Hi , I'm having CUCM System version: 10.5.2.13900-12 I'm trying to install IMP server to the cluster but i'm facing issues and the installation is not complete , IMP Version :Bootable_UCSInstall_UCOS_10.5.2.10000-5.sgn.iso Every time the instal...
Hello guys I'm trying to build MRA with two different domains, and its giving me hell :( I just can't login from outside... So, here is infrastructure: inside domain: inside.example.com (subdomain of example.com) outside domain: example.com Expre...
We have two 4331 routers with PVDM4-32 cards in them that we plan to use as CUBE router for our new data center. Right now I am testing and learning the setup. We want to use the Box-to-Box redundancy configuration for the CUBE functionality. That ...
Hello I have the PVDM-32 module installed on the router and wanted to know would that be enough for me to setup a couple of cisco ip phones to use? or what other modules/software would i need to make the phones work/dial-out/use voice mail/and video?...
Hey All, I was just wondering. I have an OVA I used to stand up a CUCM 11.5 publisher. Do I use this same OVA to stand up the VMs for my four subscribers, or is there a different OVA to use for the subscribers? Thanks in advance!
Hello Experts I am a newbie in the domain and doing baby steps now on this field. I need to know more about the fax protocols and I would be grateful if you can guide me. What are the protocols that comes in when we talk about Cisco fax deploymen...
I have an Scenario, where I am using Cisco 6901 as Hotline Phone and Third Party SIP phones as well. I am using Cisco Call manager Express. I want to know that whether I can configure PLAR with Cisco CME?
Hi ! everyone. I have to Hard Reset by 3491672850*# After that It can't boot-up ,After plug a power the light is turn on just a second the light is turn off and that's Looping. Maybe Flash file has deleted. I need to restore flash file to the device...
Hi, we are running with a problem with skype business not working with dx650 phones. call manager version 11.x i have also attached the screen of the error Please let me if anyone has a solution for the same. regards
I have a CUCM phone config question. When dialing outbound, and a pause/waiting occurs, and the end user waits more then 5 seconds it goes to the automated attendant. How can I look to fix or changes any settings that could not transfer the call to...
Hi Everyone I was asked by my manger would it be smart to add an additional SIP trunk to our environment just in case the current one goes down so we could have redundancy. I told him that would be smart but I would go with a different carrier for th...
Hi Freinds Does CME 4.1 Supports 9971 ?? I m Not able to register this Phone even though i download 9971 files to flash , any recomendation thanks all Ibrahim
All, Does anyone have any experience or advice with best practice figures for Tomcat errors/requests/SessionsActive for cucm-uds? This is a 2 node cluster with SRV DNS pointing to the Subscriber in the 1st instanceI am seeing high CPU for Tomcat ...
Hi Guys, I have outgoing Voip dialpeer where i cannot remove prefix. But we can make translation rule to omit prefix like 9 and then add outbound DID for outgoing calls. Any idea/suggestion? dial-peer voice 2 voip description OUTGOING CALLS transla...
Hi I'm using a 2811 gateway with 15 fxo lines to connect my pbx to pstn. It works fine for 1 or 2 days and after that stops. when I enable "debug vpm signal" and "debug vpm error" this messages are logged when calling to fxo lines: Jun 18 05:59:25.86...
Subject | Author | Posted |
04-29-2025 02:30 AM | ||
04-28-2025 11:36 AM | ||
04-28-2025 05:35 AM | ||
04-26-2025 05:48 AM | ||
04-24-2025 02:49 PM |
User | Count |
3 | |
2 | |
1 | |
1 | |
1 |
