problems generating csv using bat.xlt in CUCM 11.0
chaman prakash
Hello gentlemen
I`m having some difficulties generating csv from the bat.xlt file downloaded from my CUCM publisher using excel 2016 as well as excel 2013
I download the file, enable editing and macros, I hit the "create file format" button to generate the columns I need, all looks good so far..
after filling in some data in the 5 columns I need, witch are Device name, Decsription, Directory number, Display and Line text label (taking care to not enter illigal data, eg boolean, string, integer) I try to press the "Export to BAT format" button.
a popup message displays "please enter numeric value in the text boxes" and this popup will not go away no matter where I click inside excel after this
I try to enter a value above 0 in a text box, but I only get to enter a value in one of the boxes before the popup ruins the day, after that the popup message/error message appears immediately if I click anywhere in the spreadsheet
I have tried to save the file as an "Microsoft excel macro enabled worksheet" (.xlsm) but it doesnt seem to help
Thanks for your help!
5 Replies 5
Chris Deren
Can you share your file?
Make sure your Excel is 32-bit edition, as BAT file dos not work with 64-bit.
Hi Chris,
Thanks for your revert. Please find attached file
The buttons on this file do not work, use the bat.xlt which you download from your CUCM and let us know if that does not work either.
Hi ,
I downloaded the file from CUCM and tried still same error.
Even i verified i am using 32 bit of excel
