Problem with SIP-UA against provider
Hi.
I'm having some difficulties configuring our 2801 acting as CUBE to work with our new VOIP provider. Everything worked perfectly with our previous provider TDC, but for a number of reasons we had to change and we choose CellIP as our new provider.
First off, what works? Inbound calls works just as expected. Calls get connected and no audio problems. What doesn’t work is our outbound calls.
The setup looks like this:
CUCM 7.1 -> Cisco 2801 12.4(13r)T -> ASA5520 -> Internet WAN
I have setup a static NAT in the ASA for inbound traffic on 5060-5065 from the providers IP-addresses and are pointing this traffic to the 2801. I have also created a dynamic mapping so that outbound traffic from the 2801 uses the same IP-address as is used for inbound calls, which also is registered with the provider.
I have tried reading up on SIP authentication but I’m not sure on how to troubleshoot this problem further. The provider can’t provide any more help than that the error message indicates something wrong with the authentication. They think that this might be the problem, although the solution is for Asterisk, but I don’t know how to implement the solution in my configuration.
We need to authenticate our SIP-trunk so, for that reason I have setup a SIP-UA in the 2801 looking like this.
sip-ua
credentials username 4******5 password 7 ********* realm sip.cellip.com
no remote-party-id
retry invite 2
retry response 2
retry bye 2
timers trying 150
timers expires 60000
registrar dns:sip.cellip.com expires 3600
sip-server dns:sip.cellip.com
And debug message looks like this. If I read it correctly the first attempt fails men using “www-authentication”, but the gets accepted:
*Jul  6 21:56:04.775: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
REGISTER sip:sip.cellip.com:5060 SIP/2.0
Via: SIP/2.0/UDP 172.16.21.12:5060;branch=z9hG4bK325A7
To:
sip:4****5@sip.cellip.com
Date: Mon, 06 Jul 2015 21:56:04 GMT
Call-ID: EB05DCAF-235911E5-80028B0A-E00CE021
User-Agent: Cisco-SIPGateway/IOS-12.x
Max-Forwards: 70
Timestamp: 1436219764
CSeq: 4 REGISTER
Contact:
sip:4****5@172.16.21.12:5060
Expires:  3600
Supported: path
Content-Length: 0
*Jul  6 21:56:04.799: //4/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 401 Unauthorized
Via: SIP/2.0/UDP 172.16.21.12:5060;branch=z9hG4bK325A7;received=*.*.*.115;rport=12560
To: <sip:4****5@sip.cellip.com>;tag=b9b00073
CSeq: 4 REGISTER
WWW-Authenticate: Digest nonce="1436219622:4060594ce535d637fb74e9f9751ec59c",algorithm=MD5,realm="sip.cellip.com"Content-Length: 0
*Jul  6 21:56:04.803: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 172.16.21.12:5060;branch=z9hG4bK443
To:
Max-Forwards: 70
CSeq: 5 REGISTER
Contact:
Expires: 3600
Authorization: Digest username="4****5",realm="sip.cellip.com",uri="sip:sip.cellip.com:5060",response="a9fb99ffdb00dccebe7a7f18e0b99572",nonce="1436219622:4060594ce535d637fb74e9f9751ec59c",algorithm=MD5Content-Length: 0
*Jul  6 21:56:04.839: //4/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 172.16.21.12:5060;branch=z9hG4bK443;received=*.*.*.115;rport=12560
Contact: <sip:4****5@*.*.*.115:40526;transport=UDP>;expires=720
Contact: <sip:4****5@*.*.*.115:12560;transport=UDP>;expires=3600
To: <sip:4****5@sip.cellip.com>;tag=109f7a30
CSeq: 5 REGISTER
Date: Mon, 06 Jul 2015 21:53:42 GMT
PortaBilling: available-funds:****.**** currency:SEK
Content-Length: 0
So, the authentications looks OK, but when I try to make an outbound call, I get the error “SIP/2.0 401 Unauthorized”:
