problem with sip trunk between gw and ToIP ISP in incoming calls
juanluis
Hi, I have this VoIP network: SIP Server -- GW -- PSTN, with E1 link to PSTN, the gw and SIP server and GW are in the same LAN.
I can see the sip-ua is registered:
GW#show sip-ua register status
Line                              peer        expires(sec)  registered
.*                                2           154           no
90001                             -1          94            yes
GW#show sip-ua connections udp detail
Remote-Agent:192.168.4.21, Connections-Count:1
  Remote-Port Conn-Id Conn-State  WriteQ-Size
         6060       2 Established           0
The outgoing calls are working fine with phones registered in sip server. But I dont get work the incoming calls from pstn. This is the involved config:
voice service pots
supported-language es
supplementary-service qsig call-forward
voice service voip
dtmf-interworking rtp-nte
allow-connections h323 to sip
allow-connections sip to sip
redirect ip2ip
signaling forward unconditional
fax protocol t38 nse force ls-redundancy 0 hs-redundancy 0 fallback none
sip
  bind control source-interface GigabitEthernet0/0
  bind media source-interface GigabitEthernet0/0
  registrar server expires max 3600 min 3600
  no update-callerid
  early-offer forced
  midcall-signaling passthru
voice class codec 1
codec preference 1 transparent
codec preference 2 g711alaw
codec preference 3 g711ulaw
controller E1 0/3/1
framing NO-CRC4
pri-group timeslots 1-31
interface Serial0/3/1:15
no ip address
encapsulation hdlc
isdn switch-type primary-qsig
isdn incoming-voice voice
no cdp enable
bearer-cap 3100Hz
voice-port 0/3/1:15
echo-cancel coverage 64
cptone ES
connection plar 951016650
dial-peer voice 2 pots
description outgoing calls
destination-pattern .T
port 0/3/1:15
dial-peer voice 1 voip
description incoming calls
destination-pattern 951016650
voice-class codec 1
session protocol sipv2
session target ipv4:192.168.4.21:6060
dtmf-relay sip-notify h245-alphanumeric
sip-ua
credentials username 90001 password ****** realm 3CXPhoneSystem
keepalive target ipv4:192.168.4.21:6060
authentication username 90001 password ******
retry invite 3
retry response 3
retry bye 3
retry cancel 3
timers expires 300000
registrar ipv4:192.168.4.21:6060 expires 3600
sip-server ipv4:192.168.4.21:6060
I attach debug ccsip file.
I call from 952029343 to 951016650
Please, anyone can help me?, I have tried really a lot of commands and config but I dont get work the incoming calls.
Thanks in advance.
27 Replies 27
It seems that the private extension operator number is 90009
How can I test if calling directly with translation rule the call is working?
I have set destination-pattern 90001 on dial-peer voice 1 voip and translate called number on voice-port, but it doesn work.
Must I configure the rule at other level?
Can is see your translation rule/profile/voice-port ,etc?
Please rate all useful posts Regards Chrysostomos ""The Most Successful People Are Those Who Are Good At Plan B""
translation-rule 1
Rule 0 951016650 90009
voice-port 0/3/1:15
translate called 1
destination-pattern 90009
voice-class codec 1
I Prefer to use this format of translation
You can use debug voice translation  to check whats going
voice translation-rule 20987
rule 1 /951016650/ /90001/
voice translation-profile PROFILE-INCOMING
translate called 20987
voice-port 0/3/1:15
translation-profile incoming PROFILE-INCOMING
OR apply the profile in dial-peer voice 2 pots
Use voice-port for general incoming calls OR dial peer pots 2 for specific calls
incoming called-number .
port 0/3/1:15
its good also to use this dial peer with two more commands
incoming called-number.
voice-class codec 1
no vad
Today the system doesnt wat working. There is no way.
Here is the last debug, you can see the call is going to 90009, but it doesn work.
I have a phone software registered with the sip server and call directly to 90009 and the call is OK. But that I need, the incoming call from pstn doesn want to work today.
Tomorrow I´ll try to contact with sip server administrator.
Thanks. If you review this debug and see something can help me, please let me know.
OK
Now here is the problem
Received:
SIP/2.0 404 User unknown
Sip server dont know what is 90009
So check it again with teh sip server administrator and verify what sip server expecting to recieve
OK, thanks
But can I ask you a last question?, why I need the connection plar on the voice-port setup?
I can see that if I dont config that command, the incoming call doesnt progress. Must I config connection plar or translation?
I call to a number that is on the destination-pattern of the dial-peer associated with sip server, but the system seems that dont "call" to that dial-peer, why?
Regards.
I believe that you dont need the plar ,
You need translation ONLY IF the incoming number should to be translated to a different number
Verify with the sip server administrator what number is expecting to recieve from you
Also if you want to check if you hit the correct dial peerand if the translation working correct then  you can use
debug voice dialpeer
cc
This is the debug dialpeer output:
GW#
Oct  5 11:11:15.256: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=952029343, Called Number=951016650, Voice-Interface=0x6918D8B8,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
   Peer Info Type=DIALPEER_INFO_SPEECH
   Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=2
   Calling Number=952029343, Called Number=951016650, Voice-Interface=0x0,
   Peer Info Type=DIALPEER_INFO_FAX
   Result=NO_MATCH(-1) After All Match Rules Attempt
Oct  5 11:11:15.264: %ISDN-6-CONNECT: Interface Serial0/3/1:17 is now connected to 952029343 N/A
Oct  5 11:11:33.865: %ISDN-6-DISCONNECT: Interface Serial0/3/1:17  disconnected from 952029343 , call lasted 18 seconds
Oct  5 11:11:34.153: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=.T, Called Number=, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
Oct  5 11:11:34.157: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
GW#
I have no connectio plar config, and it seems that the system doesnt find the voip dialpeer with destination pattern 951016650, why?
This is the dialpeer config:
port 0/3/1:15
voice-class codec 1
Regards.
Its supposed that you have remove the translation profile or translation rule from the voice-port right?
Also put the no vad into ALL the voip dial peer.VAD is bad
Yes, no translation. And no vad on dialpeer voip.
I dont understand why the system needs connection plar to progress the call from pstn voice-port to voip sip dialpeer.
Really I must doing something wrong, but what?
I am sure that is not nee it
The call coming from E1 and then it should be go to dial-peer voice 1 voip
If you are sure that you dont missed any misconfiguration , then pls reload the VG
I can not reload the gw now, I have to wait this afternoon. I'll try it.
Thats the question, the call should go from E1 to voip dial-peer, but the call seems stop his travel.
In the phone I test the call, it seems to be established or connected immediately after dialing the number, it is as the system doesnt know there is a voip dialpeer with that destination number.
My gw has his own will.
Although all is different when I set up connection plar, as you can see in the last debug. Why?
