Problems E1 flaping and spoofing 0/0/0:15
Juan Ibañez
I have an E1 that this intermittent problems with the shutdown is sometimes also called layer 1 and layer 2, also throws these loggs:
.May 29 12:10:23.551: %MARS_NETCLK-3-CLK_TRANS: Network clock source transitioned from priority 1 to priority 10
.May 29 12:10:34.052: %MARS_NETCLK-3-CLK_TRANS: Network clock source transitioned from priority 10 to priority 1
.May 29 12:10:36.312: %MARS_NETCLK-3-HOLDOVER: Entering Holdover for Controller E1 0/0/0
.May 29 12:10:46.561: %MARS_NETCLK-3-HOLDOVER_TRANS: Holdover timer exceeded for Controller E1 0/0/0
.May 29 12:10:46.561: %MARS_NETCLK-3-CLK_TRANS: Network clock source transitioned from priority 1 to priority 10
.May 29 12:10:57.062: %MARS_NETCLK-3-CLK_TRANS: Network clock source transitioned from priority 10 to priority 1
.May 29 12:10:59.323: %MARS_NETCLK-3-HOLDOVER: Entering Holdover for Controller E1 0/0/0
.May 29 12:11:09.572: %MARS_NETCLK-3-HOLDOVER_TRANS: Holdover timer exceeded for Controller E1 0/0/0
.May 29 12:11:09.572: %MARS_NETCLK-3-CLK_TRANS: Network clock source transitioned from priority 1 to priority 10
.May 29 12:11:20.073: %MARS_NETCLK-3-CLK_TRANS: Network clock source transitioned from priority 10 to priority 1
.May 29 12:11:22.333: %MARS_NETCLK-3-HOLDOVER: Entering Holdover for Controller E1 0/0/0
.May 29 12:11:32.583: %MARS_NETCLK-3-HOLDOVER_TRANS: Holdover timer exceeded for Controller E1 0/0/0
.May 29 12:11:32.583: %MARS_NETCLK-3-CLK_TRANS: Network clock source transitioned from priority 1 to priority 10
.May 29 12:11:43.084: %MARS_NETCLK-3-CLK_TRANS: Network clock source transitioned from priority 10 to priority 1
.May 29 12:11:45.344: %MARS_NETCLK-3-HOLDOVER: Entering Holdover for Controller E1 0/0/0
.May 29 12:11:59.630: %MARS_NETCLK-3-HOLDOVER: Exiting Holdover for Controller E1 0/0/0
.May 29 12:13:33.641: %MARS_NETCLK-3-HOLDOVER: Entering Holdover for Controller E1 0/0/0
.May 29 12:13:43.890: %MARS_NETCLK-3-HOLDOVER_TRANS: Holdover timer exceeded for Controller E1 0/0/0
.May 29 12:13:43.890: %MARS_NETCLK-3-CLK_TRANS: Network clock source transitioned from priority 1 to priority 10
.May 29 12:13:54.392: %MARS_NETCLK-3-CLK_TRANS: Network clock source transitioned from priority 10 to priority 1
and interface serial 0/0/0:15 is Serial0/0/0:15 is up, line protocol is up (spoofing)
please i need help
paolo bevilacqua
Check "show controllers E1".
look
INACAP-LaSerena_GW_Voz# show interfaces serial 0/0/0:15
  Hardware is DSX1
  MTU 1500 bytes, BW 64 Kbit/sec, DLY 20000 usec,
  Encapsulation HDLC, crc 16, loopback not set
  Keepalive set (10 sec)
  Last input 00:00:06, output 00:00:06, output hang never
  Last clearing of "show interface" counters 00:30:27
  Queueing strategy: weighted fair
  Output queue: 0/1000/64/0 (size/max total/threshold/drops)
     Conversations  0/1/256 (active/max active/max total)
     Reserved Conversations 0/0 (allocated/max allocated)
     Available Bandwidth 48 kilobits/sec
     354 packets input, 2738 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     3 input errors, 3 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     354 packets output, 2429 bytes, 0 underruns
     0 unknown protocol drops
     12 carrier transitions
.May 29 18:05:29.578: %CONTROLLER-5-UPDOWN: Controller E1 0/0/0, changed state to down (RAI detected)
.May 29 18:05:29.778: %MARS_NETCLK-3-HOLDOVER: Entering Holdover for Controller E1 0/0/0
.May 29 18:05:30.578: %CONTROLLER-5-UPDOWN: Controller E1 0/0/0, changed state to up
.May 29 18:05:33.030: %MARS_NETCLK-3-HOLDOVER: Exiting Holdover for Controller E1 0/0/0
.May 29 18:05:35.578: %CONTROLLER-5-UPDOWN: Controller E1 0/0/0, changed state to down (RAI detected)
Global ISDN Switchtype = primary-net5
ISDN Serial0/0/0:15 interface
        dsl 0, interface ISDN Switchtype = primary-net5
    Layer 1 Status:
        ACTIVE
    Layer 2 Status:
        TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
    Layer 3 Status:
        0 Active Layer 3 Call(s)
    Active dsl 0 CCBs = 0
    The Free Channel Mask:  0xFFFF7FFF
    Number of L2 Discards = 0, L2 Session ID = 178
ISDN Serial0/0/1:15 interface
        dsl 1, interface ISDN Switchtype = primary-net5
    Layer 1 Status:
        DEACTIVATED
    Layer 2 Status:
        TEI = 0, Ces = 1, SAPI = 0, State = TEI_ASSIGNED
    Layer 3 Status:
    Active dsl 1 CCBs = 0
    The Free Channel Mask:  0x00000000
    Number of L2 Discards = 0, L2 Session ID = 0
    Total Allocated ISDN CCBs = 0
INACAP-LaSerena_GW_Voz#show controllers e1 0/0/0
E1 0/0/0 is up.