*Jul  6 23:23:55.571: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:04*****8@172.16.21.12:5060 SIP/2.0
Date: Tue, 07 Jul 2015 06:23:13 GMT
Call-Info: <sip:172.16.21.20:5060>;method="NOTIFY;Event=telephone-event;Duration=500"
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
From: <sip:04*****6@172.16.21.20>;tag=b7fd6ac6-e8d0-47b5-8a53-e836f9e1659f-23910483
Allow-Events: presence, kpml
P-Asserted-Identity:
Supported: timer,resource-priority,replaces
Min-SE:  3600
Remote-Party-ID: <sip:04*****6@172.16.21.20>;party=calling;screen=yes;privacy=off
Content-Length: 0
User-Agent: Cisco-CUCM7.0
To:
Contact: sip:04*****6@172.16.21.20:5060
Expires: 180
Call-ID:
a3e8e400-59b17051-37c-141510ac@172.16.21.20
Via: SIP/2.0/UDP 172.16.21.20:5060;branch=z9hG4bK4143f0f3af9
CSeq: 101 INVITE
Session-Expires:  3600
Max-Forwards: 70
*Jul  6 23:23:55.591: //10/E7B827B08018/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To:
Date: Mon, 06 Jul 2015 23:23:55 GMT
Call-ID:
CSeq: 101 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
*Jul  6 23:23:55.607: //11/E7B827B08018/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:464*****8@sip.cellip.com:5060 SIP/2.0
Via: SIP/2.0/UDP 172.16.21.12:5060;branch=z9hG4bK91284
From: <sip:464*****6@***.**.***.115>;tag=7CDD90-11D3
To:
Call-ID:
E7BBD138-236C11E5-801E8B0A-E00CE021@***.**.***.115
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  3600
Cisco-Guid: 3887605680-0594285029-2149092106-3758940193
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1436225035
Contact:
sip:464*****6@172.16.21.12:5060
Expires: 60
Max-Forwards: 69
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 259
v=0
o=CiscoSystemsSIP-GW-UserAgent 3377 8789 IN IP4 172.16.21.12
s=SIP Call
c=IN IP4 172.16.21.12
t=0 0
m=audio 18120 RTP/AVP 0 8 101
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
*Jul  6 23:23:55.647: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 172.16.21.12:5060;branch=z9hG4bK91284;received=***.**.***.115;rport=48615
To:
Call-ID:
CSeq: 101 INVITE
Content-Length: 0
*Jul  6 23:23:55.667: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.16.21.12:5060;received=***.**.***.115;branch=z9hG4bK91284;rport=48615
Record-Route:
sip:62.84.202.106:5060;transport=udp;lr
To: sip:464*****8@sip.cellip.com
Call-ID:
CSeq: 101 INVITE
Server: Sippy
WWW-Authenticate: Digest realm="sip.cellip.com",nonce="b3acde029185f6230b408d09ee2590f2e496"
Content-Length: 0
My configuration on the 2801 looks like this:
voice service voip
ip address trusted list
  ipv4 0.0.0.0 0.0.0.0
 allow-connections sip to sip
 redirect ip2ip
 fax protocol pass-through g711alaw
 sip
  bind control source-interface FastEthernet0/0
  bind media source-interface FastEthernet0/0
  min-se 3600 session-expires 3600
  registrar server expires max 1500 min 600
  asserted-id pai
  redirect contact order best-match
  localhost dns:sip.cellip.com
  early-offer forced
  registration passthrough
voice class codec 1
 codec preference 1 g711ulaw
 codec preference 2 g711alaw
voice class sip-profiles 10
 request INVITE sip-header Call-ID modify "(.*)@(.*)" "\1@***.**.***.115"
 request INVITE sip-header From modify "@(.*);tag=(.*)" "@***.**.***.115>;tag=\2"
 request INVITE sip-header P-Asserted-Identity modify "@(.*)>" "@***.**.***.115>"
voice translation-rule 10
 rule 1 /^0/ /46/
voice translation-rule 30
 rule 1 /^00/ /+/
voice translation-rule 300
 rule 1 /^/ /+/
