip-server ipv4:192.168.4.21:6060
I attach debug ccsip file.
I call from 952029343 to 951016650
Please, anyone can help me?, I have tried really a lot of commands and config but I dont get work the incoming calls.
Thanks in advance.
27 Replies 27
add incoming called-number. in this dial peer
incoming called-mumber .
port 0/3/1:15
Questions:
What is the extension number in sip server?(951016650)?
We need full running config
Need also debug isdn q931 to see how the incoming call coming from PSTN.
Please rate all useful posts Regards Chrysostomos ""The Most Successful People Are Those Who Are Good At Plan B""
I have tried the incoming called-number but it doesnt work. I send you the debug isdn q931.
That debug shows that in the beginnig the calling number is the real I use to test, 628436338, but then it changes to the same called number, 951016650. I dont know why it happens and if that is the reason the incoming call doesnt work.
The sip server doesnt have a extension with the called number, it has my gw defined and an incoming rule to send the calls to 951016650 to a operator private extension.
What is the version of the voice gateway ios
c3825-spservicesk9-mz.124-24.T3.bin
Can you remove codec preference 1 transparent and recheck?
Is really strange the debug for isdn
is any reason that you change the default port for sip?Sip server is configured also with this port? (6060)
Also why do you have a plar configured?
If you want all the incomimg numbers to translated to 951016650, then create a simple translation rule
I have rechecked but no success.
Here is the new debug. It keeps showing the change of calling number to the same called number, why?
Yes, there is a reason, the sip server have to listen in 6060 port because another instance of the same server is listen in 5060 port to other customer.
I have connection plar because I thought I need it, if it is not necessary please tell me another way to get the incoming calls work.
I have checked without the connection plar and this is the debug, it seems that the call doesnt progress. In calling phone now I can hear a continous tone, but with the connection plar command set I can hear nothing.
So, must I delete the connection plar config?
GW#
GW#
Oct  4 15:05:44.030: ISDN Se0/3/1:15 Q931: RX <- SETUP pd = 8  callref = 0x1A19
        Sending Complete
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA18386
                Preferred, Channel 6
        Calling Party Number i = 0x2183, '628436338'
                Plan:ISDN, Type:National
        Called Party Number i = 0xA1, '951016650'
Oct  4 15:05:44.034: %ISDN-6-CONNECT: Interface Serial0/3/1:5 is now connected to 628436338 N/A
Oct  4 15:05:44.038: ISDN Se0/3/1:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x9A19
        Channel ID i = 0xA98386
                Exclusive, Channel 6
Oct  4 15:05:44.038: ISDN Se0/3/1:15 Q931: TX -> CONNECT pd = 8  callref = 0x9A19
        Connected Number i = 0x80, '951016650'
Oct  4 15:05:44.106: ISDN Se0/3/1:15 Q931: RX <- CONNECT_ACK pd = 8  callref = 0x1A19
GW_INGENIA#
GW_INGENIA#
GW_INGENIA#
Oct  4 15:06:04.386: ISDN Se0/3/1:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x1A19
        Cause i = 0x829000000000 - Normal call clearing
        Progress Ind i = 0x8288 - In-band info or appropriate now available
Oct  4 15:06:04.386: %ISDN-6-DISCONNECT: Interface Serial0/3/1:5  disconnected from 628436338 , call lasted 20 seconds
Oct  4 15:06:04.386: ISDN Se0/3/1:15 Q931: TX -> RELEASE pd = 8  callref = 0x9A19
Oct  4 15:06:04.718: ISDN Se0/3/1:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x1A19
GW#
Yes i believe that you dont need the conenction plar.
can you try another one call with debug ccsip messages?
I need to have , incoming called-number . in pots dial peer
Remove the tranlsrent codec
Remove plar
The incoming call coming from PSTN is always 951016650?You dont need any translation?
Also the connection with the PSTN network is E1 PRI
So the correct
no ip address
encapsulation hdlc
isdn switch-type primary-net5 (If is europe)
no cdp enable
voice-port 0/3/1:15
cptone (cyptone of your country)
bearer-cap Speech
I have done all the config changes but it doesn work, I only can hear a continous tone.
That is to test the solution, when I get to work it is possible I have to do translation.
This is the debug:
GWA#
GW#
Oct  4 15:39:46.613: %ISDN-6-CONNECT: Interface Serial0/3/1:17 is now connected to 628436338 N/A
Oct  4 15:39:49.621: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/3/1:17, changed state to up
Oct  4 15:39:49.621: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_bind_if_comingup: The interface which is bound to SIP is comin up
Oct  4 15:39:58.389: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAddContextToTable: Added context(0x68B13C00) with key=[9961] to tabl
e
Oct  4 15:39:58.389: //20409/000000000000/SIP/State/sipSPIChangeState: 0x68B13C00 : State change from (STATE_NONE, SUBSTAT
E_NONE)  to (STATE_IDLE, SUBSTATE_NONE)
Oct  4 15:39:58.389: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for e
vent 37
Oct  4 15:39:58.389: //20409/000000000000/SIP/Info/sipSPIUaddccCallIdToTable: Adding call id 4FB9 to table
Oct  4 15:39:58.389: //20409/000000000000/SIP/Info/sipSPIUaddCcbToUACTable: ****Adding to UAC table.