  Applique type is Channelized E1 - balanced
  Description: E1 TELEFONIA
  No alarms detected.
  alarm-trigger is not set
  Version info FPGA Rev: 08121917, FPGA Type: PRK4
  Framing is NO-CRC4, Line Code is HDB3, Clock Source is Line.
  International Bit: 1, National Bits: 11111
  Data in current interval (860 seconds elapsed):
     0 Line Code Violations, 0 Path Code Violations
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     120 Errored Secs, 48 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
  Data in Interval 1:
     0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
  Data in Interval 2:
  Data in Interval 3:
     0 Line Code Violations, 175 Path Code Violations
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 1 Degraded Mins
     2 Errored Secs, 2 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
  Data in Interval 4:
     0 Line Code Violations, 1 Path Code Violations
     1 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
  Data in Interval 5:
     0 Line Code Violations, 63 Path Code Violations
     4 Errored Secs, 4 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
  Data in Interval 6:
     0 Line Code Violations, 1227 Path Code Violations
     51 Errored Secs, 26 Bursty Err Secs, 0 Severely Err Secs, 10 Unavail Secs
  Data in Interval 7:
     32 Errored Secs, 8 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
  Data in Interval 8:
  Data in Interval 9:
     0 Line Code Violations, 8 Path Code Violations
     5 Errored Secs, 1 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
  Data in Interval 10:
     0 Line Code Violations, 133 Path Code Violations
     36 Errored Secs, 20 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
  Data in Interval 11:
     3451737 Line Code Violations, 53955 Path Code Violations
     0 Slip Secs, 26 Fr Loss Secs, 423 Line Err Secs, 0 Degraded Mins
     113 Errored Secs, 39 Bursty Err Secs, 0 Severely Err Secs, 492 Unavail Secs
  Data in Interval 12:
     7371900 Line Code Violations, 114300 Path Code Violations
     0 Slip Secs, 0 Fr Loss Secs, 900 Line Err Secs, 0 Degraded Mins
     0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 900 Unavail Secs
  Data in Interval 13:
  Data in Interval 14:
  Data in Interval 15:
  Data in Interval 16:
  Data in Interval 17:
  Data in Interval 18:
  Data in Interval 19:
  Data in Interval 20:
  Data in Interval 21:
  Data in Interval 22:
  Data in Interval 23:
  Data in Interval 24:
  Data in Interval 25:
  Data in Interval 26:
  Data in Interval 27:
  Data in Interval 28:
  Data in Interval 29:
  Data in Interval 30:
  Data in Interval 31:
  Data in Interval 32:
  Data in Interval 33:
  Data in Interval 34:
  Data in Interval 35:
  Data in Interval 36:
  Data in Interval 37:
  Data in Interval 38:
  Data in Interval 39:
  Data in Interval 40:
  Data in Interval 41:
  Data in Interval 42:
  Data in Interval 43:
  Data in Interval 44:
  Data in Interval 45:
  Data in Interval 46:
  Data in Interval 47:
  Data in Interval 48:
  Data in Interval 49:
  Data in Interval 50:
  Data in Interval 51:
  Data in Interval 52:
  Data in Interval 53:
  Data in Interval 54:
  Data in Interval 55:
  Data in Interval 56:
  Data in Interval 57:
  Data in Interval 58:
  Data in Interval 59:
  Data in Interval 60:
  Data in Interval 61:
  Data in Interval 62:
  Data in Interval 63:
  Data in Interval 64:
  Data in Interval 65:
  Data in Interval 66:
  Data in Interval 67:
  Data in Interval 68:
  Data in Interval 69:
  Data in Interval 70:
  Data in Interval 71:
  Data in Interval 72:
  Data in Interval 73:
  Data in Interval 74:
  Data in Interval 75:
  Data in Interval 76:
  Data in Interval 77:
  Data in Interval 78:
  Data in Interval 79:
  Data in Interval 80:
  Data in Interval 81:
  Data in Interval 82:
  Data in Interval 83:
  Data in Interval 84:
  Data in Interval 85:
  Data in Interval 86:
  Data in Interval 87:
  Data in Interval 88:
  Data in Interval 89:
  Data in Interval 90:
     2293216 Line Code Violations, 35560 Path Code Violations
     0 Slip Secs, 0 Fr Loss Secs, 280 Line Err Secs, 0 Degraded Mins
  Data in Interval 91:
  Data in Interval 92:
     4785429 Line Code Violations, 66433 Path Code Violations
     0 Slip Secs, 50 Fr Loss Secs, 588 Line Err Secs, 0 Degraded Mins
  Data in Interval 93:
     7367832 Line Code Violations, 97195 Path Code Violations
  Data in Interval 94:
     7366594 Line Code Violations, 92523 Path Code Violations
  Data in Interval 95:
     7369116 Line Code Violations, 93148 Path Code Violations
  Data in Interval 96:
     7369106 Line Code Violations, 95302 Path Code Violations
  Total Data (last 24 hours)
     615011230 Line Code Violations, 9451123 Path Code Violations,
     0 Slip Secs, 76 Fr Loss Secs, 75091 Line Err Secs, 2 Degraded Mins,
     244 Errored Secs, 100 Bursty Err Secs, 0 Severely Err Secs, 77002 Unavail Secs
Circuit did go down, it could be faulty.
