01-03-2013 09:42 AM - edited 03-16-2019 02:58 PM
I've a problem with ucm 8.6.2 and ip communicator.
on my pc.
If I look on ther ucm the communicator is registered, but on the communicator disply doesn't appers nothing (only the date/time)
Can you help me?
thanks in advance
Giancarlo
Solved! Go to Solution.
01-03-2013 09:44 AM
Do you have a line configured on the IP Communicator's CUCM config?
01-03-2013 09:44 AM
01-03-2013 10:04 AM
Yes,I've the auto registration enabled.
After the boot in the Cucm Isee the Cipc registerd witch the autoregistration number, bur on the phone I haven't the number
01-03-2013 10:17 AM
Any firewalls/VPN's in between the pc and CUCM? Also, what do you see in the status messages on the phone?
01-03-2013 03:42 PM
Hi Will, excuse for late, but I was very busy to debugging the problem.
I've solved.
The problem was a mtu to high!!!!
The CUCM see the ipphone between a GRE Tunnel over a pppoe connection.
The ethernet mtu are 1492 and the pppoe support smallest mtu.
I've configured the tunnel mtu at 1375 and now all works well||| thanks for haelp
Giancarlo
01-03-2013 04:50 PM
Great job troubleshooting!
Sent from Cisco Technical Support Android App