voice translation-profile 10
 translate calling 10
 translate called 10
voice translation-profile 30
 translate called 30
voice translation-profile 300
 translate called 300
voice-card 0
 ip address 172.16.21.12 255.255.255.0
 duplex auto
 speed auto
dial-peer voice 1 voip
 description Outgoing calls forwarded to CellIP
 translation-profile outgoing 10
 destination-pattern 0T
 session protocol sipv2
 session target dns:sip.cellip.com
 session transport udp
 voice-class codec 1
 no voice-class sip associate registered-number
 voice-class sip profiles 10
 voice-class sip registration passthrough
 dtmf-relay rtp-nte
 no vad
dial-peer voice 10 voip
 description Outbound domestic calles to TDC SIP
 translation-profile outgoing 30
 destination-pattern 00T
 session target dns:sip1.cellip.com
 voice-class codec 1
 dtmf-relay rtp-nte
dial-peer voice 100 voip
 description Inbound calls from CellIP SIP-trunk
 translation-profile outgoing 300
 destination-pattern 46T
 session target dns:cucmbe01.voice.**********.local
 voice-class codec 1
 dtmf-relay rtp-nte
 no vad
sip-ua
 credentials username 4*****5 password 7 ********** realm sip.cellip.com
 no remote-party-id
 retry invite 2
 retry response 2
 retry bye 2
 timers trying 150
Can anyone provide me with some insight?
Best regards,
Johan Christensson
Hi Johan
On dial-peer 10 please remove voice class sip profile and voice class sip registration passthrough.
Let me know
Thx
Carlo
Please rate all helpful posts "The more you help the more you learn"
23 Replies 23
Arthur Luke
Johan,
Does your provider require you to use a specific calling party number in the From: on the INVITE?
Vivek Batra
When you make a call to service provider, SP is authenticating with 401 Unauthorized. This is normal behavior. I can't see further messages in your traces. Are traces incomplete?
I assume that IOS is not sending further INVITE with desired authentication header, if that is your issue, add the following command under sip-ua and check it solves your issue.
 authenticate username 4*****5 password 7 ********** realm sip.cellip.com
Hi Johan.
To add a tip to what Vivek correctly suggested (+5 V) try to add
calling-info pstn-to-sip remote-party-id number set 4******5 <--- your number
try also to modify
with
credentials number 4*****5 username 4*****5 password 7 ********** realm sip.cellip.com
Carlo
Hi, and thanks for your answers. Sorry I haven't been able to reply earlier.
I have been in contact with my provider, but the only help they can offer is to tell me that the “there is a problem with the authentication”, and I have also received this link that’s supposed to solve this problem when using Asteriks server. http://serverfault.com/questions/574166/asterisk-401-unauthorized-when-trying-to-register-sip-clients But, they can’t provide me whit any further information on how the invite and authentication need to be “formatted”.
I have tried your suggestions, without any luck. One thing I noticed is that in the “SIP/2.0 401 Unauthorized” messages it says: WWW-Authenticate: Digest realm="ip", shouldn’t this be “Digest realm=”sip.cellip.com”?
I tried changing the realm in the SIP-UA Authentication line from sip.cellip.com to just ip, but the made no difference.
As off Carlos suggestion, I tried to add the “calling-info pstn-to-sip remote-party-id number set” under SIP-UA both with the “main SIP-trunk number” that is also used as username and the actual outbound number. Both seems to have no effect.