Oct  4 15:39:58.389: //20409/000000000000/SIP/Info/sipSPIUaddCcbToTable: Added to table. ccb=0x68B13C00 key=D2C7C864-D5F11
E2-9DCE983E-D9D8E858@192.168.4.2
Oct  4 15:39:58.389: //20409/000000000000/SIP/State/sipSPIChangeState: 0x68B13C00 : State change from (STATE_IDLE, SUBSTAT
E_NONE)  to (SIP_STATE_OPTIONS_WAIT, SUBSTATE_NONE)
Oct  4 15:39:58.389: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Converting TimeZone GMT+1 to SIP default timezone = G
MT
Oct  4 15:39:58.389: //20409/000000000000/SIP/Error/sipSPIAddPrivacyHeader: Orig Container is NULL...should have value
Oct  4 15:39:58.389: //20409/000000000000/SIP/Error/sipSPIAddAssertedIDHeader: Orig Container is NULL...should have value
Oct  4 15:39:58.389: //20409/000000000000/SIP/Error/sipSPIAddPreferredIDHeader: Orig Container is NULL...should have value
Oct  4 15:39:58.389: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
OPTIONS sip:192.168.4.21:6060 SIP/2.0
Via: SIP/2.0/UDP 192.168.4.2:5060;branch=z9hG4bK2B1126B1
To: <192.168.4.21>
Date: Thu, 04 Oct 2012 13:39:58 GMT
Call-ID: D2C7C864-D5F11E2-9DCE983E-D9D8E858@192.168.4.2
User-Agent: Cisco-SIPGateway/IOS-12.x
Max-Forwards: 70
CSeq: 101 OPTIONS
Contact: <192.168.4.2:5060>
Content-Length: 0
Oct  4 15:39:58.493: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [192.168.4.21
]:6060
Oct  4 15:39:58.493: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for e
vent 1
Oct  4 15:39:58.493: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
Oct  4 15:39:58.493: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Contact: <192.168.4.21:6060>
To: <192.168.4.21>;tag=f5355f15
CSeq: 101 OPTIONS
Accept: application/sdp
Accept-Language: en
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO, MESSAGE
Supported: replaces
User-Agent: 3CXPhoneSystem 10.0.23053.0
Allow-Events: presence, message-summary, dialog, call-info, line-seize
Content-Length: 0
Oct  4 15:39:58.493: //20409/000000000000/SIP/Info/sipSPICheckResponse: non-INVITE response with no RSEQ - do not disable
IS_REL1XX
Oct  4 15:39:58.493: //20409/000000000000/SIP/Info/sipSPIUdeleteccCallIdFromTable: Removing call id 4FB9
Oct  4 15:39:58.493: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIDeleteContextFromTable: Context for key=[9961] removed.
Oct  4 15:39:58.493: //20409/000000000000/SIP/Info/sipSPIUdeleteCcbFromUACTable: ****Deleting from UAC table.
Oct  4 15:39:58.493: //20409/000000000000/SIP/Info/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x68B13C00 key=D2C7
Oct  4 15:39:58.493: //20409/000000000000/SIP/Info/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue t
hat are going to be free'd
Oct  4 15:39:58.493: //20409/000000000000/SIP/Info/ccsip_qos_cleanup: Entry
Oct  4 15:39:58.493: //20409/000000000000/SIP/Info/sipSPI_ipip_free_codec_profile: Codec Profiles Freed
Oct  4 15:39:58.493: //20409/000000000000/SIP/Info/sipSPIUfreeOneCCB: Freeing ccb 68B13C00
Oct  4 15:39:58.493: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContextFromTable: NO context for key[9961]
Oct  4 15:40:07.525: %ISDN-6-DISCONNECT: Interface Serial0/3/1:17  disconnected from 628436338 , call lasted 20 seconds
GW#
It seems that the CUBE(GW) send the call succesfully to sip server.From there i dont know how is working
What is the ip:
192.168.4.2
Also just to understand:
Operator private extension where is register.
The sip server what number expecting to recieve from gw??(951016650)??
Operator private extension does not have a number>??
That is the ip address of the GW lan interface, and 192.168.4.21 is assigned to sip server.
Ok
From the traces i see that 192.168.4.2 has port 5060.From what you say you want 6060 and not 5060
Are you sure that the sip server in listening ONLY for 6060 port with this connection?
Can you answer the above and also the previous post>?
Can i see also one outgoing call from the operator private extension?
Debug isdn q931
ccsip messages
The gw is using port 5060, but sip server is working on port 6060. I think that's not a problem, is fact outgoing calls work fine, and the gw seems to be registered on the sip server.
The operator private extension is registered on sip server, I dont know the number, is a private number. The gw is expecting to receive calls on the number 951016650, and has a incoming rule to transfer that calls to the private extension.
I send you the debug for a outgoing succesfully call.
Thats very strange, I am really desperate.
From the outgoing you can see that all the sip messages are there.Invite , ACK, etc
In incoming call i dont see full sip messages
Most propably the sip server is not configure correct for this connection
Second :Gw is sending 951016650 to sip server.I believe that the call stuck there and never trying to go to the endpoint
So i want from you to be sure that sip server expecting to recieve 951016650 and not something else..
From outgoing call the calling number is 90001.So why would not be also and the incoming number 90001
You have to be sure what number expecting to recieve the sip server
