Problem with SIP-UA against provider
Hi.
I'm having some difficulties configuring our 2801 acting as CUBE to work with our new VOIP provider. Everything worked perfectly with our previous provider TDC, but for a number of reasons we had to change and we choose CellIP as our new provider.
First off, what works? Inbound calls works just as expected. Calls get connected and no audio problems. What doesn’t work is our outbound calls.
The setup looks like this:
CUCM 7.1 -> Cisco 2801 12.4(13r)T -> ASA5520 -> Internet WAN
I have setup a static NAT in the ASA for inbound traffic on 5060-5065 from the providers IP-addresses and are pointing this traffic to the 2801. I have also created a dynamic mapping so that outbound traffic from the 2801 uses the same IP-address as is used for inbound calls, which also is registered with the provider.
I have tried reading up on SIP authentication but I’m not sure on how to troubleshoot this problem further. The provider can’t provide any more help than that the error message indicates something wrong with the authentication. They think that this might be the problem, although the solution is for Asterisk, but I don’t know how to implement the solution in my configuration.
We need to authenticate our SIP-trunk so, for that reason I have setup a SIP-UA in the 2801 looking like this.
sip-ua
credentials username 4******5 password 7 ********* realm sip.cellip.com
no remote-party-id
retry invite 2
retry response 2
retry bye 2
timers trying 150
timers expires 60000
registrar dns:sip.cellip.com expires 3600
sip-server dns:sip.cellip.com
And debug message looks like this. If I read it correctly the first attempt fails men using “www-authentication”, but the gets accepted:
*Jul  6 21:56:04.775: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
REGISTER sip:sip.cellip.com:5060 SIP/2.0
Via: SIP/2.0/UDP 172.16.21.12:5060;branch=z9hG4bK325A7
To:
sip:4****5@sip.cellip.com
Date: Mon, 06 Jul 2015 21:56:04 GMT
Call-ID: EB05DCAF-235911E5-80028B0A-E00CE021
User-Agent: Cisco-SIPGateway/IOS-12.x
Max-Forwards: 70
Timestamp: 1436219764
CSeq: 4 REGISTER
Contact:
sip:4****5@172.16.21.12:5060
Expires:  3600
Supported: path
Content-Length: 0
*Jul  6 21:56:04.799: //4/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 401 Unauthorized
Via: SIP/2.0/UDP 172.16.21.12:5060;branch=z9hG4bK325A7;received=*.*.*.115;rport=12560
To: <sip:4****5@sip.cellip.com>;tag=b9b00073
CSeq: 4 REGISTER
WWW-Authenticate: Digest nonce="1436219622:4060594ce535d637fb74e9f9751ec59c",algorithm=MD5,realm="sip.cellip.com"Content-Length: 0
*Jul  6 21:56:04.803: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 172.16.21.12:5060;branch=z9hG4bK443
To:
Max-Forwards: 70
CSeq: 5 REGISTER
Contact:
Expires: 3600
Authorization: Digest username="4****5",realm="sip.cellip.com",uri="sip:sip.cellip.com:5060",response="a9fb99ffdb00dccebe7a7f18e0b99572",nonce="1436219622:4060594ce535d637fb74e9f9751ec59c",algorithm=MD5Content-Length: 0
*Jul  6 21:56:04.839: //4/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 172.16.21.12:5060;branch=z9hG4bK443;received=*.*.*.115;rport=12560
Contact: <sip:4****5@*.*.*.115:40526;transport=UDP>;expires=720
Contact: <sip:4****5@*.*.*.115:12560;transport=UDP>;expires=3600
To: <sip:4****5@sip.cellip.com>;tag=109f7a30
CSeq: 5 REGISTER
Date: Mon, 06 Jul 2015 21:53:42 GMT
PortaBilling: available-funds:****.**** currency:SEK
Content-Length: 0
So, the authentications looks OK, but when I try to make an outbound call, I get the error “SIP/2.0 401 Unauthorized”:
*Jul  6 23:23:55.571: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:04*****8@172.16.21.12:5060 SIP/2.0
Date: Tue, 07 Jul 2015 06:23:13 GMT
Call-Info: <sip:172.16.21.20:5060>;method="NOTIFY;Event=telephone-event;Duration=500"
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
From: <sip:04*****6@172.16.21.20>;tag=b7fd6ac6-e8d0-47b5-8a53-e836f9e1659f-23910483
Allow-Events: presence, kpml
P-Asserted-Identity:
Supported: timer,resource-priority,replaces
Min-SE:  3600
Remote-Party-ID: <sip:04*****6@172.16.21.20>;party=calling;screen=yes;privacy=off
Content-Length: 0
User-Agent: Cisco-CUCM7.0
To:
Contact: sip:04*****6@172.16.21.20:5060
Expires: 180
Call-ID:
a3e8e400-59b17051-37c-141510ac@172.16.21.20
Via: SIP/2.0/UDP 172.16.21.20:5060;branch=z9hG4bK4143f0f3af9
CSeq: 101 INVITE
Session-Expires:  3600
Max-Forwards: 70
*Jul  6 23:23:55.591: //10/E7B827B08018/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To:
Date: Mon, 06 Jul 2015 23:23:55 GMT
Call-ID:
CSeq: 101 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
*Jul  6 23:23:55.607: //11/E7B827B08018/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:464*****8@sip.cellip.com:5060 SIP/2.0
Via: SIP/2.0/UDP 172.16.21.12:5060;branch=z9hG4bK91284
From: <sip:464*****6@***.**.***.115>;tag=7CDD90-11D3
To:
Call-ID:
E7BBD138-236C11E5-801E8B0A-E00CE021@***.**.***.115
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  3600
Cisco-Guid: 3887605680-0594285029-2149092106-3758940193
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1436225035
Contact:
sip:464*****6@172.16.21.12:5060