I will also include a more complete trace of an attempt to make an outbound call:
*Jul 20 14:33:59.146: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:04****18@172.16.21.12:5060 SIP/2.0
Date: Mon, 20 Jul 2015 21:31:50 GMT
From: <sip:04****46@172.16.21.20>;tag=b7fd6ac6-e8d0-47b5-8a53-e836f9e1659f-23910810
P-Asserted-Identity: <sip:04****46@172.16.21.20>
Min-SE:  3600
Remote-Party-ID: <sip:04****46@172.16.21.20>;party=calling;screen=yes;privacy=off
Content-Length: 0
To: <sip:04****18@172.16.21.12>
Contact: <sip:04****46@172.16.21.20:5060>
Expires: 180
Call-ID:
b9f1ac80-5ad168c6-3f7-141510ac@172.16.21.20
Via: SIP/2.0/UDP 172.16.21.20:5060;branch=z9hG4bK4992bd17c25
CSeq: 101 INVITE
Max-Forwards: 70
*Jul 20 14:33:59.162: //744/315B364F845C/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Mon, 20 Jul 2015 14:33:59 GMT
Call-ID:
CSeq: 101 INVITE
Content-Length: 0
*Jul 20 14:34:03.594: //745/315B364F845C/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:464****18@sip.cellip.com:5060 SIP/2.0
Via: SIP/2.0/UDP 172.16.21.12:5060;branch=z9hG4bK3F42386
To: <sip:464****18@sip.cellip.com>
Date: Mon, 20 Jul 2015 14:34:03 GMT
Call-ID:
315EDFD7-2E2311E5-84628B0A-E00CE021@*.*.*.115
Min-SE:  3600
Cisco-Guid: 0828061263-0774050277-2220657418-3758940193
CSeq: 101 INVITE
Timestamp: 1437402843
Contact: <sip:464****46@172.16.21.12:5060>
Expires: 60
Max-Forwards: 69
P-Asserted-Identity: <sip:464****46@*.*.*.115>
Content-Length: 258
v=0
o=CiscoSystemsSIP-GW-UserAgent 8823 521 IN IP4 172.16.21.12
s=SIP Call
t=0 0
m=audio 19180 RTP/AVP 0 8 101
a=fmtp:101 0-16
*Jul 20 14:34:03.606: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 172.16.21.12:5060;branch=z9hG4bK3F42386;received=*.*.*.115;rport=64120
Call-ID:
CSeq: 101 INVITE
Content-Length: 0
*Jul 20 14:34:03.646: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.16.21.12:5060;received=*.*.*.115;branch=z9hG4bK3F42386;rport=64120
Record-Route: <sip:193.105.226.106:5060;transport=udp;lr>
Call-ID:
CSeq: 101 INVITE
Server: Sippy
WWW-Authenticate: Digest realm="ip",nonce="2bd4f56f26fee3fc9f392074ed44f40fee6e"
Content-Length: 0
*Jul 20 14:34:03.750: //745/315B364F845C/SIP/Msg/ccsipDisplayMsg:
Sent:
Call-ID:
Min-SE:  3600
CSeq: 101 INVITE
Expires: 60
Max-Forwards: 69
Content-Length: 258
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-16
*Jul 20 14:34:03.762: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID:
CSeq: 101 INVITE
Server: Sippy
Content-Length: 0
*Jul 20 14:34:04.050: //745/315B364F845C/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Mon, 20 Jul 2015 14:34:04 GMT
Call-ID:
Min-SE:  3600
CSeq: 101 INVITE
Timestamp: 1437402844
Expires: 60
Max-Forwards: 69
Content-Length: 258
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-16
*Jul 20 14:34:04.070: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID:
CSeq: 101 INVITE
Server: Sippy
Content-Length: 0
*Jul 20 14:34:04.146: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID:
CSeq: 101 INVITE
Server: Sippy
Content-Length: 0
*Jul 20 14:34:04.654: //745/315B364F845C/SIP/Msg/ccsipDisplayMsg:
Sent:
Call-ID:
Min-SE:  3600
CSeq: 101 INVITE
Expires: 60
Max-Forwards: 69
Content-Length: 259
v=0
o=CiscoSystemsSIP-GW-UserAgent 9037 8781 IN IP4 172.16.21.12
s=SIP Call
t=0 0
m=audio 18422 RTP/AVP 0 8 101
a=fmtp:101 0-16
*Jul 20 14:34:04.670: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 172.16.21.12:5060;branch=z9hG4bK3F42386;received=*.*.*.115;rport=52750
Call-ID:
CSeq: 101 INVITE
Content-Length: 0
*Jul 20 14:34:04.690: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.16.21.12:5060;received=*.*.*.115;branch=z9hG4bK3F42386;rport=52750
Record-Route: <sip:193.105.226.102:5060;transport=udp;lr>
Call-ID:
CSeq: 101 INVITE
Server: Sippy
Content-Length: 0
*Jul 20 14:34:04.806: //745/315B364F845C/SIP/Msg/ccsipDisplayMsg:
Sent:
Call-ID:
Min-SE:  3600
CSeq: 101 INVITE
Expires: 60
Max-Forwards: 69
Content-Length: 259
