Showing results forĀ
Search instead forĀ
Did you mean:Ā
SyslogSeverityMatchFound CUCM8.6
pbosio
At Thu Sep 22 13:40:08 EST 2011 on node X.X.X.X, the following SyslogSeverityMatchFound events generated:
SeverityMatch : Alert
MatchedEvent : Sep 22 13:40:04 CUCMHOSTNAME syslog 1 nbslogpd[8228]: 33 messages were dropped
AppID : Cisco Syslog Agent
ClusterID :
NodeID : CUCMHOSTNAME
TimeStamp : Thu Sep 22 13:40:04 EST 2011
Hi, I'm trying to find the source of this issue and having no luck. Errors are frequent at all times of the day. Cluster appears to be running OK.
CUCM cluster is 4 nodes
TAC finally come back saying this is a "Cosmetic Error" with no real explanation but referencing "CSCty61808" to which I cant see any bug details....
Who knows, will just ignore as advised by TAC for now???...
5 Replies 5
VLT06
Level 3
Level 3
Hey pbosio,
How did you go with this?
RTMT does not provide what service is causing what logs that are to be written but have been dropped....
I have logged a TAC case however don't like my chances of a solution.
Will post what I find though (if anything comes of it).
Cheers!
Hi James - never really found out an answer. It would be nice to know if the TAC do have something to say about it.
Hi James,
Thanks for posting back with your results! +5 for this very
kind follow-up
Cheers!
Rob
"And if I should fall behind
Wait for me" - Springsteen
Jim,
Did you ever get a reply back from TAC about this?  I just started getting the same MSG.
Thanks Jim