Expires: 60
Max-Forwards: 69
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 259
v=0
o=CiscoSystemsSIP-GW-UserAgent 3377 8789 IN IP4 172.16.21.12
s=SIP Call
c=IN IP4 172.16.21.12
t=0 0
m=audio 18120 RTP/AVP 0 8 101
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
*Jul  6 23:23:55.647: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 172.16.21.12:5060;branch=z9hG4bK91284;received=***.**.***.115;rport=48615
To:
Call-ID:
CSeq: 101 INVITE
Content-Length: 0
*Jul  6 23:23:55.667: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.16.21.12:5060;received=***.**.***.115;branch=z9hG4bK91284;rport=48615
Record-Route:
sip:62.84.202.106:5060;transport=udp;lr
To: sip:464*****8@sip.cellip.com
Call-ID:
CSeq: 101 INVITE
Server: Sippy
WWW-Authenticate: Digest realm="sip.cellip.com",nonce="b3acde029185f6230b408d09ee2590f2e496"
Content-Length: 0
My configuration on the 2801 looks like this:
voice service voip
ip address trusted list
  ipv4 0.0.0.0 0.0.0.0
 allow-connections sip to sip
 redirect ip2ip
 fax protocol pass-through g711alaw
 sip
  bind control source-interface FastEthernet0/0
  bind media source-interface FastEthernet0/0
  min-se 3600 session-expires 3600
  registrar server expires max 1500 min 600
  asserted-id pai
  redirect contact order best-match
  localhost dns:sip.cellip.com
  early-offer forced
  registration passthrough
voice class codec 1
 codec preference 1 g711ulaw
 codec preference 2 g711alaw
voice class sip-profiles 10
 request INVITE sip-header Call-ID modify "(.*)@(.*)" "\1@***.**.***.115"
 request INVITE sip-header From modify "@(.*);tag=(.*)" "@***.**.***.115>;tag=\2"
 request INVITE sip-header P-Asserted-Identity modify "@(.*)>" "@***.**.***.115>"
voice translation-rule 10
 rule 1 /^0/ /46/
voice translation-rule 30
 rule 1 /^00/ /+/
voice translation-rule 300
 rule 1 /^/ /+/
voice translation-profile 10
 translate calling 10
 translate called 10
voice translation-profile 30
 translate called 30
voice translation-profile 300
 translate called 300
voice-card 0
 ip address 172.16.21.12 255.255.255.0
 duplex auto
 speed auto
dial-peer voice 1 voip
 description Outgoing calls forwarded to CellIP
 translation-profile outgoing 10
 destination-pattern 0T
 session protocol sipv2
 session target dns:sip.cellip.com
 session transport udp
 voice-class codec 1
 no voice-class sip associate registered-number
 voice-class sip profiles 10
 voice-class sip registration passthrough
 dtmf-relay rtp-nte
 no vad
dial-peer voice 10 voip
 description Outbound domestic calles to TDC SIP
 translation-profile outgoing 30
 destination-pattern 00T
 session target dns:sip1.cellip.com
 voice-class codec 1
 dtmf-relay rtp-nte
dial-peer voice 100 voip
 description Inbound calls from CellIP SIP-trunk
 translation-profile outgoing 300
 destination-pattern 46T
 session target dns:cucmbe01.voice.**********.local
 voice-class codec 1
 dtmf-relay rtp-nte
 no vad
sip-ua
 credentials username 4*****5 password 7 ********** realm sip.cellip.com
 no remote-party-id
 retry invite 2
 retry response 2
 retry bye 2
 timers trying 150
Can anyone provide me with some insight?
Best regards,
Johan Christensson
23 Replies 23
I think its basiclly the same result.
Best regards,
Johan Christensson
Hi Johan
On dial-peer 10 please remove voice class sip profile and voice class sip registration passthrough.
Let me know
Thx
Carlo
Please rate all helpful posts "The more you help the more you learn"
That did the trick!! Thanks alot!
I tested a bit by adding the lines back, and when adding backl the "voice class sip profile" it stopped working again.
The reason I set that up was because I tryed to mimik the invites I recived from the ITSP. Is there a simple explenation to why it caused these problems, or was it just a hunch?
Best regards,
Johan Christensson
Hi Johan.
Basically you added the sip profile to an outbound dialpeer which was modifying your username and the provider rejected because didn't recognize it.
If you want to modify the from field that you are receiving, add a dialpeer with incoming called-number statement matching your assigned did and there you can add the sip profile 10.
Thanks for nice rating.
Cheers
Carlo
Hi Carlo,
Nice job, +5.
Thanks for nice rating Vivek.
You also are doing a great job on this community !
Cheers
Carlo
Hi Johan.
Can you please post your actual config?
regards
Carlo
Configure the authentication command without realm as follow:
sip-ua
authencation username 4******5 password 7 *********
Also, make sure that you debugs are in text file. Don't paste your debugs directly in the post.
That did it for me.  I needed the credentials number xxxxxxxxx username xxxxxx password 7 xxxxxx realm x.x.x.x.  Without that i couldn't get outbound calls to complete.  I was getting the 401 and then the:
*Mar 25 19:13:13.500: //62323/80A2C52CC000/SIP/Error/sipSPIHandleAuthChallenge:
Error getting credentials
*Mar 25 19:13:13.500: //62323/80A2C52CC000/SIP/Error/act_recdproc_new_message_response:
Error handling AuthenticationChallenge
Once i added the credentials with the "number" command i was good to go!