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-16
*Jul 20 14:34:04.818: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID:
CSeq: 101 INVITE
Server: Sippy
Content-Length: 0
*Jul 20 14:34:05.106: //745/315B364F845C/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Mon, 20 Jul 2015 14:34:05 GMT
Call-ID:
Min-SE:  3600
CSeq: 101 INVITE
Timestamp: 1437402845
Expires: 60
Max-Forwards: 69
Content-Length: 259
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-16
*Jul 20 14:34:05.142: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID:
CSeq: 101 INVITE
Server: Sippy
Content-Length: 0
*Jul 20 14:34:05.158: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID:
CSeq: 101 INVITE
Server: Sippy
Content-Length: 0
*Jul 20 14:34:05.194: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID:
CSeq: 101 INVITE
Server: Sippy
Content-Length: 0
*Jul 20 14:34:05.710: //745/315B364F845C/SIP/Msg/ccsipDisplayMsg:
Sent:
Call-ID:
Min-SE:  3600
CSeq: 101 INVITE
Expires: 60
Max-Forwards: 69
Content-Length: 259
v=0
o=CiscoSystemsSIP-GW-UserAgent 5711 5341 IN IP4 172.16.21.12
s=SIP Call
t=0 0
m=audio 17596 RTP/AVP 0 8 101
a=fmtp:101 0-16
*Jul 20 14:34:05.750: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 172.16.21.12:5060;branch=z9hG4bK3F42386;received=*.*.*.115;rport=26661
Call-ID:
CSeq: 101 INVITE
Content-Length: 0
*Jul 20 14:34:05.778: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.16.21.12:5060;received=*.*.*.115;branch=z9hG4bK3F42386;rport=26661
Record-Route: <sip:62.84.202.106:5060;transport=udp;lr>
Call-ID:
CSeq: 101 INVITE
Server: Sippy
Content-Length: 0
*Jul 20 14:34:05.862: //745/315B364F845C/SIP/Msg/ccsipDisplayMsg:
Sent:
Call-ID:
Min-SE:  3600
CSeq: 101 INVITE
Expires: 60
Max-Forwards: 69
Content-Length: 259
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-16
*Jul 20 14:34:05.886: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID:
CSeq: 101 INVITE
Server: Sippy
Content-Length: 0
*Jul 20 14:34:06.162: //745/315B364F845C/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Mon, 20 Jul 2015 14:34:06 GMT
Call-ID:
Min-SE:  3600
CSeq: 101 INVITE
Timestamp: 1437402846
Expires: 60
Max-Forwards: 69
Content-Length: 259
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-16
*Jul 20 14:34:06.190: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID:
CSeq: 101 INVITE
Server: Sippy
Content-Length: 0
Received:
Call-ID:
CSeq: 101 INVITE
Server: Sippy
Content-Length: 0
*Jul 20 14:34:06.274: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID:
CSeq: 101 INVITE
Server: Sippy
Content-Length: 0
*Jul 20 14:34:06.766: //745/315B364F845C/SIP/Msg/ccsipDisplayMsg:
Sent:
Call-ID:
Min-SE:  3600
CSeq: 101 INVITE
Expires: 60
Max-Forwards: 69
Content-Length: 259
v=0
o=CiscoSystemsSIP-GW-UserAgent 7838 8586 IN IP4 172.16.21.12
s=SIP Call
t=0 0
m=audio 17818 RTP/AVP 0 8 101
a=fmtp:101 0-16
*Jul 20 14:34:06.786: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 172.16.21.12:5060;branch=z9hG4bK3F42386;received=*.*.*.115;rport=22441
Call-ID:
CSeq: 101 INVITE
Content-Length: 0
*Jul 20 14:34:06.794: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.16.21.12:5060;received=*.*.*.115;branch=z9hG4bK3F42386;rport=22441
Record-Route: <sip:62.84.202.101:5060;transport=udp;lr>
Call-ID:
CSeq: 101 INVITE
Server: Sippy
WWW-Authenticate: Digest realm="ip",nonce="2dda93126945f5eec1e956a97dd0c25cea71"
Content-Length: 0
*Jul 20 14:34:06.918: //745/315B364F845C/SIP/Msg/ccsipDisplayMsg:
Sent:
Call-ID:
Min-SE:  3600
CSeq: 101 INVITE
Expires: 60
Max-Forwards: 69
Content-Length: 259
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-16
*Jul 20 14:34:06.946: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID:
CSeq: 101 INVITE
Server: Sippy
Content-Length: 0
*Jul 20 14:34:07.142: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID:
CSeq: 101 INVITE
Server: Sippy
Content-Length: 0
*Jul 20 14:34:07.218: //745/315B364F845C/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Mon, 20 Jul 2015 14:34:07 GMT
Call-ID:
Min-SE:  3600
CSeq: 101 INVITE
Timestamp: 1437402847
Expires: 60
Max-Forwards: 69
Content-Length: 259
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-16
*Jul 20 14:34:07.238: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID:
CSeq: 101 INVITE
Server: Sippy
Content-Length: 0
*Jul 20 14:34:07.262: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID:
CSeq: 101 INVITE
Server: Sippy
Content-Length: 0
*Jul 20 14:34:07.314: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID:
CSeq: 101 INVITE
Server: Sippy
Content-Length: 0
*Jul 20 14:34:07.822: //744/315B364F845C/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 404 Not Found
To: <sip:04****18@172.16.21.12>;tag=46B0DADC-2544
Call-ID:
CSeq: 101 INVITE
Reason: Q.850;cause=3
Content-Length: 0
*Jul 20 14:34:07.822: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:04****18@172.16.21.12:5060 SIP/2.0
Content-Length: 0
Call-ID:
CSeq: 101 ACK
Max-Forwards: 70
*Jul 20 14:34:08.198: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID:
CSeq: 101 INVITE
Server: Sippy
Content-Length: 0
*Jul 20 14:34:08.294: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID:
CSeq: 101 INVITE
Server: Sippy
Content-Length: 0
*Jul 20 14:34:09.278: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID:
CSeq: 101 INVITE
Server: Sippy
Content-Length: 0
*Jul 20 14:34:09.930: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
*Jul 20 14:34:10.306: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID:
CSeq: 101 INVITE
Server: Sippy
Content-Length: 0
*Jul 20 14:34:11.146: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID:
CSeq: 101 INVITE
Server: Sippy
Content-Length: 0
*Jul 20 14:34:12.214: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID:
CSeq: 101 INVITE
Server: Sippy
Content-Length: 0
*Jul 20 14:34:13.266: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID:
CSeq: 101 INVITE
Server: Sippy
Content-Length: 0
*Jul 20 14:34:14.298: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID:
CSeq: 101 INVITE
Server: Sippy
Content-Length: 0
*Jul 20 14:34:15.146: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID:
CSeq: 101 INVITE
Server: Sippy
Content-Length: 0
*Jul 20 14:34:16.190: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID:
CSeq: 101 INVITE
Server: Sippy
Content-Length: 0
*Jul 20 14:34:17.278: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID:
CSeq: 101 INVITE
Server: Sippy
Content-Length: 0
*Jul 20 14:34:18.298: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID:
CSeq: 101 INVITE
Server: Sippy
Content-Length: 0
*Jul 20 14:34:19.150: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID:
CSeq: 101 INVITE
Server: Sippy
Content-Length: 0
*Jul 20 14:34:20.194: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID:
CSeq: 101 INVITE
Server: Sippy
Content-Length: 0
*Jul 20 14:34:21.262: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID:
CSeq: 101 INVITE
Server: Sippy
Content-Length: 0
*Jul 20 14:34:22.298: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID:
CSeq: 101 INVITE
Server: Sippy
Content-Length: 0
*Jul 20 14:34:23.146: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID:
CSeq: 101 INVITE
Server: Sippy
Content-Length: 0
*Jul 20 14:34:24.190: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID:
CSeq: 101 INVITE
Server: Sippy
Content-Length: 0
*Jul 20 14:34:24.934: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
*Jul 20 14:34:25.270: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID:
CSeq: 101 INVITE
Server: Sippy
Content-Length: 0
*Jul 20 14:34:26.298: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID:
CSeq: 101 INVITE
Server: Sippy
Content-Length: 0
*Jul 20 14:34:27.158: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID:
CSeq: 101 INVITE
Server: Sippy
Content-Length: 0
*Jul 20 14:34:28.190: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID:
CSeq: 101 INVITE
Server: Sippy
Content-Length: 0
*Jul 20 14:34:29.282: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID:
CSeq: 101 INVITE
Server: Sippy
Content-Length: 0
*Jul 20 14:34:30.310: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID:
CSeq: 101 INVITE
Server: Sippy
Content-Length: 0
*Jul 20 14:34:31.150: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID:
CSeq: 101 INVITE
Server: Sippy
Content-Length: 0
*Jul 20 14:34:32.194: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID:
CSeq: 101 INVITE
Server: Sippy
Content-Length: 0
*Jul 20 14:34:33.270: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID:
CSeq: 101 INVITE
Server: Sippy
Content-Length: 0
*Jul 20 14:34:34.302: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID:
CSeq: 101 INVITE
Server: Sippy
Content-Length: 0
*Jul 20 14:34:35.154: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID:
CSeq: 101 INVITE
Server: Sippy
Content-Length: 0
*Jul 20 14:34:36.194: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID:
CSeq: 101 INVITE
Server: Sippy
Content-Length: 0
*Jul 20 14:34:37.262: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID:
CSeq: 101 INVITE
Server: Sippy
Content-Length: 0
*Jul 20 14:34:38.302: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID:
CSeq: 101 INVITE
Server: Sippy
Content-Length: 0
I don't realy know where to go from here.
Best regards,
Johan Christensson
Hi Johan,
Yes, there is a problem with authentication. I can see that when gateway receives 401 (against INVITE), gateway is not generating INVITE with desired authentication header.
Another point to be noted that realm received in 401 is now different. You should clarify the same with ITSP. However considering following logs, can try making changes accordingly.
authenticate username 4*****5 password 7 ********** realm ip
Hi again.
With "desired authentication header" do you mean that header is missing altogether or that the credentials supplied in the header is wrong? My understanding is that all configuration regarding SIP authentication is done under SIP-UA, correct?
I have tried every combination regarding the authentication and credentials possible. With realm, without realm, with both “ip” and “sip.cellip.com” as realm, with and without number.
I was asked to try a softphone application called X-lite, to verify that my credentials is correct, and using this I could make a call using the “main number”. So the credentials seems to be correct.
Best regards,
Johan Christensson
Can you please share the Xlite traces (REGISTER, INVITE and BYE)... so that we can check what's the difference here...
Not quite sure on how to do this. Is there a logging function in the x-lite application, or do I have to use Wireshark? I'm using X-lite directly against the ITSP.
Best regards,
Johan Christensson
You must be running X-Lite on your desktop. Simply run the wireshark on your desktop and filter it with SIP, it will capture all SIP packets.
I actually found a log function in the application. I filtered out the SIP bits. Here you can clearly see that x-lite is sending an INVITE with an authentication header after the first "401" message, just as you stated earlier.
So, the question is why don't my Cisco gateway do the same thing? Or is it just that it dosen’t show up in the trace?
Best regards,
Johan Christensson
Here is my current running configuration plus a more cleaned up log-file from x-lite. Something seems to have gone wrong with the CR.
Best regards,
Johan Christensson
Hi Johan.
Modify you ua authentication as follows
sip-ua
authentication unsername <your username > password <your password> realm sip.cellip.com
Please attach the output of a debug ccsip messages
Carlo
Ok, here is what I got
Best regards,
Johan Christensson
Ok.
So let's try with the following
authentication unsername <your username > password <your password> realm ip
